F430 - rear main seal leak ? | FerrariChat
Discussion in 'Technical Q&A' started by PaulCr, Oct 5, 2020.
  1. PaulCr
    PaulCr Rookie
    Jan 15, 2018
    14
    Geneva, Switzerland
    Paul Cruikshank
    F430 F1 2008 23kkm - noticed oil pool under car early this year and finally got around to investigating at the weekend. Removed bottom tray (a lot of oil) and obvious leak is at junction of main crankcase and clutch housing. Cleaned it up - returned few hours later to see oil drips collecting again on the engine block under side. Almost certain its the main crankshaft seal, but why does it continually drip if the engine is off for several days - is there a gravity feed of the oil to the main bearing ? Other possibilities ? ......and yes, my fault for leaving the car too static for months on end. Cheers, Paul
  2. windsock
    windsock Formula 3
    1,066
    This is really common. The clutch dust eats the rear main seal over time. As the car is a dry sump system they will not leak while running because the oil in the engine is minimum and it is being pumped to the sump in the gearbox. Once you turn the engine off the oil will eventually equalize between the engine and the sump. This puts the rear main under the level of the oil and they leak. Easy fix is to replace the rear main seal and inspect the clutch components while your in there.
  3. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,114
    Georgia
    Wade Williams
    If you put a rear main seal in, it is not an option to reseal the throw out bearing. It has to be done. Once you slide the gear box back, the throw out bearing then extends to the end of stroke. The clutch diaphram fingers have been holding it, so now it slides onto all of the clutch dust that is on the flange. It will leak if not addressed. I always allow my customer to have the option of replacing the clutch and ALL associated components. No need going in again for something you actually have apart now.
    tbakowsky, 2NA and JL350 like this.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    This is not an "easy" job.
    Excellent point.
    2NA likes this.
  5. PaulCr
    PaulCr Rookie
    Jan 15, 2018
    14
    Geneva, Switzerland
    Paul Cruikshank
    Thanks guys, really solid explanation and advice. So until I get it repaired I should park on a hill to keep the oil in the gearbox - just joking. I heard that the leak is also assocaited with lack of use - but the abrasive dust seems to be the main killer - yes ? Out of interest, the flow of oil back into the engine crank case with the engine off, what route does the oil flow take - via the pumps or are there other oil channels ? Cheers, Paul
  6. Ferrari Tech
    Mar 5, 2010
    1,114
    Georgia
    Wade Williams
    The oil is from the oil pan, not the trans, so park facing downhill. ;)
    The oil gravitates from the tank (clutch housing) into the oil pan through the oil pump.
    I am a big believer in driving these cars. I tell clients all the time that just starting and moving it around won't do it. I also remind them that everything in the car should be turned on or off or adjusted and messed with. Every knob, button, switch, lever, handle, or whatever. Move it, or adjust it. Keep it all working The Italian tune up is a real thing. I have left HUGE black clouds of crap behind cars on test drives that just never get run hard. The rev limiter is there for a reason, you should know where it is and what it feels like. The oil temp need to get fully up as well to steam off the moisture in the engine. I have come back from test drives with the oil fully hot and just let the engine run with the cap off the tank and watch the steam roll out just to help get the moisture out. You won't get it all but try anyway.
    Sorry for running off a bit, rant over.
    Red 27, wiley355, f355spider and 3 others like this.
  7. PaulCr
    PaulCr Rookie
    Jan 15, 2018
    14
    Geneva, Switzerland
    Paul Cruikshank
    Thanks Merlin - yes, and the smile gets bigger as the engine starts to scream. Concerning the leaking oil seal, what's your view - simple ageing, becoming too dry when parked up, dust from the clutch, other? - ever heard of cases where the seal recovers once the car get used regularly.....well I have to ask.
  8. yelcab
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    Never heard of that one, but ... one can always reach for the stars. Not!
  9. Manda racing
    Manda racing Formula 3
    Feb 25, 2015
    1,245
    Bakersfield, Ca
    Mark
    You could mess up the clutch if it gets oil on it. Right?
