F40 Photos | Page 146 | FerrariChat
F40 Photos
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by TexasMike, Mar 5, 2006.
  1. mechaniker
    mechaniker Formula Junior
    May 30, 2004
    608
    Germany
    Sorry Joe, but I have to correct you here:
    The F40 body is not entirely made of fiberglass. Thats correct. But it is mostly made of fiberglass (by weight).
    The side panels for example (and all other external body panels) are made of a Nomex core embedded in two carbon/aramid hybrid fabric and a quite thick/heavy layer of different fiberglass layers on top. The orange stuff is gel coat. On top of that are the factory paint layers.
    https://www.ferrarichat.com/forum/attachments/img_0970-jpg.1607221/
    The structual composite parts (sills, bulkhead, ..) are made entirely different. Different carbon/aramid hybrid fabric, resin, manufacturing process, core material, no fiberglass, no gel coat.
    of2worlds and tomgt like this.
  2. Tenney
    Tenney F1 Rookie
    Feb 21, 2001
    4,285
  3. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    We are saying the same thing.
    mechaniker likes this.
  4. luigisayshello
    luigisayshello Karting
    Jul 9, 2014
    169
    It is a straight foward repair, the only challanges is knowing exactly what is the steel used in the different parts of the chassis and either have another chassis to copy from or have the drawings for individual parts.
    After the assement of what is not straight and all the small weld cracks are, it's a matter of fabricating the parts with the correct material and reweld straight all the affected parts, like a weldable lego.
    And to meet at an half point, some crashes are massive jobs, that involve basically a new chassis, this one looks far from that.
    P.S. Just to be clear tubular chassis is a type of design, it does not necessarly mean it is 100% made out of tubes.
    joe sackey likes this.
  5. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
  6. Fenz
    Fenz Karting
    Nov 8, 2018
    176
    Team Europe
  7. Boomhauer
    Boomhauer Formula Junior
    Aug 18, 2007
    881
    Milano - Italia
    Cardinal
  8. Barnyb
    Barnyb Karting
    Oct 1, 2014
    186
    Auckland
    A follow up to above vid.
    Frank Stephenson drawls over the F40 in Harry's Garage's garage.
    (both YouTube channels worth following)
  9. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    of2worlds and joe sackey like this.
  10. Dino2010
    Dino2010 F1 Rookie
    4,852
    Belgium
  11. of2worlds
    of2worlds F1 World Champ
    17,974
    ON
    CH
    Caeruleus11 and NürScud like this.
  12. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
  13. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    I guess they had run out of wheels and tyres that day and had to throw whatever was around onto the cars to keep them moving along the line
  14. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,067
    Troy, Michigan
    James
    how did they get 5 lug wheels on it?
    NürScud, joe sackey and of2worlds like this.
  15. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
  16. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
  17. Garretto
    Garretto F1 Veteran
    Sep 3, 2003
    5,068
    Bilbao, Spain
    Rodolfo Di Pietro
    Is this one of the prototypes or pre-production with 5 vents on the rear fender and window installed mirrors?
    Trivia: that prova plate was one of the choices for the Tamiya 1:24 scale model.
    of2worlds likes this.
  18. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
    Yes, 76354 is an early prototype.
    That memorable day it was used for a comparison against a white Porsche 959.
    Marcel Massini
    Caeruleus11, of2worlds and joe sackey like this.
  19. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
  20. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    That is a bloody good point, I had not thought of that.
    Often the wheel locating points on a centre lock wheel hub are the same pcd as the standard lug pattern on a normal wheel (5x108 in the case of Ferrari), so the 5 holes would probably line up with those as a temp fix but I doubt the centre bore hole is big enough on a 348 wheel to allow the central hub spline of an F40 to pass through it, maybe they had some bored out ones to use as transport wheels.
  21. Marcel Massini
    Honorary
    Mar 2, 2005
    24,860
  22. ttforcefed
    ttforcefed F1 World Champ
    19,251
