exhaust hanger for middle section? | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by It's Ross, Jan 13, 2020.
  1. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    My parts book indicates PN 101999. Searching indicates this is a 70mm x 48mm ID piece. Sounds like the smaller one for the rear muffs. to me.
    Seems like asking for a lot of stretch from this little guy. Is this the correct part # and what other applications cross?
    thanks
  2. Rifledriver
    37,288
    101999 should be pretty large. I never had a great deal of difficulty installing them. It is the correct #. Where did you get it?
  3. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Ross
    From a Ferrari parts book. I indicates a size of 70mm x 48mm. Does this mean a typical round donut with an OD of 70mm and 48mm ID? Installed they are quite elongated as you know.
    Perhaps the dimension is for an oblong shaped piece with 70mm being the length and 48mm width? If so then ought to work.
    Do you have one of these on hand to look at?
    Thanks!
  4. Rifledriver
    37,288
    That sounds about right. If you look at the picture on Ricambis web site it looks correct.
  5. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Ross
    Thanks, hard to tell from the photo. Have you bought this # for hanging the center exh?
    $28 a piece? Yikes!
  6. Rifledriver
    37,288
    Yes but it has been a very long time.
  7. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,681
    Romulus, NY (Finger Lakes)
    Ken Battle
    NAPA has two sizes of the round 'donuts', item nrs 35120 and 35352. I use one of these for my rear silencer as they are a bit smaller than the originals. They have a wide range of alternate types and sizes if you need a better fit.
    Ken
  8. jacques
    jacques Formula Junior
    May 23, 2006
    877
    Los Angeles/Florida
    I just this moment googled rubber exhaust donuts and amazon rubber exhaust donuts, and mercedes exhaust donuts, and found many sizes and varieties, and found dozens of them. Jq.
  9. SouthJersey400i
    Mar 14, 2007
    1,681
    Ken Battle
    Check out the tool on Amazon: OEMTOOLS 25543. This sure will help installing them!
    Ken
  10. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,649
    SF Bay Area, CA
    Ruben
    I just purchased these from Amazon for $7.99 for a pack of 4: https://www.amazon.com/gp/product/B07XH233TW/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    They have the exact same shape and dimensions as 101999 and are a perfect fit for our cars. Note: the material’s cross-section is oval shaped (just like 101999), not round shaped as they appear to be in the pic.
    I just mounted them and they look great. I had no problem installing with a screwdriver as leverage - just make sure to use a jack to pick up the slack in the exhaust (they are really heavy). Will report back in terms of longevity.
    bjwhite, 360modena2003 and Ak Jim like this.
