F430 Challenge Headers | Page 4 | FerrariChat
Discussion in '360/430' started by Blackfspider, Oct 10, 2020.
  1. armedferret
    armedferret Formula 3
    Mar 24, 2018
    1,350
    Maryland
    Mark
    Random question as I become more edjumicated (and apologies if it's covered previously, just point me to where and i'll stfu ;) ), OBD-based emissions testing.....should one obtain a tune from, say, Trev, presumably this will still pass the plug test? No sniffers, just assume non-catted headers and (possibly) a high-flow setup from the glorious aftermarket world.
    The tune doesn't just leave them in a constant not-ready state, does it? It corrects for the change and makes it kosher?
  2. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,653
    San Jose
    dc
    Ask the tune maker. Non-ready will fail CA smog.
    armedferret likes this.
  3. Blackfspider
    Blackfspider Rookie
    Dec 6, 2019
    42
    Malaysia
    D
    I ordered too roughly gbp 1300 including free shipping...... now waiting.... out of stock factory. Hoping to get it in feb
  4. CoreyNJ
    CoreyNJ F1 Rookie
    2,550
    New Jersey Shore
    Here is a question. Are these challenge headers using the same thickness as MKII cats or MKI? I would hope if they were manufactured after 2008 they would use the stronger design and that all Ferrari did was not install the cats during assembly of the headers.
  5. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Contact Aldous at AV Engineering for any CELs such as air injection, secondary air, cat efficiency, cat monitors, secondary o2s, readiness, immobilizer delete, gated conversion, evap system removal, etc. They have all the necessary experience and tools to fix this properly.
    Many of the "coded out" aftermarket examples are quite scary. They are done completely wrong in a very hacked/botched way, the number of Ferrari's I've had to fix lately with botched mapping is unbelievable and quite sickening if you love the cars as I do. [emoji58][emoji2962]
    Many are not doing it in the proper way that Bosch would have done it. For example I've seen some tuners are simply hiding of the ecu light so you don't "see" the CEL, this is absolutely NOT the correct way to do it properly as the ecu software still sees the faults and acts accordingly as if the fault was there because it still is. By not properly deleting the components you can get into a whole heap of engine troubles longer term.
    If you just hide faults to remove components like air injection the underlying fault condition still exists which can lead to all kinds of unintended consequences and it can be bad for performance, throttle response and drivability, in the longer term too much fuel being injected for example on startup due to coding out air injection wrongly could lead to bore wash issues!
    O2 extenders are very hit and miss, I wouldn't recommend them as they are not a forever solution and can trigger a CEL under all kinds of situations such as cold starts, etc. Getting the software reprogrammed correctly is the only way to remove things properly.
    Sent from my VOG-L29 using Tapatalk
    NC-Ferrari, RANDY6005 and armedferret like this.
  6. RichardCH
    RichardCH F1 Rookie
    4,661
  7. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,653
    San Jose
    dc
    Thanks for the lead!
  8. RichardCH
    RichardCH F1 Rookie
    4,661
    Mine should hopefully arrive tomorrow
  9. ttforcefed
    ttforcefed F1 World Champ
    19,287
    Nice!
  10. ttforcefed
    19,287
    Wonder how these will sound with tubi 200 cats and 430 sport exhaust- that will be my setup ok my 07
  11. RichardCH
    RichardCH F1 Rookie
    4,661
    #86 RichardCH, Dec 24, 2020
    ShineKen likes this.
  12. RedTaxi
    RedTaxi F1 Rookie
    3,366
    New Zealand
    Glen
    Big one is O2 of course. The other 2 on my challenge headers are capped off as they were on my (euro spec car) old stock 430 headers. Small one I think is for a thermocouple that my car didn't have.
  13. RichardCH
    RichardCH F1 Rookie
    4,661
    ok thks looks like I need some caps then
  14. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Early F430s still used thermocouples, later specs eliminate them entirely for temperature estimation modelling which is more than sufficient for cat monitoring
  15. RichardCH
    RichardCH F1 Rookie
    4,661
  16. RedTaxi
    RedTaxi F1 Rookie
    3,366
    New Zealand
    Glen
  17. RichardCH
    RichardCH F1 Rookie
    4,661
    My 08 doesnt have them either, seems as the middle sized bung is M12
  18. ttforcefed
    19,287
    eurospares sent me an email saying the parts are still on order...fingers crossed
  19. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,653
    San Jose
    dc
    After reading all the O2 woes I decided to cancel mine since I am in CA.
  20. Blackfspider
    Blackfspider Rookie
    Dec 6, 2019
    42
    Malaysia
    D
    Anybody received their newly ordered challenge headers yet?
  21. ttforcefed
    19,287
    the left one is ready to ship but theyre (eurospares) still waiting on my right one
  22. Blackfspider
    Blackfspider Rookie
    Dec 6, 2019
    42
    Malaysia
    D
    Yup. In the same boat. Side by side.
  23. ttforcefed
    19,287
    Communication from eurospares has been excellent
  24. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    I love those guys!!
    RANDY6005 likes this.
  25. CoreyNJ
    CoreyNJ F1 Rookie
    2,550
    New Jersey Shore
    Has anyone finally got their challenge headers and installed them?
    If yes, was it on a later model 430? I think there are some holes to plug, so what did you do for that?
    Thanks,
    Cheers,
    Corey
