F430 Interstate MTP-H6A battery | FerrariChat
Discussion in '360/430' started by mjz, Feb 22, 2012.
  1. mjz
    mjz Karting
    Aug 3, 2007
    173
    Houston, Texas
    Michael
    Will the factory supplied C-Tek charger maintain the AGM battery from Interstate (MTP-H6A)?
    I am replacing the FIAMM factory battery with one of these. As it is an AGM battery, I read that the float charge required to "tend" it is different.
    Anyone deal with this?
  2. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,840
    Jupiter, FL
    Paul Bianco
    I would say yes. That is the same battery in my car. But I would confirm with someone else to make sure.
  3. hangarsixco
    hangarsixco Formula Junior
    Oct 10, 2010
    396
    S. California
    Chris
    I'm not sure about that C-tek but Deltran makes a specific tender for Gel Cell Batteries.
  4. sclja
    sclja Formula Junior
    392
    San Diego Ca
    Scott Cairncross
    Just put 2 in today... They are a standard wet battery so charging is not an issue....
    Scott
  5. hangarsixco
    Oct 10, 2010
    396
    S. California
    Chris
    The MTP-H6A is a Gel Cell the H6 is a Wet Acid Battery.
    I can't find any Data on the Deltran that makes it specific to a gel cell or standard wet acid, but according to Deltran they have a specific tender for the wet and one for the Gel.
    The standard may work but I would not risk a $200.00 bat.
    Just my opinion.
  6. tazandjan
    39,016
    Every reference I read says the MTP-48H6A is a wet cell battery using silver calcium technonlgy, just like the MTP-48H6. It is just a bit more powerful than the H6. This includes Interstate's own specifications on their web site. Does anybody have a reference for the MTP-48H6A, besides FChat, that shows it is an AGM battery? The warranty on the battery is identical to the MTP-91 and MTP-48H6 at 30 months free replacement and 85 months total.
    Braille and Odyssey do make AGM batteries that fit Ferraris.
  7. hangarsixco
    Oct 10, 2010
    396
    S. California
    Chris
    Taz,
    I was told by a tech at Interstate that the MTP-H6A is a Gel cell. He may be wrong and it could actually be an AGM. If so I stand corrected.
    Im going to try and call interstate tomorrow and ask about a few bat models. If I get any decent info I'll let you know for your Battery Reference sheet.
    Chris
  8. tazandjan
    39,016
    Chris- AGM batteries are probably the gel cells you are talking about. They do not need to be vented, are spill-proof, and can be mounted in different orientations (even upside down) without problems.
    Let us know if you get any additional info on the H6A.
  9. bshah
    bshah Formula Junior
    Jun 28, 2011
    326
    Chicago
    MPT-91 is the way to go. Venting was the only mod....the screws fit just fine.
  10. sclja
    392
    San Diego Ca
    Scott Cairncross
    #11 sclja, Feb 24, 2012
    Here are the specs on the battery. This battery or the mtp48h6/ fits perfectly and the breather vent location works perfectly with the stock fitting in the car with no mods.
    Scott
  11. LouB
    LouB Formula 3
    Apr 15, 2001
    1,811
    FL, OR
    I have that battery in my 430 Spider and the Ferrari supplied charger works fine. Not sure if its a C-teck.. Its the red one supplied in the leather case.
  12. tazandjan
    39,016
    #13 tazandjan, Feb 24, 2012
  13. tazandjan
    39,016
    Scott- That is the ad I found, too, which identifies the MTP-48H6A as a conventional wet cell battery using silver calcium technology.
  14. LouB
    LouB Formula 3
    Apr 15, 2001
    1,811
    FL, OR
    Yes, that's the charger I have.
