430 - F1 driving tips | FerrariChat
430 F1 driving tips
Discussion in '360/430' started by CoreyNJ, Mar 3, 2020.
  1. CoreyNJ
    CoreyNJ Formula 3
    2,030
    New Jersey Shore
    Ok. So I have been told to think of the F1 as manual transmission where the throttle is also your clutch.
    So far the tips I have gotten to reduce clutch and transmission wear have been basically don’t let up on the throttle when you shift and don’t drive it up a hill in reverse. Also, don’t use the throttle to keep the car from rolling just use the brake to hold the car.
    I’m sure there are more tips out there so here is my question.... I noticed when I come from a standstill in 1st gear if you feather the throttle you can feel the clutch slip and then it abruptly engages. So should I never feather the throttle from standstill and basically push the throttle quickly 1/4 of the way every time trying to let the clutch engage as fast as possible or should I be doing something different from a standstill (just driving around not racing around)?
    Thanks,
    Cheers,
    Corey
  2. 3POINT8
    3POINT8 F1 Rookie
    4,432
    i thought you let up on the throttle when shifting to avoid clutch wear that's what i used to do on my f430 maybe i got that wrong...
  3. frankgoodson
    frankgoodson Rookie
    Dec 25, 2008
    42
    Don't feather the throttle. Be a little aggressive with the throttle so the clutch engages fast. Like you said, 1/4 throttle should be fine.
  4. nickorette
    nickorette Formula Junior
    Jun 19, 2017
    341
    Canada
    Not sure what you mean by feather the throttle, but in a manual from stop the best method to preserve clutch is maintain consistent low throttle and bring clutch to engagement point and hold until clutch engages then release. It's a common misconception to release clutch and increase throttle at same time, but this extra throttle increases clutch wear. The same can be said for F430 from stop, maintain low throttle until you feel it engage then you can give it the beans
