F430 Header Failure (it CAN happen to you!) | Page 7 | FerrariChat
Discussion in '360/430' started by Trent, Aug 1, 2012.
  1. 88Testarossa
    88Testarossa Formula 3
    Sep 25, 2012
    2,450
    Annapolis and Daytona Beach
    Al
    Sounds like the makings of a class action lawsuit, assuming there's a law firm looking for business. Ferrari should do better, starting with all those sticky plastic interiors.
    Sent via itty bitty electrons
  2. BigTex
    79,212
    Houston, Texas
    Bubba
    I think the modern perspective is consider your headers a "wear item", like brake pads, and tires.....
  3. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    +1
    Ferrari considers the exhaust manifolds a 'wear and tear' item.....thats what the f dealer told me when my manifolds failed.
    Theres lots of choices.....go aftermarket.
    Tubi Sales likes this.
  4. Perkins
    Perkins Formula Junior
    Dec 22, 2013
    702
    Sacramento
    Rick
    My 2005 F430 had the MKII headers when I purchased it from the second owner. My indie noticed that they were starting to blow packing all over the floor pans. I immediately bought the AP headers and had them installed. Cheap insurance.
    whatheheck likes this.
  5. azzurribaggio
    azzurribaggio Formula Junior
    Bring this thread back to life, so bottom line, to avoid any header issues replace the stock Ferrari headers with aftermarket ones and you'll not experience this again?
  6. CarAholic
    CarAholic Formula Junior
    May 10, 2016
    514
    Correct very cheap insurance especially for mental clarity
  7. michaelo
    michaelo Formula Junior
    350
    Tn.
    Michael O.
    After two sets of crappy Ferrari headers and a dealer saying I needed another set, I questioned the sanity in such a proposal and despite being warned
    that the car would be less attractive without Ferrari parts I went with Fabspeed headers and blankets. The thought of bad headers is no longer a
    constant theme and I guess my car is less attractive. I also went off the reservation with Hill Engineering ball joints. I just made my car even less attractive.
    You would think I would learn!
    Zed82, LARRYH and whatheheck like this.
  8. RedTaxi
    RedTaxi F1 Rookie
    3,253
    New Zealand
    Glen
    Stronger aftermarket headers work but don't actually address the real problem which is the rigid lower exhaust brackets. Which can simply be removed.
    LorenzoR and whatheheck like this.
  9. f355spider
    f355spider F1 World Champ
    17,938
    My local dealer told me the same when I was on the hunt for an F430 back in 2015. When I inquired about exhaust manifold failures, their recommendation was ensure you have MKII exhaust manifolds, and install the Capristo brackets. At that time, they had no failures with that combination. They did recommend to still monitor the situation by smoke inspection every year or two during normal maintenance visits.
  10. ttforcefed
    ttforcefed F1 World Champ
    18,874
    my brain hurts every time i come back to think about this issue.
    i thought the capristo brackets actually accentuate the problem and the best thing to do was take the brackets off?
    crinoid likes this.
  11. f355spider
    17,938
    That's why I bought a 430 Scuderia, the only issues they have with exhaust manifolds is the mounting flanges to the heads can warp, causing leaks and a ticking noise at start up. But if you remove them, get them flat ground, and reinstall, they seem to stay trouble free from then on.
    LARRYH likes this.
  12. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,059
    Fort Washington, PA
    John S
    Phil from Fabspeed here.
    360 and 430 headers are can be a serious headache. These are some of our highest selling products as well which is why we always have them in stock. But most of the time we try to have guys line up doing the headers as preventative maintenance and you can keep the stock headers to sell with the car as original equipment.
    It is not fun to change the headers by themselves especially when there are so many cases of header failure. Knowing that there is an issue and not doing anything to prevent the issue. Boom they fail.
    psych0hans likes this.
  13. CarbonDan
    CarbonDan Karting
    Aug 19, 2017
    185
    PNW
    ^ Just ordered a set of fabspeed headers for my 360CS last week, they should be installed by next weekend. Will be glad to have that peace of mind (and noise!)
    LARRYH likes this.
  14. michaelo
    350
    Tn.
    Michael O.
    The OEM Sport Exhaust addresses the bracket issue. Lots of rubber mounts to allow play in the connections.
  15. Jgivoo
    Jgivoo Formula Junior
    432
    New Jersey
    +1
  16. RedTaxi
    RedTaxi F1 Rookie
    3,253
    New Zealand
    Glen
    Yes they got it right with that exhaust. It would be interesting to know if any of the cars that came optioned with that exhaust ever suffered header failure.
  17. ttforcefed
    18,874
    what if you already have capristo headers with capristo high flow cars and want to keep the stock mufflers?
  18. RedTaxi
    RedTaxi F1 Rookie
    3,253
    New Zealand
    Glen
    ^^ No problem just bin the lower brackets.
  19. 1949live
    1949live Karting
    Sep 18, 2014
    111
    Denver, Colorado
    David
    Didn't see anywhere in this thread the impact on emissions of replacing the stock units with headers. Has anyone had their 430's tested after the header installation and passed?
  20. RedTaxi
    RedTaxi F1 Rookie
    3,253
    New Zealand
    Glen
    Pre cats are for cold start emissions. Without them when up to temp, you should be fine. Mine did throw a CEL which I cured with O2 extenders.
  21. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,059
    Fort Washington, PA
    John S
    Hey Guys,
    THe headers will not effect your emissions testing. You with still pass the sniffer testing and obdii port as well.
  22. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    I have Agency Power Headers on mine and Kline Innovation exhaust with stock cats and no precats.
    Always passed annual emission test with zero problems and no check engine light.
    We are lucky here in Washington State. No more emission / smog test effective year 2020! Yay!
    Dan
  23. shifter
    shifter Formula Junior
    625
    Danville, Ca
    Joe
    I have Tubi manifolds on my 2006, no lights, no O2 extenders, passed Ca smog requirements. Stock OEM cats, Ferrari Sport exhaust.
    Year matters, I think.
  24. msper
    msper Karting
    Oct 29, 2016
    70
    New Jersey
    Mark
    FYI.....I have a pair of Tubi manifolds for sale in the classified section.....These are the BEST manifolds for a 430.....Take a look at my ad
    Thanks!
  25. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    I haven’t heard of just removing the brackets outright? Do you mean simply taking them off as not replacing them with anything?
