News
F430 Coupe, Spider, Scud, 16M skid plates
Discussion in 'Boardwalk Ferrari & Maserati' started by Challengehauler, Jul 14, 2009.
  1. Challengehauler
    Challengehauler Formula 3
    Jul 28, 2008
    1,242
    NE Connecticut
    DB
    #1 Challengehauler, Jul 14, 2009
    We have skid plates for your 430.
    These mount below your front bumper and take pretty much all of the beatings. (They weigh less than 4 lbs. installed)
    They are made of black ABS plastic, come with hardware, and we will provide the template instructions for the Scuderia and 16M installation.
    They are priced at $400.00 a pair, part number 6927430A
    Feel free to contact me directly in the parts department. (info below)
    Dan Brodaski
    (972) 447-5228
    Cheers!
  3. babyjesus
    babyjesus Rookie
    27
    Woodside, CA
    On a normal F430 Coupe, do they bolt up to existing locations? Or is any drilling/modification required?
    -mike
  4. Challengehauler
    Jul 28, 2008
    1,242
    NE Connecticut
    DB
    #3 Challengehauler, Jul 14, 2009
    You will have to drill as they are mounted to the bottom of the bumper. Hardware is stainless. You will also have to drop your front under panel slightly to get to the nuts and washers on the inside.
  5. Challengehauler
    Jul 28, 2008
    1,242
    NE Connecticut
    DB
    #4 Challengehauler, Jul 15, 2009
    Luckily Jason B. had to do an install this morning on a 430 Spider. Thank you Jason for letting me take spy photos while you did the work!
    Jason removed the front under panel for access to the back side of the front bumper.
    The tech uses spring clamps to position the skid plates to the bumper.
    He then uses a center punch to mark the bolt locations through the plates onto the bumper.
    Then he will drill the bolt locations with the plates in place.
    black gum is used on a wrench to hold the nut/washer. There is not a whole lot of room on the inside of the bumper to work with.
    He then uses a nylon wedge to create space where the bumper is a little closer to the front radiator frames (for wrench to clear)
    As you can see, these skid plates look like they belong on the car.
    Hope this clears up installation for you guys.
  6. Tarek K.
    Tarek K. F1 Veteran
    Sep 7, 2006
    9,602
    Cairo - Egypt
    Tarek K.
    Look good...........
  8. Ferrarista3
    Ferrarista3 F1 Rookie
    Oct 30, 2007
    4,530
    MC/UK
    Carlo
    Do you have skid plates for the 599?
  9. Challengehauler
    Jul 28, 2008
    1,242
    NE Connecticut
    DB
    We do not have any skid plates for the 599. We had 360 plates for a while, but they were not nearly as nice and functional as the 430 pieces.
  10. rjsmd
    rjsmd Karting
    Apr 20, 2008
    133
    Arizona
    Ron
    With the car off the lift, are these visible from any angle higher than the vantage point offered by kneeling on the ground? How thick are they? My car was lowered to Euro specs, but can still clear speed bumps without scraping. I have not actually measured the clearance I have in that situation, but wonder whether the addition of skid plates would cause me to start scraping in that situation.
  11. Challengehauler
    Jul 28, 2008
    1,242
    NE Connecticut
    DB
    They are 3/8" in thickness. We have another black spider out on the floor with these installed. The only indication that they are on the car is the in the wheel arch. You can see the tapered end just barely. If you walk around the front of the car you can't see them at all.
  13. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    IMHO skid plates should be mounted directly to the chassis and clearance through spoiler panels.
  14. Challengehauler
    Jul 28, 2008
    1,242
    NE Connecticut
    DB
    These are merely to protect the paint on the bottom of the bumper. They also spread the impact out so the bumper does not crack. The old 360 bumper plates protected the bumper, but were so small that the bumpers would still crack.
  15. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    On P 4/5 we mounted them as I've described and they can take a good high speed bottoming without damaging the car.
  16. Challengehauler
    Jul 28, 2008
    1,242
    NE Connecticut
    DB
    I am reducing the price of this item to $325.
    Cheers!!
    DB
  17. WJHMH
    WJHMH Two Time F1 World Champ
    22,638
    Panther City, Texas
    Preferred Pronouns: Lord/Master
    Excellent idea, I've always wondered why this wasn't done at the factory.
  18. miketuason
    miketuason F1 World Champ
    Silver Subscribed Owner
    Feb 24, 2006
    14,306
    Cerritos, CA.
    Can the skid plate be made out of aluminum?
  19. Challengehauler
    Jul 28, 2008
    1,242
    NE Connecticut
    DB
    Sure, they could be made out of just about anything. These are more like a teflon product They don't drag or promote friction as much as metal would. They would be able to take a better hit, and for a longer period of time.
  20. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    Premiere Motorsport also has skid plates for Scuderia,which ones are better ?
  21. BoardwalkFerrari
    Sponsor
    May 1, 2009
    50
    Plano, Texas USA
    Boardwalk Ferrari
    We cannot claim that ours are better than any other one. Ours work as intended without impeding on the "look" of the car.
    For the Scuderia and 16M these plates must be trimmed. They also do not cover the entirety of the Scuderia's under-bumper surface. They will on the other hand, cover the leading edge that gets most of the asphalts attention.
    Thanks for looking,
    BWF
  22. Jorgeassoc
    Jorgeassoc Rookie
    Sep 6, 2011
    8
    Los Angeles
    George
    are these still available for my f430 scud ? I am interested in a set thank you
  23. bart12
    bart12 Formula 3
    1,407
    Dallas/Westtexas
    MD Leo
    Is this price still available? Does this include installation already? Thanks
  24. SAFE4NOW
    SAFE4NOW F1 Rookie
    Sponsor Owner
    Aug 25, 2004
    4,069
    Dallas Texas
    Steve F
    Sorry for the late reply, but YES, we have a few sets still in stock!
    Steve
    steve@boardwalkag.com
  25. SAFE4NOW
    SAFE4NOW F1 Rookie
    Sponsor Owner
    Aug 25, 2004
    4,069
    Dallas Texas
    Steve F
    #22 SAFE4NOW, Apr 20, 2012
    Pricing from now until the end of May 2012
    If Installed at Boardwalk Ferrari Plano Texas:
    Labor $220.00
    Parts $150.00
    Tax $12.38
    or - Parts Only
    Parts $200.00
    Tax $16.50
    Shipping $TBD ( as needed )
    e-mail me at sfordham@boardwalkag.com or call for an appointment 972-447-5200
    S
    p.s. Retail Price has been $621.81 installed
  26. SAFE4NOW
    SAFE4NOW F1 Rookie
    Sponsor Owner
    Aug 25, 2004
    4,069
    Dallas Texas
    Steve F
    Bump. I'm going to let this deal run until they are sold out....
    We still have a few in stock!
    S
  27. SAFE4NOW
    SAFE4NOW F1 Rookie
    Sponsor Owner
    Aug 25, 2004
    4,069
    Dallas Texas
    Steve F
    Upcoming driving season Bump
    S
  28. Iceman23
    Iceman23 Karting
    Mar 21, 2013
    152
    Miami
    Ruben Salama
    Just curious any scud skid plates still available??
    Thank you
    Ruben
