F355 front mesh grille | FerrariChat
Discussion in '348/355' started by ShineKen, Oct 13, 2016.
  1. ShineKen
    ShineKen Two Time F1 World Champ
    20,199
    Southern California
    Nostradamus
    #1 ShineKen, Oct 13, 2016
    I believe this is the first time I've seen this on a street car. This car is located in HK. I've seen pictures of it on a 355 race car a few times. Michelotto product? Anyone have an idea of a source? I am looking for something like this to compliment my challenge side grilles.
    -K1- likes this.
  2. PeteyP
    PeteyP Formula Junior
    May 3, 2005
    830
    NJ
    Petey
    Im sure that can easily be fabricated for very little effort.
    Just some mesh bent and cut to fit the grill, Add screws in factory location and call it.
  3. ShineKen
    20,199
    Southern California
    Nostradamus
    #3 ShineKen, Oct 13, 2016
    The hard part would be the outline the mesh is most likely welded to to keep it's shape and give a more finished look, which this 355 has. I agree, can be done if someone is willing to do it. Just less headache if there's already a source.
  4. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    SoCal LA/OC/New Mexico
    Tim Dee
    I have some mesh may be cool to try
  5. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    I'm thinking the same thing
  6. tres55
    tres55 F1 Rookie
    3,573
    Canada
    make it out of the same grill material as the rear challenge grill. would look great
  7. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,492
    Tucson, Arizona, USA
    Robb
    Should be cool to see what you come up with. I would think that using the same material as the rear challenge grill (in the front) would be difficult to keep clean. A bigger pattern like in the 599 gto would be a better selection.
    Robb
  8. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    On my long list of things to do
    Upcoming year I may be a busy little boy :)
    ShineKen likes this.
  9. ShineKen
    20,199
    Southern California
    Nostradamus
  10. ShineKen
    20,199
    Southern California
    Nostradamus
  11. ShineKen
    20,199
    Southern California
    Nostradamus
    how’s that mesh lookin :)
    SoCal1 likes this.
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    Thanks for reminding me I was wondering why I had that mesh, thought it was for a truck project
    taz355, Ferrarium and ShineKen like this.
  13. ShineKen
    20,199
    Southern California
    Nostradamus
    Lol. You'll need bigger pieces than that. Are those samples? Im diggin the square mesh to match the challenge door mesh.
  14. ShineKen
    20,199
    Southern California
    Nostradamus
  15. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Properly known as "Hardware Cloth."
    Yes, that will effectively keep tire marbles from being ingested into the brake cooling ducts.
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    Tim Dee
    Yes samples
    Have them in black also.
    Just got a few new tanks of welding gas I may need to crack open
  17. ShineKen
    20,199
    Southern California
    Nostradamus
  18. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,852
    Lake Villa IL
    Where are you guys sourcing the stainless mesh?
  19. ShineKen
    20,199
    Southern California
    Nostradamus
    Try customcargrills.com. They have a selection of stainless steel and aluminum mesh. I actually ordered a sheet of the square mesh in stainless steel.
  20. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
  21. ShineKen
    20,199
    Southern California
    Nostradamus
    The customcargrill one is sturdy. Keeps its shape. Can't even bend it let alone roll it :).
  22. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    Secure the hardware cloth to the back of the stock grill and you'll have a functional, esthetic, and cheap barrier to keep tire boogers out of the brake cooling ducts.
    It's a good idea for the track. It's not really necessary for the road.
    I use a heavier gauge hardware cloth for the door and wheel well vents and still a big tire marble at Sebring earlier this year managed to rip through the passenger side wheel well screen taking off two fan blades and damaging the radiator core. There was lots of rubber on the track those two days because of the Porsche Club Races practice sessions being held at the same time.
    If you want to swap out your stock front grill, then customcargrill.com is the way to go.
  23. ShineKen
    20,199
    Southern California
    Nostradamus
    "Secure the hardware cloth to the back of the stock grill and you'll have a functional, esthetic, and cheap barrier to keep tire boogers out of the brake cooling ducts."
    That's actually a good idea. Never thought of that.
    The challenge door mesh didn't work out for you?
  24. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    The original Challenge door mesh was swapped out years ago, probably when my car was raced, for heavier gauge screens. These screens get hit and damaged frequently by track debris and have to be replaced periodically. They're fabricated at the shop.
  25. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    What's truly amazing is that the flimsiest fiberglass parts on my F355 Challenge, the clutch heat shield and the four brake cooling intakes, have held up well since first installed in 1995. :)