  10. PaulCr
    PaulCr Rookie
    Jan 15, 2018
    14
    Geneva, Switzerland
    Paul Cruikshank
    Yes, tis reaching for the stars but was a half serious question. I work with vacuum system - needs very good tightness with elastomer seals - but all the seals are static. A leaking vacuum seal can sometimes be recovered by adding silicon oil or grease. So if a dynamic seal like the main bearing becomes dry, then perhaps the presence of oil could reset - eg by driving out contaminants at the sealing line due to the positive pressure in the crankcase or simply softening the seal. If the seal is damaged due to cracking/scoring then its impossible to regain tightness.
  11. Ferrari Tech
    Mar 5, 2010
    1,114
    Georgia
    Wade Williams
    I am not sure there is a definitive answer as to why. Clutch dust doesn't really go inward behind the flywheel, I think not running is more likely or it just doesn't want to do its job. As for getting better, I don't think it will get better. Then again, it isn't really hurting anything except making a mess. Again, the oil comes from beck of the flywheel and doesn't get on the clutch so no harm there. Drive it until you can't stand it and then get it fixed.
    2NA likes this.
  12. PaulCr
    PaulCr Rookie
    Jan 15, 2018
    14
    Geneva, Switzerland
    Paul Cruikshank
    Thanks MerlinTech. I'm at ~ 50% clutch wear so would be good to get a bit more life out of it before doing the big job. I'll keep you updated if any miracles happen. Cheers, Paul
    Ferrari Tech likes this.
  13. PaulCr
    PaulCr Rookie
    Jan 15, 2018
    14
    Geneva, Switzerland
    Paul Cruikshank
    Update: sent car to R&D Automotive in Manchester, UK - privately owned Ferrari repair specialists (ex-Ferrari mechanics - ask for Nick). They inspected clutch and flywheel - neither required replacement (just the release bearing), so total was ~2000 GBP - great job, would highly recommend.
  14. Jackson32
    Jackson32 Rookie
    May 29, 2017
    48
    North Carolina, U.S
    Jackie
    Are there any symptoms to the rear main seal leaking? should it be leaking after clutch replacement after 2-3 years with driving the car?
  15. PaulCr
    PaulCr Rookie
    Jan 15, 2018
    14
    Geneva, Switzerland
    Paul Cruikshank
    First sign of a rear main seal leak is oil on the under tray of the car - look into the engine bay with a torch and check presence of oil. The seal is easily changed during a clutch replacement, but I don't know if its systematically done/inspected by Ferrari.
    However visual presence of oil doesn't confirm the origin - you need to take off the undertray and see where the drips are coming from (for example could also be the oil pump)
  16. JM280z
    JM280z Formula Junior
    Aug 22, 2020
    677
    Jake
  17. yelcab
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    drill a hole, use a seal puller. There is plenty of space for that.
    Red 27 and 2NA like this.
  18. JM280z
    Aug 22, 2020
    677
    Jake
    Got it. Image Unavailable, Please Login
    f355spider likes this.
  19. garybobileff
    garybobileff Formula 3
    Sponsor
    Feb 5, 2004
    1,105
    San Diego CA
    Gary
    Historically, There have been a number of times that people complain about the rear main seal leaking, but it's been our experience over the years that the seal is fine, but in the end of the crank is a threaded plug which almost always causes the leak. Mainly on shut down of the motor, it leaks out the oil that is held inside the crank shaft. Remove the threaded plug, clean the surface, remove the factory sealer, reseal and install the plug, 99% of the time, that will cure your problem.
    Gary Bobileff
    Paddy_SP likes this.
  20. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
  21. Ricambi America
    Sponsor Owner
    @2NA I think he is referring to the plug at the end of the crankshaft, 176396 (360) or 163528 (F430) ?
  22. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
  23. yelcab
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    I have seen that plug leak on a 360, but it does not look like the 430 crank has a plug. I actually don't know what torque value to put the 360 crank plug back.
  24. garybobileff
    Sponsor
    Feb 5, 2004
    1,105
    San Diego CA
    Gary
    2NA's photo above shows the back of the crank with the threaded plug, if you look inside the pilot bearing, you will see the brass Allen plug in the picture. Ferrari part # 163528. All 430's and Maserati 4.7 V 8's have this threaded plug. I think we have resealed several dozen over the years.
    Gary Bobileff
  25. Ricambi America
    Sponsor Owner
    It does.
    Just not drawn by the artists at Ferrari.
