F430 - oil change question- quick question | FerrariChat
Discussion in '360/430' started by carguy007, Mar 21, 2018.
  1. carguy007
    carguy007 Formula Junior
    Apr 24, 2013
    886
    i just drained the oil and removed the circular piece to access the mesh filter. This piece was incredibly difficult to remove. I also noticed some white sealant around the metal pieces edges. I am putting everything back togetther and was curious if I shpuld be using some kind of sealant.
    I watched our fellow f chatter Daniel's video's and he did not use any. I noticed that the circular piece in his video also had the same white sealent. Should I just replace the o ring and torque to spec? Link to vid:
    Any advice is greatly appreciated. If someone has a link to DYI with torque specs that would also be appreciated.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    Here is the document from the wsm ..the torque for the oil drain plug is believed to be too high but the rest of the document should be ok
    You should not have to put any rtv sealant if you put a new gasket which I would recommend
    If you want that extra protection ..maybe consider locktite 518
    Sent from my Moto G (4) using Tapatalk
  3. djempire
    djempire Formula Junior
    Apr 30, 2012
    613
    Toronto
    Serf
    Replace the circular flange O-ring. I added a thin layer of gasket sealant for security.
    I'm curious how many people actually change the mesh filter? I did mine last year and it looked like the original one after over ten years of life. It had all sort of crud/shards caught in the filter. Mind you it only has ~8K miles.
  4. carguy007
    Apr 24, 2013
    886
    Thanks for the help. I am having a hell of a time getting the clip out to realeasetge mesh filter. Did you use a special tool. In the instructions it says to leverage out the clip with screw driver. I tried this and failed miserably. Any pointers? I imagine there is a specific tool to use and it will just pop out:)
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    Use a pick
    Sent from my SM-T380 using Tapatalk
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
  7. djempire
    Apr 30, 2012
    613
    Toronto
    Serf
  8. carguy007
    Apr 24, 2013
    886
    That's a small arsenal for the job... lol - thanks again for the advice
  9. rennspeed
    rennspeed Formula Junior
    528
    Rennspeed
    Great document. I would certainly use these instructions and not that video.
  10. Dean Palmer
    Dean Palmer Formula Junior
    May 21, 2010
    407
    St. Petersburg, FL
    Dean Palmer
    Old thread but just happened to see it. I also have the large drain with the white sealant around it. No need to remove it if you have a vacuum of some sort to get up in there and ensure there are no particles of anything up in there on the screen. There was nothing on mine but the car only has just under 16k miles and has had regular oil changes.
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    Best of luck, i gave up in the end.
