F355 Outside Gearbox Gasket | FerrariChat
Discussion in '348/355' started by Suffyk, Mar 3, 2021.
  1. Suffyk
    Suffyk Formula Junior
    May 25, 2012
    284
    Hi, All.
    I recently had some interior pieces redone. I want to reinstall them, but realized that I'm missing part number 159389:
    https://www.ricambiamerica.com/159389-gasket-spacer.html
    Everyone seems to be completely sold out of this part, and there is no solid ETA.
    This may be a silly question, but do you think I can make a 550 one work:
    https://www.ricambiamerica.com/168955-gasket.html
    I realize reverse is in the opposite location, so will need to make some adjustments...
    Alternatively, what about just buying something like this and cutting it to make it work:
    https://www.mcmaster.com/nitrile-rubber/oil-resistant-high-temperature-buna-n-rubber-sheets/
    Suggestions / thoughts are welcome... Do not want to put things back without the gasket -- apparently doing so is what causes the plastic surround to crack.
    suffyk
  2. carnutdallas
    carnutdallas Formula 3
    1,683
    Dallas Burbs
    Rob
    Dang that sucks. That gasket/spacer is critical for proper operation and lever adjustment. It also protects the console plastic. My local dealer had the last one I bought. I thought Dave at Sticky RX made them?? That could be wrong? I thought someone was making them??
    Not sure you can make 550 work? Could maybe flip around, cut and glue? Will watch this to see what you do. Good luck. Another part I need to buy and hoard, LOL.
  3. MAD828
    MAD828 F1 Rookie
    2,539
    Elliott Caras
    Have you tried superformance uk? They list it.
  4. Suffyk
    May 25, 2012
    284
    carnutdallas likes this.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    I think I have one if you wanted it.
    Suffyk likes this.
  6. Suffyk
    May 25, 2012
    284
    And... that's why this forum is the best. PM sent!
  7. Suffyk
    May 25, 2012
    284
    emac, ShineKen and carnutdallas like this.
  8. kenneyd
    kenneyd Formula 3
    1,944
    NE FL
    Ken
    Weird, I just bought a 159389 like 6mo again from ricambi for like 20 bux.
    Kind of scary more of these needed items are going NLA
  9. 0.0.1.99
    0.0.1.99 Formula Junior
    Jan 14, 2012
    423
    Carolinas
    Ken
    That part seems ideal for banging out on a 3d printer. The quality of the surface finish would not matter at all. If I had the printer I would make them for free.
  10. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    If someone would make the file, I will 3D print them!
  11. 0.0.1.99
    Jan 14, 2012
    423
    Carolinas
    Ken
    That just involves taking measurements and building it in Solidworks or Sketchup? I will call some dealers and create the file if I can locate the part.
  12. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    I 3D print daily, but I have no experience using those programs. Everyone says they are pretty easy once you get the hang of it, I just haven't made the time to learn.
