f12 rear mesh. corrosion | FerrariChat
Discussion in 'F12/812' started by 2006m5, Feb 18, 2020.
  1. 2006m5
    2006m5 Formula Junior
    Dec 19, 2008
    924
    huntingdon valley PA
    Question for the ferrari regulars
    If you own a ferrari f12 and you get the corrosion will ferrari
    step up and fix?
    I assume its a issue because a car i looked at the dealer had this problem.
  2. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,593
    Grant
    eskanday likes this.
  3. 2006m5
    Dec 19, 2008
    924
  4. Gh21631
    Gh21631 F1 Veteran
    9,371
    East
    Many cars had the issue but not all. The dealer should fix it beef you take ownership and it should be done to your satisfaction or pass. I was told and read that Ferrari will cover under the extended warranty.
  5. 2006m5
    Dec 19, 2008
    924
    thanks Gh^^
  6. colonels
    colonels Formula Junior
    Aug 5, 2011
    887
    i also have an F12 out of factory warranty. i would like more details on the preventative fix if anyone can provide it. the linked thread did not have that info.
  7. Gh21631
    Gh21631 F1 Veteran
    9,371
    East
    My understanding is that there are spacers between the metal mesh and body which keep it from rusting. However Ferrari in their wisdom won't do that fix until there is a problem and they have to paint the area as well.
  8. colonels
    Aug 5, 2011
    887
    good info! how does one access the screws to add spacers? you cannot do it from the outside.
  9. 2006m5
    Dec 19, 2008
    924
    colonels i assume u need to remove interior trunk panels and should be able to see from inside.
    colonels likes this.
  10. Gh21631
    Gh21631 F1 Veteran
    9,371
    East
    It's not a simple thing but it should he done
  11. 2006m5
    Dec 19, 2008
    924
    In my younger years i was in car stereo and alarm business so taking apart cars was easy .
    If not up to it a good body shop will do it ....since they take cars apart all the time.
  12. Gh21631
    Gh21631 F1 Veteran
    9,371
    East
    I am going to ask my tech what the prevent fix entails and I will post up.
  13. 2006m5
    Dec 19, 2008
    924
  14. Gh21631
    Gh21631 F1 Veteran
    9,371
    East
    I went ahead and scheduled a proactive fix. Basically they will insert plastic spacers between the mesh grill and the paint to eliminate galvanic corrosion. I dont know the cost but I am guessing between 1K and 2k. All labor.
    Interestingly I learned that the 812 has the same problem, Ferrari did not learn from the F12.
  15. 2006m5
    Dec 19, 2008
    924
    Gh very good.
    This will fix for sure.
    2 dollars in parts....what is ferrari thinking?
  16. 2006m5
    Dec 19, 2008
    924
    I made a offer today on 2013 f12.
    The car has no corrosion .
    if i buy i will tackle the mesh with washers right away.
  17. 2006m5
    Dec 19, 2008
    924
    gh another thought make sure when they release the nuts make sure they are aluminum.
    If not get aluminum material nuts.
    F1 Addict and Gh21631 like this.
  18. colonels
    Aug 5, 2011
    887
    Was this covered under a corrosion warranty? My F12 is out of factory warranty and I don't have the extended warranty. My car is a 2016 and is showing the bubbling now.
  19. Gh21631
    Gh21631 F1 Veteran
    9,371
    East
    I "think" Ferrari has an extended warranty for corrosion but I am not certain. You should contact a local dealer and/or maybe someone else here knows.
  20. ScottS
    ScottS F1 Rookie
    2,953
    Winter Park
    Scott S
    812 also ? Please say more ....
  21. eskanday
    eskanday Karting
    Jun 21, 2017
    94
    Hi, did you end up doing the proactive fix? How involved it was? How much did it cost? Any bubbling since?
    Alex
  22. Gh21631
    Gh21631 F1 Veteran
    9,371
    East
    I did the fix and while I owned the car it had no issues. If I recall it was under $1k in labor and took about a day and half.
  23. Eilig
    Eilig F1 Rookie
    4,299
    Tänzelndes Pferd
    My '15 has 1325 miles, never driven in rain, no corrosion around rear mesh.
  24. SkipperAndre
    SkipperAndre Rookie
    Mar 15, 2017
    13
    Just bought a 2015 which had this issue around the mesh. Ferrari says they will only honor this as a warranty claim if I was the original owner..?
    Ferrari in Houston told me they had seen several cars with this issue.
    My car was sold by a Lamborghini dealership, hence they will fix it before I take the car.
    Hopefully it will not go beyond the mesh/rear vents... As soon as I get the car I will open it up back there to have a look
    and see if there are additional preventive steps to be taken.
  25. haithman
    haithman Formula Junior
    Aug 12, 2004
    272
    Assume this is not covered under the extended power warranty?
