F12 Retrofit rear wheel steering ? | FerrariChat
Discussion in 'F12/812' started by RichardCH, Dec 29, 2019.
  1. RichardCH
    RichardCH F1 Rookie
    4,661
    Ferrari were a bit late to the game with 4 wheel steering, can a standard F12 be retrofitted with the F12TDF rear wheel steering ?
  2. 4_Eff_Sake
    4_Eff_Sake Formula Junior
    Jul 30, 2016
    761
    Australia
    Scott
    I would seriously doubt it
  3. LVP488
    LVP488 F1 Rookie
    Jan 21, 2017
    4,839
    France
    Everything is technically possible if cost is no object; but the F12 TdF was a serious work by Ferrari (not a mere body kit and engine tuning as we've seen for other VS ;) ) so I doubt the transformation would be easy.
    It's certainly less expensive to buy a used 812 than to transform an F12, which may be less expensive than buying a TdF but still hardly making sense.
    Caeruleus11 likes this.
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    It would cost more than just purchasing a used F12 Tdf to engineer a 4 wheel steering retrofit for an F12. I doubt that you could find anyone that would be willing to even try.
    Brian Brown
    San Francisco Motorsports
  5. 4_Eff_Sake
    Jul 30, 2016
    761
    Australia
    Scott
    Actually, I may have been too hasty in this response.
    @Eilig may be able to comment
  6. Eilig
    Eilig F1 Rookie
    3,494
    Cavallo
    Partial list of mechanicals (major components only):
    2 x REAR SHOCK ABSORBER 319243 2050 €
    2 x REAR UPPER CONTROL ARM 802 €
    REAR LH LOWER CONTROL ARM. 329243 682 €
    REAR RH LOWER CONTROL ARM. 329244 682 €
    REAR RH STEERING ACTUATOR. 329655 4382 €
    REAR RH STEERING ACTUATOR. 329653 4382 €
    WIRING HARNESS 7000 €
    SUSPENSION ECU 323930 654 €
    COMPL. LH FRONT HUB CARRIER 314463 1362 €
    COMPL. RH FRONT HUB CARRIER 314464 1362 €
    COMPL. LH FRONT UPPER ARM 295788 885 €
    COMPL. RH FRONT UPPER ARM 295789 885 €
    COMPL. LOWER LH FRONT ARM 295790 885 €
    COMPL. LOWER RH FRONT ARM 295791 885 €
    HYDRAULIC UNIT 315049 2385 €
    For proper clearances with larger front wheels and rear steering, you'll need to convert to Tdf front fenders and rear quarter panels. In order for those panels to fit, you'll basically need to re-skin the entire car, as the ONLY panels shared between F12 and Tdf are roof panels. Partial list (major components only):
    COMPL. REAR RH FLANK 86994611 6509 €
    COMPL. REAR LH FLANK 87005711 6509 €
    COMPL. RH FRONT FENDER 87086711 3210 €
    COMPL. LH FRONT FENDER 87086911 3210 €
    RH AERODYNAMIC FAIRING 87191910 4637 €
    LH AERODYNAMIC FAIRING 87191610 4637 €
    COMPL. FRONT BUMPER 7943010 17862 €
    COMPL. REAR MESH 87943310 28747 €
    COMPL. DIFFUSER 87436900 6970 €
    RH DIFFUSER HATCH 87436610 1515 €
    LH DIFFUSER HATCH 87436810 1515 €
    CENTRE DIFFUSER HATCH 87436510 2271 €
    DIFFUSER ACTUATOR KIT 2500 €
    RH QUARTERLIGHT GLASS 87095800 778 €
    LH QUARTERLIGHT GLASS 87095900 778 €
    REAR SCREEN 87097000 1395 €
    COMPL. LH OUTER SILL COVER 87532900 6812 €
    COMPL. RH OUTER SILL COVER 87533000 6812 €
    RH HEADLAMP 297789 5776 €
    LH HEADLAMP 297791 5776 €
    Net, would be easier to just trade your F12 on a Tdf.
    Bundy, j09333, 4_Eff_Sake and 2 others like this.
  7. Solid State
    Solid State F1 Veteran
    9,586
    Maximus Decimus Meridius
    Good work. My F12 steers with the right foot so modification not required. :)
    MDEL, j09333 and 4_Eff_Sake like this.
  8. Caeruleus11
    Caeruleus11 F1 World Champ
    10,861
    Or trade for 812 which has friendlier handling.
    RamsHmb likes this.
  9. Solid State
    9,586
    Sorry, looks and tradition matter! Also prefer the more 'unfriendly' F12.
  10. KarlA69
    KarlA69 Formula Junior
    Oct 9, 2017
    759
    Karl
    Not sure how serious the initial idea was (?). I think this makes no sense. Leaving aside the likely very substantial cost and hassle of making this conversion, I would not feel comfortable that this retro fitted system works exactly as designed. You might find out the hard way that it doesn't.
    Wheels1 likes this.
  11. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Lol. This is what I thought too. Want to decrease wheelbase? Just give it a bootfull:)
  12. Caeruleus11
    10,861
    The irony is the F12tdf RWS is used to increase wheelbase. It only steers in phase with the fronts (same direction). This was done because they added so much grip to the front end, they needed a way to increase stability. So even though they call it virtual short wheel base, in reality it is a virtual long wheelbase.
  13. Solid State
    9,586
    Yes indeed. The story told before release, not sure if true, was that they started by putting the rears on the fronts and found so much grip that the rear stepped out uncontrollably. They ended up with rear steer and easing up on the front width as the final combo. The story goes that being a numbered VS they wanted it to be a challenge to drive spiritedly so the calibration for the RWS was intentionally left edgy. This was toned down in the 812sf as predicted resulting in very fine and accurate handling. Ferrari can and does make the best package.
