F430 F1 clutch slipping issue | FerrariChat
Discussion in '360/430' started by Zed82, Oct 4, 2017.
  1. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    479
    Sweden
    Hi guys,
    Couple of days ago my gearbox and clutch starting acting erratically all of the sudden. The shifts took longer with clutch slippage and when i came to a stop and was about to drive off there was a warning beep everytime i touched the throttle. If i still tried to drive off there was bad clutch slippage but it drove off. All this happened within 10 minutes maybe and was gone thereafter.
    I didn´t do any remarkable tough driving before where the clutch could have overheated. I didn´t smell anything or see any smoke or so. There is no stored error codes and clutch is worn 60% according to the computer.
    Car i at a Ferrari specialist right now for a check up and they are puzzled.
  2. Virulosity
    Virulosity Karting
    Jun 26, 2017
    162
    Orange County CA
    Rob
    PLEASE let me know what you find out. My 360 is doing this too.
  3. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    531
    Fountain Hills
    Jon
    Don't always believe the clutch reading as the number can be reset with a worn clutch. If the clutch is slipping the clutch is either worn, or you may have a leak in the throw out bearing slave. Either way, you can't fix the problem until you dig into the area.
    Could also be the f1pump not keeping enough pressure in the system.
    whatheheck likes this.
  4. Zed82
    Sep 28, 2017
    479
    Sweden
    Clutch reading was around 62% worn according to the dealer when I bought the car last week. The dealer did another read out on Tuesday this week and it was 59% left. I then took the car to a specialist where I found out that the real clutch wear is 89,8%. Go figure...
  5. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,625
    England
    Mark
    It is easily manipulated. I never pay any attention to calculated clutch (or CCB) wear. IMO the only way to check is via the access panel underneath the gearbox.
  6. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Clutch wear reading is very inaccurate. It can jump quite a bit from one dealer to another.
    Most likely your issue is worn out clutch. The clutch on my 360 Spider started popping out of gear at 78% wear reading.
    Removed and replaced clutch and all is good again. Except my pocket was $8,200.00 lighter, and that was after 10% Ferrari Car Club discount.
    Hope that helps.
    Dan
  7. jkatz
    jkatz Rookie
    Jun 14, 2020
    1
    jacob katz
    I'm new here but am having a similar intermittent clutch slip, comes and goes, any suggestions ?
  8. Zed82
    Sep 28, 2017
    479
    Sweden
    My issues were solved with a new clutch.
  9. Doug2D
    Doug2D Karting
    Mar 29, 2015
    136
    I had to get a new clutch even though my reading was at 70%. Clutch is great now.
  10. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    I have a post here about my experience with clutch wear and clutch reading.
    Summary:
    Your clutch will start having issues at about 70% wear.
    Signs of clutch wear:
    • Clutch popping out of gear uncommanded.
    • Clutch starting to slip.
    There is no other fix Im aware of for the above anomalies except clutch replacement.
    F1 Clutch replacement average costs depending on what other parts needs to be replaced while the transmission is out:
    • Independent mechanic: $6K
    • Dealer: $9K - $11K.
  11. Zed82
    Sep 28, 2017
    479
    Sweden
    From my experience if you ask five indys and five dealers about the clutch reading you will get 10 different answers.
    Doug2D and whatheheck like this.
  12. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    True!
  13. Fenz
    Fenz Karting
    Nov 8, 2018
    167
    Team Europe
    To my knowledge, the only value that you can fake that will affect clutch % wear calculation in a "positive" way is the "Clutch Position From New".
    You can't fake the "Clutch Position Closed" value, which is the one that can give you a good hint of the current clutch wear.
    I'm curios what peoples Clutch Position Closed values was reading at the time when the clutch needed replacement?
    Guess somewhere between 20 and 25 mm.
