How cheap are we talking from waytekwire? I have purchased those Bosch relays online for $7 or $8 with free shipping.
355 Spider hydraulic reservoir for the top. $623 from Ferrari. $57.24 from Audi Part number: 8G0 898 101 Available from SunsetPorsche. Luke is the parts guy I usually talk to 800.346.0182 who quoted me the $57.24 price. (I have no affiliation with these guys, other than that I've been ordering Porsche parts from them for a long time) It comes as a complete kit, just like the one in the yellow box. Includes the O-ring and new torx screws with loctite on them. I did need to peel the sticker off and rotate it 45 degrees. I installed it tonight. It is in every way, identical to the original (once you rotate the sticker) Image Unavailable, Please Login Image Unavailable, Please Login
The "Stop" switch in my climate control panel broke, does anyone have a replacement switch for these? Thanks, Michael
I can't recall what they are off but they are common to something much cheaper. I had one and it cost £230 fitted (needed to reuse the Ferrari clutch but the rest was a straight bolt in). Have a dig around bt don't pay Ferrari prices.
Throttle position sensor Bosch part# 0280122044 (Ferrari part# 142434), same as found on a 1996 Saab 900 (non-tubro) 2.3liter 4 cylinder. Cost me $125 each, but I have seen them for sale on Amazon and Rockauto for around $98 for the Bosch sensor. Here are some other numbers I found that correlated to that Bosch part number. ALFA ROMEO: 605493590 BOSCH: 0280122004 0280122008 0280122001 CITROEN: 1628L1 72408124 96038938 FERRARI: 142434 FIAT: 60549359 7637025 GM: 826924 90323839 HYUNDAI: 3517022001 3517022010 KIA OK: 01118911 PEUGEOT: 1628L1 72408124 96038938 PORSCHE: 94460611600 94460616600 RENAULT: 7701047921 SAAB: 885719 8857915 SOLEX: 72408127 VOLVO: 1336385 3450030 I did not look any further into the rest of those number (except for the Ferrari part number and that one is good), so do your due diligence before you dive in. These are also the same TPS found on: 456 GT (1995 - 1997) 456 GTA 1997 550 MARANELLO 1997 F355 BERLINETTA 1996 F355 GTS (1996 - 1997) F355 SPIDER (1996 - 1997)
Wouldn´t anyone happen to know an alternate source for the inner rear view mirror? I´m planning on a project that involves taking apart the mirror and I would like to have some practice/spare junkyard mirrors, I´m assuming that this mirror is also used in other cars from the FIAT group (lots of them available in the yunkyards)
In addition to the SAAb heater valve actuator/motor as a replacement, the BMW e30 uses the same actuator. The unit is from the E30 (3 series 1982-1889) It is item marked 12 on the diagram. http://www.realoem.com/bmw/showparts.do?model=1003&mospid=47312&btnr=64_1719&hg=64&fg=35 BMW PART No. 64111380275 Available on ebay at roughly $80
Just as a follow up...the part is "currently" available on Ebay as a used part for around $80 from a single seller in the UK, but the typical online price is more like $355 to $400 for a new one.
I didn't even knew about the existance of this pump... and i've owned my car for almost three years and 10k miles... where is it? what does it do?? forgive my ignorance
One of the tonneau chrome pulls broke on me. Found them at http://www.eagleday.com/tefage.html. They are the exact replacements. Tenax 33 GHE Made in Germany Dont forget to buy the little tool to make life easier. They are a quick fix, though a little pricey. No affiliation, yada yada
Got this info from Erick's thread: Carpet retaining clips are no longer available from Ferrari. These look identical to the originals: Long Black Turnbuckle Fasteners - TBLB
It's a "recirculation pump". It aids in drawing coolant from the rear of the car. Seems the O ring is prone to fail.
This part is NLA. F7192 (Actually a Victor Reinz part number) has been discontinued. Here are the new, applicable part numbers: (I just bought these yesterday. My car is a 2.7) Ferrari # 159914 = Fel Pro 60201. (This is the passenger side Y-pipe to header gasket) Ferrrari # 159922 = ????? (Did not buy this one, as mine was perfect. Driver side Y-pipe to header) Ferrari # 154984 = Fel Pro 60155 (Two are required..this is the header to primary cat gasket. This part works for all F355's) Ferrari # 159906 = Fel Pro 9587 (This is the Y-pipe to spacer/bypass valve gasket. 2.7 Only) FYI: Fel Pro is the same as Federal Mogul. Made in the US.
It was previously reported that Porsche 930 CV boots were a match for the 355, but they are not, at least for the '99 355 they are not. The Porsche boot can fit, but it is half assed and will leak. Both boots are made by Lobro, but have different end designs. The Ferrari part has a flat lip at the end, where as the Porsche part is a beveled end. If you are going to the trouble of taking the axles off to replace the boots, get the right part.
Tried to search and could not find a cross reference for the speed sensor # 149095. If anyone knows of a replacement please let me know, thanks.
I just fitted these coil packs to my 97 355, working well so far Ignition coil | Meat and Doria Quite a bit cheaper than the Bosch ones, at under £30 rather than over £100. Thought they were worth a punt at the price. It seems to me that anything electrical in the engine bay is pretty much a consumable anyway given the temps in the bay.
I don't know if this has been posted in this thread or not but, The 360 pump retrofit for the 355 F1 shifter is, Denso Manufacturer Part Number:MD064100-9011, BM.0019748.C Ferrari Part Number :247223-M I also found this info for the 360 F1 pump: Part Number 178757 Maserati Updated F1 pump Part Number 213264 , 000213264, 5-349-B New superceeded Part Number AE1223.07 Magneti Marelli Part Number BM.0004708.E, DR.0077396.A T-2074-24343 F1 pump Part Number 51736315 Year 03-07 Description Lower PAS Hydraulic Pump Manufacturer Part Number MS064100-9010, MS064100-9060, MS064100-9061 Voltage 12 V Manufacturer: Denso, Magneti Marelli Applications BMW 6 speed SMG : M3,M5,M6 LAMBORGHINI Gallardo and Murcillago LP640 Maserati :4200 Spyder, Coupe, Quattroporte,Grand Sport 03-05 Maserati 4200 Spyder, Coupe, Quattroporte Maserati Grand Sport Ferrari 360 Challenge Stradale Ferrari 575M Maranello 2000- Ferrari 360 Challenge Ferrari Enzo Ferrari 365 GT 2+2, 365 GT4 2+2, 365 GTC4, 400 GT, 400 Auto, 400 GTi, 400i Auto Ferrari 612 Scaglietti 2004- Alfa Romeo GT, 164, 156 ALFETTA, 147, 159, GTV 33 155, 166, 145/146 2,0L 16V 2006- Fiat Panda 1.2 8v Semi-Auto Electric Gear Actuator
Important info on Bosch part #0 390 721 006! These are discontinued, and you can source them from Saab used parts dealers (from a model year 2000 Saab 9000) -------------------------------------------------------------------------------- There is an important sub part number to this item, I just learned today. There is a number in a circle "944" after the main part number Bosch part #0 390 721 006 It is important you get the one with the "944", if you get the one with "917" the operation is reversed, and it won't work! I got mine from a Saab breaker parts dealer and he had both. I got lucky the first time, and it worked perfectly. Today, I was helping a friend fix his, and got one with "917" on it, and it worked in reverse. We called the Saab specialist and he admitted there are different versions and he was at a loss to know which was which, but when we checked my car, my old broken one, and the one we removed off my friends car, all had "944" in a circle after Bosch part #0 390 721 006. Both the 917 and 944 are used on the Saab 9000, so very important to get the right one.
