F355 Updated Throttle quadrant | FerrariChat
Discussion in '348/355' started by 275GTB, Feb 20, 2017.
  1. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,911
    London
    Mark McCracken
    Hi, just dealing with the classic sticky throttle problems on my 355 - going through all the usual fixes as we speak.
    I have read in several threads that there is an updated quadrant linkage for the throttle bodies. Can anyone tell me how you distinguish between the updated and non-updated quadrant?
    many thanks
    Mark
  2. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,911
    London
    Mark McCracken
    the car is a 1997 355 5.2 motronic
  3. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    #3 MAD828, Feb 20, 2017
    On my 1995 the bel crank has been modded to update it.
    Basically the bell crank angle is slightly changed so that there is less angle the curved part that holds the throttle cable is almost in line with the two mounting points.
    This pic should help. The one on the left is the old style.
    ShineKen likes this.
  4. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Have not heard about this mod before.
    Was this mod installed on any 355 from the factory.....if so what year?
    For those that installed this....is this mod effective?
  5. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Early F355s had it, not sure what year model the change occurred. My car was modded at the Ferrari dealership the bell crank pulled apart and spot welded in place to mimic the updated version, a tech I know said this was common practice.
    It's a well known mod in the circle of techs with experience of the F355. For the record my F355 has no sticky throttle but I have driven a car with it and it's down right scary!
  6. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    cool....will have to have a look at mine
  7. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Elliott - great info. I'll check my 95. Is this the part that is referred to as a quadrant?
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #8 Dave rocks, Feb 20, 2017
  9. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    Happy to help Dave. This is known as the quadrant. Your 95 one whilst super clean and looking great is the old style, you can mod that one as mine has been done, as the updated part isn't exactly cheap.
  10. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Now you know where the extra 5 hp comes from ;-)
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yeah, that's been stripped, bead blasted, tumbled and replated ;)
  12. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,911
    London
    Mark McCracken
    I am sure i read somewhere that the factory adopted the mod on production cars from 1997, but not sure when in that year. Can't even remember where i got that info.
    I think a lot of UK cars were updated early on in their life, while in the main service network.
    I spoke to one of the head Ferrari technicians down the garage, he does all the 355's that come through, he commented that he hasn't seen the old style on any UK cars for years.
  13. Rifledriver
    33,997
    Austin TX
    Ferrari calls it a transmission lever and the rest of the world might generically call it a bell crank. Calling it a quadrant makes zero sense and is rather misleading.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    You got that right :) For the last 4 years I've been trying to figure out WTF is this quadrant that people talk about :D
  15. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    I agree and referred to it as the bell crank in my first post. Even the tech at the local Ferrari dealership referred to it as a quadrant not sure how this has eventuated.
    Do you happen to know when Ferrari updated this bell crank?
  16. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    My prior 95 was the 15th to come to NA so it was a very early car. No records of this part being replaced and it did not have any sticking issues.
    P/N: 161826 says valid until Assy number 28137
    P/N: 175234 says valid from Assy number 28138
  17. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,655
    CT
    John Kreskovsky
    Rotates over approximately 90 degrees, thus a quadrant?
  18. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Anyone know who could reliably mod the old ones to the new angle? It says welding is involved. Is this part all one piece (looks like it)? Does it have to be broken apart, the 2 "ears" rotated to the new position and re-welded?
  19. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    #19 MAD828, Feb 20, 2017
    Here is a picture of my modified one.
    It isn't pretty but looks to have been separated and re welded to the new position which changes the cam angle to mimic the updated part. Last I checked the updated part on Ricambi was around 600 USD so this must have been a mod done at the dealership without the cost of replacing the part.
    308 GTB likes this.
  20. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    The bell crank (OEM) is a welded assembly. Cutting it apart are re-welding would not be difficult
    I passed on an entire assembly for like $25.00 a year ago coz I just did not need it. Seems they go for around $300ish on ebay
  21. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    This would be the way to go Dave. I had purchased new roller bearings for it and for the throttle pedal, one day will pick up a used updated bell crank and get it looking pretty like yours!
  22. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    814
    BUMP
    I have the old style bell crank and my pedal is very responsive. Can someone comment on the before and after with this upgrade?
  23. MAD828
    MAD828 F1 Rookie
    2,540
    Elliott Caras
    If there is no jerkiness or sticking of your throttle pedal then you won’t notice any difference modifying it.
  24. Carmellini
    Jul 16, 2019
    814
    After driving a few more miles, I can't say I have any sticking or jerkiness, but on initial depression I can feel what I would call a flat spot. It is not much of a nuisance as I have gotten use to the feel and have learned how to drive without any noticeable issue,,,,,,,,BUT.....there are times when I can feel that flat spot
    and wonder is that what the newer style lever corrects?
  25. audi_328
    audi_328 Formula 3
    2,451
    NH
    Audi
    Not sure about the flat spot you feel, but if you have the sticking throttle/jerky issue, you'd know it; that's what the updated quadrant is supposed to correct. (I bought one from Eurospares last fall, haven't gotten around to installing it yet).
