F12 Battery Replacement | Page 3 | FerrariChat
Discussion in 'F12/812' started by Cincy2, Jan 13, 2017.
  1. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    I think those individuals who have done it on the forum mentioned writing down or making note of everything when taking things apart, and that will be helpful when putting everything back together. One individual suggested use a few bungee cords to keep the wiring out of the way during installation if you are doing it along. Regardless of what you do, just make sure you don't hurt your back. It's definitely not worth saving a few hundred bucks and end up with back pain for the rest of your life.
  2. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    It is no fun replacing the battery in an F12. It is a tight squeeze and the battery is very heavy. You don't have to drain or top up any fluids when you replace the battery, but low battery voltage will set numerous fault codes in the multitude of electronic control units that are in the car. You need a diagnostic computer to clear all of those codes. After battery replacement you need to leave the key on for a minute before starting the car, then after starting it, do not touch the throttle for five minutes. Just let it idle and learn the idle parameters. You also need to lock and unlock the doors with the key remote in order to initialize the door locks/rear hatch/fuel door system. You will need to reset the date and time and recalibrate the TPMS system, but you can drive it with all of the low voltage fault codes to get it to a shop in order to clear them.
    Endrig and BruceC like this.
  3. Solid State
    Solid State F1 Veteran
    9,641
    Maximus Decimus Meridius
    Motob - Your Ferrari experience leaves me envious and grateful! Your posts are always factual and insightful. Glad you are on this board.
  4. not4one
    not4one Formula Junior
    May 23, 2010
    887
    CT, FL
    #54 not4one, Jul 30, 2017
    Battery issue just hit my 2017. In the past I've let it sit for 3-4 weeks with no issue.
    As I rarely drive it during the summer (stored at my winter place) I decided it probably wise to put the conditioner on as it sat for 6 weeks. Seems to have been a mistake. Completely dead. (Have only driven it about 1000 miles over past 6 months so it doesn't get the full charge that often).
    Tried to jump it and while full power seemed to go thru the electrical system (full blower speed, etc.) during the jump attempt, all I could get were clicks out of the starter...no turning at all.
    So, do any of you with battery experience have any advice/thoughts? Why would power move thru the system so effectively, but not result in engine turning over? All thoughts appreciated.
    Feeling like I'm likely getting it towed to nearest exotic car expert (Ferrari dealer over 100 miles away...so that's not happening) and having a Sears DieHard installed (after reading an FF thread).
  5. deltona
    deltona Formula 3
    Aug 7, 2009
    1,386
    Justin
    Try leaving it on the tender overnight. That should get you going unless the battery is damaged.
  6. not4one
    May 23, 2010
    887
    CT, FL
    I'm concerned that it is somehow damaged. I just don't understand why a jump start from another car wouldn't turn the engine over, but would turn all the electrics on. Never experienced a jump not working.
    I did get a recommendation from a knowledgable garage to put a 4.3 amp charger on it for a day or two to see what happens. I'll probably give that a go next weekend.
  7. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    Hope it works out with the 4.3A charger. Or throw in the DieHard battery and see. Let us know how it turns out.
  8. not4one
    May 23, 2010
    887
    CT, FL
    Update.
    Finally got back to the car...another couple of weeks sitting there dead could not have helped the situation. Hooked up the 4.3 charger, went back 15 hours later and the charger was only indicating a 3 on the 8 point scale (instructions indicate you need at least a 4 for a start)....turned the key, hit the button, and voila it started!
    Gotta say this was a good surprise...I was pretty much convinced this step was just part of the process of confirming the battery was kaput before calling the tow truck. Happy days.
  9. rockitman
    rockitman F1 Veteran
    May 31, 2015
    5,982
    Upstate, NY
    Christian
    I think I will let the dealer install a new battery when necessary. I say that knowing how quirky Ferrari electrical systems can be...
  10. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    Just make sure to bring in a good aftermarket battery for the dealer to install instead of using another oem battery.
  11. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    So did you have an aftermarket battery installed?
  12. Tupps11
    Tupps11 Formula Junior
    Jan 7, 2009
    558
    +1
    OEM battery is garbage.
  13. Rosino81
    Rosino81 Rookie
    May 25, 2013
    36
    London, UK
    I just ordered the Varta Silver in the spec reported above which is the exact same one that appeared for the car when input F12 in Varta and Eurocar parts. Fingers crossed it's a fit indeed and I can strop stressing if the car is not on trickle charger for more than 2 days.
  14. speedbird1000
    speedbird1000 Rookie
    Jun 29, 2008
    41
    Europe
    .......its easy to get to the stage of getting ready to remove battery..very hard to do this bit though...."Remove the battery from the battery mount, tipping to facilitate the operation "......i even made a special metal grab tool that grabs the battery up by hooking in under the edge, but the stupid FIAMM battery is huge, i cant wrestle it out yet, has anyone successfully wrestled it out ? any tips ? maybe tear off the heat shielding around battery to free it up more ? on LHD cars, the power steering reservoir is on the other side of the car, and so does not have to be removed....
  15. sandman03456
    sandman03456 Formula Junior
    381
    Las Vegas, NV
    Which battery for the GTC4Lusso V12?
  16. speedbird1000
    Jun 29, 2008
    41
    Europe
    successfully removed mine. definitely a nightmare of a job.
  17. bruno787
    bruno787 Karting
    Nov 1, 2010
    198
    PHILIPPINES
    12v 95ah L5 AGM 850a EN---->>Lusso V12 battery
  18. bruno787
    bruno787 Karting
    Nov 1, 2010
    198
    PHILIPPINES
    having hundreds of vehicles in our company fleet, the lusso is the most difficult battery change ived ever had, took 3 people to lift it up
  19. sandman03456
    381
    Las Vegas, NV
    Great news. Hernias all around
    Solid State and otakki like this.
  20. speedbird1000
    Jun 29, 2008
    41
    Europe
    The 95 Ahr 850 cca Fiamm AGM battery that came out weighs 23 kg and you have to wriggle it out bent over with the bonnet totally on the way... I made a special tool out of a bit of metal 8 inch long, so I could lift it out standing straight, on my own, by hooking it into the upper body, that way you avoid a guaranteed Hernia...
  21. speedbird1000
    Jun 29, 2008
    41
    Europe
    Putting in a Bosch S5 95 Ahr 850 CCA AGM.. it's the same as the Varta Silver. My stock FIAMM battery did last 6 yrs I noted.
  22. sandman03456
    381
    Las Vegas, NV
    Could you post a photo of your custom tool as a reference. Joe
    otakki likes this.
  23. otakki
    otakki Formula 3
    Mar 24, 2016
    1,624
    6 years?!...That has to be a record for the oem battery. I have read that F12 is even worse than FF/GTC4. For FF, taking it out is still not too bad. Putting it in wouldn't have been so bad if it wasn't for the heatshield plus that drainage button at the bottom. Of course, the entire ordeal would have been a non-issue if that plastic cave around it can be easily removed. Next time, will likely pay the dealer to do it. It makes no financial sense for me to spend 4+ hours plus the risk of hernia and injury to tackle that again...not to mention the sore upper body for nearly a week afterward.
    Yes, definitely would love to see what that custom tool looks like.
  24. Solid State
    9,641
    I changed mine at around the six year mark. Removing the plastic bits was simple. Getting it past the vapor breather tube flange as you point out and replacing the breather tube that connects to it and extends out the bottom of the car took over a month for the part.
  25. speedbird1000
    Jun 29, 2008
    41
    Europe
