430 - F430 ECU Pinout | FerrariChat
430 F430 ECU Pinout
Discussion in '360/430' started by tstuli, Nov 12, 2022.
  1. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    379
    NC
    Hi
    Does anyone have a F430 ECU pinout they'd be willing to share?
    Alternatively, any good sources for the complete wiring diagrams?
  2. Qavion
    Qavion F1 World Champ
    13,806
    Ian Riddell
    Nope. Not complete ones.
    I have a Scud pinout (mostly similar to a regular F430)
    RH ECU:
    https://www.dropbox.com/t/DM1o3Gs5RTKT6EDz
    LH ECU:
    https://www.dropbox.com/t/fkmAJzUAxB08uCoG
    Links expire in 6 days.
    If you have a specific problem, it might make it easier for us to figure out your needs and what pins to check.
    flash32 likes this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    I have something..if no one answers by tomorrow afternoon...shoot.me.a PM to.remind me when i am in front of my PC and i will send
  4. tstuli
    Jun 12, 2018
    379
    NC
    Perfect thanks. The scud on is close enough.
    flash32 and Qavion like this.
  5. Qavion
    13,806
    Ian Riddell
    Note that some of the pin functions don't make any sense at all. e.g. pin 50 on the RH ECU has three different unrelated functions. I don't have a wiring diagram for the RH ECU with which to resolve this issue.
    Here is a diagram showing some wiring going to/from the ECUs "E300" and "E006" (at the bottom of the diagram).
    https://www.dropbox.com/t/dQeg33PrZvVEnXf0
  6. nwhite96244
    nwhite96244 Rookie
    Jun 27, 2023
    40
    Northville mi
    Nick white
  7. Qavion
    13,806
    Ian Riddell
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    Qavion likes this.
  9. nwhite96244
    nwhite96244 Rookie
    Jun 27, 2023
    40
    Northville mi
    Nick white
    Ya I bought workshop manual online but only shows codes and removal processes
  10. bazza9683
    bazza9683 Rookie
    Jul 14, 2021
    7
    United Kingdom
    Barry Walker
    Hi Guys,
    Have the following fault P2632 (Fuel pump B control circuit/open malfunction(sig), looking for LH engine ecu pin out for 2008 F430 coupe Uk car.
    Want to check signal to fuel pump relays.
    Any help greatly appreciated
  11. Qavion
    13,806
    Ian Riddell
    #11 Qavion, Feb 13, 2025
    Copied from the Tech Forum ... (message easier for me to find here on the 430 forum in the future)
    I have an incomplete ECU wiring diagram for the 430, but the fuel pump wiring for the LH side seems to be complete.
    https://www.dropbox.com/t/sw03jcjCBATnLhdw
    Link expires in 6 days.
    It may require some explanation:
    Looking at the diagram, there are two fuel pump relays PSR8 and PSR9 on relay block CBL9-C (middle relay block) behind the left hand seat. See the bottom third of my huge diagram.
    PSR8 (pump speed 1) and PSR9 (pump speed 2) relay coil power is provided by fuse PSF1 which is powered by key power relay PSR3 on relay block CBL9-A (inboard relay block behind the left hand seat). Check fuse PSF1. Swap L/R bank pump relays over if you think it's a relay issue.
    The signal from the ECU (E300) which energises PSR8 is provided by pin 65. See the graphic above the ECU for pin numbering. There is a diode in ECU pin 65 circuit (PZ01). If you do carry out wiring checks between pin 65 and relay pin 2 (aka 85), make sure the polarity of your ohmmeter is ok. Since pin 65 also (edit) turns on the fuel vapour diagnostic pump, maybe you could check for a signal there, too.
    The signal from the ECU which energises PSR9 is provided by pin 116.
    I'm not familiar with the fault code, but I guess the ECU only talks to the coil of the relay. Unless there is a fuel pressure sensor sending data back to the ECU, I can't see how the ECU knows what is coming from the relays (on pin 5). Anyway, let me know if you need help analysing the relay output circuits.
    Caveat: The original Ferrari diagrams on which my diagrams are based are are riddled with errors, so I can't guarantee their accuracy
    Please let us know how you go.
  12. Qavion
    13,806
    Ian Riddell
    Not sure if "pump B" is the"speed 2" relay. I guess diagnosis will be easier if it is. No diode or splices.
    My relay graphics show the relay socket contact numbering...
