F355 Tire Sizes | FerrariChat
F355 Tire Sizes
Discussion in '348/355' started by Robb, Dec 3, 2014.
  1. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,196
    Robb
    So let's talk tire sizes.
    Ferrari standard tire sizes for the F355 Stock Magnesium Rims:
    Front
    225 / 40 ZR 18
    Rear
    265 / 40 ZR 18
    Ferrari standard tire sizes for the F355 Challenge rims:
    Rain Tire
    Front
    225 / 40 ZR 18
    Rear
    265 40 ZR 18
    Racing Slicks
    Front
    245 / 645 x 18
    Rear
    305 / 645 x 18
    What other sizes are people running on their stock rims and challenge rims and at the track?
    Any Photos showing the differences.
    It was suggested to go up to 235's on the front for the challenge rims and maybe split the difference on the rear. I always like to see lots of info and suggestions.
    Thanks.
    Robb
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Run factory tires, Robb. Pininfarina knew what they were doing....
    PS, remove the spacers too ;)
  3. Robb
    Robb Moderator
    Feb 28, 2004
    14,196
    Robb
    I agree on the standard rims. I'm running Bridgestone's (or Michelin's) at those sizes.
    And I don't have spacers. I promise. :)
    I am curious about rubber for my new challenge wheels...
    Robb
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,631
    Ferrari (not PinninFarina) knew what it was doing.
    Spacers are for people who do not understand that the justifiable suspension makes the spacers unnecessary.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Pilot sport Robb.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Really? Who was the coach designer? I'm sure it was a collaborative effort.
  7. Robb
    Robb Moderator
    Feb 28, 2004
    14,196
    Robb
    My mechanic worked as a designer at Ferrari on the F355 suspension components - He does not recommend spacers.
    Robb
  8. Robb
    Robb Moderator
    Feb 28, 2004
    14,196
    Robb
    Those sound good.
    Robb
  9. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    Pilot super sport.
    235 front
    295 rear
  10. Robb
    Robb Moderator
    Feb 28, 2004
    14,196
    Robb
    Now that's what I was hoping to see! Thanks.
    Robb
  11. Subarubrat
    Subarubrat Formula 3
    Apr 1, 2009
    2,072
    VA
    Scott
    +1 for 235/295
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    SoCal LA/OC/New Mexico
    Tim Dee
    +355
    On challenge rims no spacers
  13. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,677
    Lake Villa IL
    Would you mind double checking the rear? PSS run wide, yours look like a 265.
  14. Robb
    Robb Moderator
    Feb 28, 2004
    14,196
    Robb
    Great Tim and Scott. Thank you for the vote.
    Robb
  15. 355dreamer
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    #15 355dreamer, Dec 3, 2014
    You are correct. On my current car, I have 265 rears. When I had my Barchetta GTB, I ran 285s with the challenge wheels, not 295s.
    Sorry for the incorrect info.
  16. group77racing
    group77racing Formula Junior
    Sep 5, 2006
    453
    Often Imitated
    Never Duplicated
    #16 group77racing, Dec 3, 2014
    225/45/18 front 26" tall- size up one aspect ratio
    275/40/18 rear 26.7" tall- 10mm wider
    this combo adds a small amount of diameter front and rear to fill up the wheelwell with the addition of 10mm more tread in the rear, since 265's are too small for a 10 inch wheel which is actually 11 inches overall.
    I 4 corner scaled and set the new ride height after the new tire combo was put on, rides and handles great.
    you can see the difference. The sun angle is casting a bigger sidewall shadow on the top pic, but you get the idea by looking at the diameters and even wheelwell fitments.
  17. Challenge
    Challenge Formula 3
    Sep 27, 2002
    1,997
    PA
    Kevin
    I'm confused. Why don't you ask him if he recommends tinkering with tire sizes instead of strangers online?
  18. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,817
    Richmond
    Pete
    I have 245 front, 275 rear Conti's on my factory rims and 235/295 Hoosiers on my challenge rims. Pics are scattered through the forums, pic in my profile has older Dunlop Z1*'s in 235/275 iirc.
  19. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    You notice any difference in tire size when tracking? One grip better but slower on the straits?
  20. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,817
    Richmond
    Pete
    Not really, I just like a little more front end grip so went with the larger front tires in the Contis. On track they gave slight understeer trail braking into the turns and slight throttle on oversteer with 35psi front, 33 rear, just the way I like it. I could attack pretty agressively under braking without worrying about the rear coming around and steer with the throttle a bit on exit. Biggest issue was the brakes overheating and fading after 4 or 5 hard laps so I didn't bother with the Hoosiers as they'd overwhelm the brakes even more quickly. I'm hoping to get some track pads and try again in the spring with the Hoosiers, so we'll see. In autox I've gotten the balance virtually the same with the Hoosiers if/when I get the heat into them using similar tire pressures, so not sure the sizes matter as much as getting the tire pressures correct. I have some autox runs on youtube under the same user name, both in the rain on the contis and in the dry on the Hoosiers and you can see the car behavior is virtually the same, and the results were as well (5th or 6th out of 70 or 80 cars) and first in my class. If I can't get the heat into the Hoosiers, it doesn't go as well as I really need A6's for autox use, but I use that more for testing and getting a feel for the car as opposed to trying to outright win. Feel under braking is better with the Hoosiers, don't think that's related to the size at all but the tires themselves. I felt the same way with the Z1*'s compared to the Contis, so I think the contis just don't have quite the same feel. No biggie, though, they're unbelievable in the wet which is why I got them over z2's or other similar tires.
    In short, I don't think 10-20mm up or down will effect handling that much, at least not outside the parameters of tuning with tire pressures. Maybe you can gain a few tenths here or there, but unless you're seriously racing or time trialing I'd just go with what you prefer visually, take it to an autox and tune your pressures to get the handling where you want and not sweat it.
  21. Robb
    Robb Moderator
    Feb 28, 2004
    14,196
    Robb
    I guess I like this group of strangers. But fair enough, I'm seeing him Friday.
    Robb
  22. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,629
    Tim Dee
    Thanks much !!! I think we both like old school handling, a little tail happy when tickled
  23. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    #23 jimmym, Dec 4, 2014
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Nice garage, Jim. Now paint that floor :)
    PS, what is the maroon car peeking thru?
  25. Robb
    Robb Moderator
    Feb 28, 2004
    14,196
    Robb
    Jim. That looks good. Great car(s).!
    Robb.
