430 - F430 Brake replacement info & tips | FerrariChat
430 F430 Brake replacement info & tips
Discussion in '360/430' started by whatheheck, Apr 29, 2019.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    The usual, I’m posting to share knowledge and experience and hopefully help others.
    I’m not here to argue or debate with anyone as I have better things to do.
    So if this information has helped you, a simple thanks goes a long way.
    If you disagree or don’t like my approach its OK, its my car. You too can do what you like with yours.
    Thanks for your understanding.
    Now that we have that out of the way……………….
    • · My front brakes are due for replacement at 36K miles.
    • · Dealer quoted me $2K to do the front brakes parts and labor (new pads & rotors).
    • · I purchased OEM Brembo rotors and Stop Tech Sport pads for the front for less than $500.00.
    • · Brakes are super easy to do. Took me 1.5 hours to do the front left, half hour to do the right front.
    • · Done: I saved $1.5K, plus pride in workmanship. Now I can take my wife out to a nice dinner :)
    Details on attached pdf document.
    Hope this helps some of you.
    Dan
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
  3. f355spider
    f355spider F1 World Champ
    17,940
    Looks great Dan, nice job! Am I correct the aftermarket Brembo rotors do not come with painted "hats" or hubs like oem Brembo rotors, so you painted them to prevent rusting? Sounds like a minor trade off for the tremendous savings. :)
    whatheheck likes this.
  4. timwu12
    timwu12 Formula Junior
    919
    TX
    let us know how you like the StopTech sport pads. I'm in need of new front pads soon and have debated to go to these or stick with OEM brembo because of the potential for squeal.
  5. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Thanks my friend.
    Yes you are correct. The Brembo OEM rotors does not come with the hub pre-painted so I had to paint it myself.
    Like you said, a very minor inconvenience for a fraction of the OE rotor cost.
    Sent from my SM-G955U using Tapatalk
    f355spider likes this.
  6. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    I drove for 6 hours yesterday and I noticed no difference compared to OE.
  7. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    StopTech Sport Pads: No noise, no brake squeal, no warm up required for it to grab. Very similar to OE performance for a fraction of the cost.
    Dan
  8. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    552
    SW Suburbs of Chicago, IL
    Lawrence P.
    Thank you for sharing. Very, very useful.
  9. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    I want to add that I chose the "no brake pad wear sensor" type pad. So I removed the brake pad sensor and just tied it back away from the rotor.
  10. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    The StopTech Sport pad has a built in metal wear sensor.
  11. DefunctNeurons
    DefunctNeurons Formula Junior
    May 15, 2018
    412
    Alpharetta, GA
    Trevor
    Let’s make this a standard (mandatory!) intro to all helpful posts, shall we?!
  12. c6vette
    c6vette Karting
    Jun 4, 2009
    118
    St. Petersburg
    Great write up! I have just shy of 32k miles on mine and it is needing new rotors front and rear. I have been planning to do the exact same thing you did.
  13. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Thanks everyone for the appreciation.
    I had a request to add the part numbers & cost of the parts I used so here it is: Note that I have no affiliation to them.
    Part numbers & cost of parts used:
    • Brembo Rotors: 182606. Same part number for front and rear. You will need 4 each. About $100 each shipped from Superformance UK.
      Fast shipping. I got mine in 3 business days.
    • Brake Disc / Rotor Centering Screw: 104370. Need 4 each. Plus get 4 washers. $5.00 each. Same as above.
    • Brake Pads - StopTech Sport Pads 309 Series: 63-309-1053. Same part number for front & rear.
      I ordered mine from Zeckhausen Racing website. $82.00 a pair. You will need 2 sets. It comes complete with all hardware (pins, anti rattle bracket)
    • StopTech Stainless Steel Lines: 950.03501. Comes in pairs. You will need 2 pairs = $50.00 a pair.
    • ATE Type 200 Brake Fluid = Amazon. I bought 4 liters as its cheaper if you buy 4 cans.
    Hope that helps.
    Dan
    Xtro, Flea7 and f355spider like this.
  14. MJGinTX
    MJGinTX Karting
    Mar 30, 2019
    158
    Indianapolis, IN
    Thank you for the helpful write up Dan!! May I ask what paint you used - and how you applied - to the rotors?
    Matt
  15. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Hi Matt,
    Thanks for the appreciation.
    I understand Zinc paint works better but I just simply used a high temp caliper paint.
    https://smile.amazon.com/gp/product/B006ZLRBBO/ref=ppx_yo_dt_b_asin_title_o03_s01?ie=UTF8&psc=1
    Great question on application.
    First, using brake cleaner spray thorougly clean the entire brake rotor front and back.
    Then I used the cardboard box that came with the rotors, measured the size of the hub that I want painted, marked the center of the box by drawing diagonal line on each opposite corner to get the center, and using a compass I marked a circle, then cut a hole in the center of the cardboard same size as the rotor surface I want painted.
    https://smile.amazon.com/gp/product/B07D8JWYH2/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
    I then used the cardboard opening to paint the front and rear rotor hub. I wished I took a video but I found a similar approach in YouTube.
    Here you go.
    Hope that helps.
    Dan
  16. bellwilliam
    bellwilliam Formula Junior
    Oct 25, 2014
    398
    great writeup. I did almost the same thing (same rotors).
    Stoptech OEM is a great street pad, little dusty but no biggie. but definitely don't take it to track.
    I wouldn't recommend ATE200 for any type of track use. They are borderling ok in a 2,300LB 125whp Spec Miata, not on a 500hp car. at minimum, something like Motul 600/660, best is Castrol SRF, it is expensive, but it has the highest wet boiling point. which means you can go farther between fluid flushes.
  17. goto35march
    goto35march Karting
    Jul 23, 2009
    205
    amazing thread. question if i dont paint those rotors whats the drawback?
  18. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Unpainted hubs will rust.
  19. bellwilliam
    Oct 25, 2014
    398
    If you drive it in the wet.
    Anyway, spray paint takes may be a minute per rotor.
  20. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    A simple car wash will rust your brake rotors.
  21. shifter
    shifter Formula Junior
    625
    Danville, Ca
    Joe
    Thank you Dan, this is great information. I truly appreciate your contributions on this site.
  22. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Thanks for the kind appreciation Joe.
    I think if we all just contribute, share knowledge & experience and help each other out life would be much easier for everyone.
    Please stay safe and healthy.
    Dan
    Danedingerson and shifter like this.
  23. goto35march
    goto35march Karting
    Jul 23, 2009
    205
    I will paint. Question is sensors only in the front right? Rear there is no sensors?
  24. goto35march
    goto35march Karting
    Jul 23, 2009
    205
    i know ive said this but i really have to say THIS IS AN AMAZING WRITE UP. thank you so much!!!! lol
  25. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,646
    Silicon Valley
    I use these on my 360, too. Great pads.
