F355 Paddle Shifting Logistics - Please Help. | FerrariChat
Discussion in '348/355' started by SoftwareDrone, Jan 20, 2004.
  1. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,536
    San Jose, California
    A long time NSX owner (http://northwest.nsxca.org.mike.html) I now have F355 fever. However, before I purchase one, I need more information on the F1 transmission. I have sent many e-mails to many
    people and have gotten nowhere. I really need to hear from experienced F355 F1 owners to answer some logistics questions. Here are a few of the many scenarios to which I cannot get clear answers
    to.
    Scenario #1.
    You are sitting at a stoplight with your foot off of the brake and your foot off of the gas.
    What is the Status of the Transmission and Clutch (STC)?
    You put your foot on the brake. STC?
    While leaving your foot on the brake, you rev the engine to, say, 3500 RPM. What happens?
    Scenario #2.
    You are in 3rd gear, at 40 MPH. You must shift the car into neutral using both of the paddles simultaneously (don't ask why, it's purely hypothetical). Now you are rolling at 40 MPH with the engine at idle. How do you get the car back into 3rd gear without a mechanical overrev?
    Scenario #3.
    While at a stoplight with your foot on the brake only, you shift the car into neutral, rev the engine to 3500 RPM and shift into 1st without taking your foot off the brake. What happens?
    Scenario #4.
    Can you bump start the car with a dead battery? (tricky question!)
    Scenario #5.
    What are the logistics of starting and stopping the car on a steep hill?
    Does anyone have clear answers to any of these questions based on actual experience?
    Thanks!
  2. AnotherDunneDeal
    AnotherDunneDeal F1 Veteran
    Jun 2, 2003
    6,109
    N.Richland Hills, Tx
    James Dunne
    Scenario #1
    Stopped at the light at idle and foot off the brake and gas.
    After a couple of seconds the transmission will shift into neutral and yu will have to put your foot on the brake and put the car back into first gear using the paddle.
    If you keep your foot on the brake while stopped, it will not drop into neutral but will stay in gear.
    Rev the engine to 3500 with your foot on the brake. First off, please do not do this. In this transmission it is very easy to fry the clutch and this is one of the easiest ways to do it. Power braking is not recommended.
    Now someone else take the next one........................
  3. redhead
    redhead F1 Rookie
    Dec 26, 2001
    4,869
    ~Red~
    Scenario #2.
    The TCU, Trans control Unit will select the "smartest" gear to be in. If you are doing 40, it most likely will go up to 5th or 6th gear. Then you can right paddle down to where you would perfer to be. It will never go back to first unless you are stopped.
    PS....I do this while driving all the time, like rolling up to a red light and then it changes........click the paddle and then downshift to where you want to be RPM wise.
    Someone taking the next?
  4. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    #2 It will return the car to whatever gear it was in. Assuming speed is constant. My dealer showed me this one.
    #3 Don't do it. At the stoplight alway get the car into neutral.
    #4 Never had a battery problem. So I don't know.
    #5 It takes a bit of quick footwork with a foot on each pedal. Pretty much learn it while driving in Seattle traffic.
  5. Willis360
    Willis360 F1 Rookie
    Aug 4, 2001
    3,928
    Redmond, WA
    Willis H
    Yes, it basically select the gear that will not allow overreving. My dealer did it in my car at er..well over 40MPH.
  6. pino
    pino Karting
    Nov 1, 2003
    208
    South Central PA
    You cannot bump start the car because you have no physical way of engaging or disengaging the clutch. It is all done electronically. No juice, no clutch or shifting action. If the car is stuck in gear with this scenario, Ferrari has made provision for disengaging the clutch by means of a manual pump that can be quick connected to the hydraulic system of the clutch. Big $$$ special service tool.
    Starting off on a steep hill can be performed by slight left foot braking, positive use of the accelerator to avoid excess clutch slippage, or starting off in second gear instead of first. The 360 F1 system actually has a software program better designed for stop and go traffic and starting off on a hill.
    You may park the car in gear, but the car must be started in neutral.
    I don't do it because this is stressful to the system if there is any pressure on the gears such as the weight of the car on a hill. Plus, if for some reason you cannot select neutral, you cannot start the car.
    Hope that helps.
