F430 dyno results: | FerrariChat
F430 dyno results:
Discussion in 'Canada' started by djempire, Apr 19, 2017.
  1. djempire
    djempire Formula Junior
    Apr 30, 2012
    613
    Toronto
    Serf
    #1 djempire, Apr 19, 2017
  2. Indyjones
    Indyjones Karting
    Jan 28, 2009
    219
    Pacific NW
    Very nice numbers :) I assume you need to run 94 octane fuel for the tune, or are you still on 91/92?
  3. djempire
    Apr 30, 2012
    613
    Toronto
    Serf
    Running 93/94 is best but not necessary. The tune 'adapts' with the type of gas you add. I had old 91 gas for this run. I expect a higher yield as the ECU adapts and higher octane gas is used.
  4. Zaius
    Zaius Formula Junior
    May 8, 2014
    863
    Thats an excellent result.
  5. Indyjones
    Indyjones Karting
    Jan 28, 2009
    219
    Pacific NW
    Did your exhaust note change at all with the headers (hard to tell on the videos).
  6. GordonC
    GordonC F1 Rookie
    4,120
    Calgary, AB, Canada
    Gordon
    Something is wrong - there's no way torque can be greater than hp at 5600 (formula to convert measured torque to hp is hp = torque x RPM /5252).
    The power dip in the mid 5000 rpm range to below the torque values doesn't compute.
  7. djempire
    Apr 30, 2012
    613
    Toronto
    Serf
    #7 djempire, Apr 27, 2017
    Nothing wrong at all. This is an inherent result of aftermarket headers on this motor. There are various F430 dyno threads that show similar dips. I suspect that it could be the collector going from 4 to 1. In real world driving, there is no perceived dip in power or torque. It pushes violently all the way to redline. What a difference.
    A few examples:
  8. djempire
    Apr 30, 2012
    613
    Toronto
    Serf
    Thanks...I'm very happy with the result and it endorses the fact that these motors are conservative due to some restrictions.
  9. djempire
    Apr 30, 2012
    613
    Toronto
    Serf
    Yes it did change. To sum up:
    - Start up is a louder, throatier bark. Loud idle until warm.
    - Warm idle, slightly higher pitch. Almost stock.
    - Take off from Race mode, stock until the valves open up.
    - Valves open, extremely noticeable! Very loud pitch, much throatier and symphonic, shifting gears gives a back fire sound.
    - Sounds like the mid 90's F1 cars gearing up/down.
  10. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,503
    Lake Villa IL
    In both pulls, crossover is at 5252 and torque is lower than HP at 5600 as well. Not sure what you're looking at.
    Nice results!
  11. GordonC
    GordonC F1 Rookie
    4,120
    Calgary, AB, Canada
    Gordon
    Apologies, you and djempire are correct - I was mixing up the curves under 5250. My mistake!
    Gordon
