F430 Motronic ECU Pinout | FerrariChat
Discussion in 'Technical Q&A' started by SfefVan, Oct 21, 2009.
  1. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Hello,
    As an owner of a F430 03/2005 M/T, I'd like to know more about the F430 Motronic Ecu's and the specific Ferrari communication protocols used. Some sources say it's a ME7.1.1, others say it's ME7.3.2. Which one is right?
    Does anybody has the ECU pinout details and cabling diagrams of the F430? Any technical information about the Motronic ECU's would be much appreciated.
    Thanks a lot,
    Stef
  2. hexxman
    hexxman Karting
    Oct 25, 2006
    146
    10016
    NB
    #2 hexxman, Nov 2, 2009
  3. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Thanks for your answer. I got the official info now and both ECU's are ME7.1.1. It seems that the layout you attached is from the F360. I removed mine for making diagnostics and it's very different compared to your picture. Got already lots of info but there's still so much to discover and to decrypt the K lines and Can buses.
  4. North East Auto Doctors
    65
    conn
    Adam Varney
    hey SfefVan what are you ussing to check the comm lines with? Do you have any experience hacking on any other vehicle makes to cross refrence? I could maybe hook you up with some SD3 printouts as parameter refrences off a US car.
  5. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Hi Adam,
    I'm in IT since many years as a consultant but don't have a huge experience in automotive diagnostics even if I'm quite familiar with low level protocols like CAN or LIN. My goal is to reverse engineer the F430 ECU's. I'd love to have some SD3 printouts because the schematics are very important to start with. You can PM me them if you want to.
    Many thanks,
    Stef
  6. North East Auto Doctors
    65
    conn
    Adam Varney
    your going to spend alot of time doing something thats allready been done. have you read out the data in the ecu yet?
  7. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    You really think this has already been done? I mean reverse ingeneering of all the CAN / LIN modules? If yes, I'd like to get some more info if you know someone who did this. We have a project to replace the SD3 by a software solution which would do 99% the same but for a much much lower price. And the SD3 will no more be produced as Digitek stopped it. Also Ferrari is changing the SD3 by a thoughbook called DEIS which is directly networked with the factory...BTW, we've already reversed Porches and BMW.
  8. North East Auto Doctors
    65
    conn
    Adam Varney
    I saw your talking to the durametric guys about it. The people you need are the ones writing performance codes for thease cars. They have access to that fantastic file tells them what all the addresses are In side thease ecus then they find the ones relevant for tuning performance and work with them then ussually will have to fine where the diagnostic code criteria is to change the trigger values so the engine light stays off. Thease files are very expensive and I think illegal to possess. My email is [email protected] let's talk somemore and I'll see if I can point you in the right direction
  9. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Yeah, you're right, I'm in touch with them about this project. I very much agree that the guys doing reflashing have a very indeep knowledge of the ECU with can be already a huge vlue of information but I'm not targeting only the ECU's but all the controlers and modules. Sure, I'll drop you an email. Thanks
  10. sleepinglh
    sleepinglh Karting
    Jul 30, 2015
    82
    Sydney Australia
    Q
    And I'm still after F430 ECU pinout diagram for booth banks.... can someone please email me a copy as I need to wire up ECU for turbo project.
    Please email to [email protected]
    THANKS!
