355 - Exhaust Bypass Valve Solenoid Wiring | FerrariChat
355 Exhaust Bypass Valve Solenoid Wiring
Discussion in '348/355' started by Copperhed51, May 6, 2023.
  1. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    I posted about this in my thread about replacing my headers, but wanted it to have its own thread for visibility and later searches.
    I’ve narrowed this down to an electrical issue and could use a little help to complete the diagnosis and repair.
    A little diagnostic history: I checked all of the vacuum lines and the valve itself and confirmed that all is functional there. The solenoid was reading 55ohms and the connector from the 5.2 Motronic to the solenoid reads 12V to ground on one pin and 6V to ground on the other, which is odd. To verify that the system is working correctly minus the electrical portion, I actuated the solenoid using a 9V battery with the engine running. The bypass valve opened and closed exactly as it should.
    So now I’m at the point of figuring out the electrical problem. I understand it is pin 64 (yellow/blue wire) on the ECU that is controlling the solenoid.
    My questions: Does the ECU provide 12V to this wire to command the solenoid open? Is the other wire at the connector grounded somewhere on the car or has something been integrated some other way to complete the circuit? Why do we think one wire is receiving 12V and the other 6V to ground (the ground being a bolt on the gearbox housing that holds a bonding strap)?
    I won’t be able to look into the issue more for another week or so, but how often do the ECU’s fail on just one thing like this? The car seems to be operating fine otherwise. I’m sure I’ll have more questions as this is discussed, but appreciate any info to get me headed in the right direction when I get my hands on the car again.
    cavlino likes this.
  2. Qavion
    Qavion F1 World Champ
    14,236
    Ian Riddell
    Sequence:
    1) Ignition on, the ECU runs through a quick self test then energises relay "M"
    2) 12 volts power is supplied by relay M to the solenoid valve via the green/black wire (and is always present with the ignition on)
    3) The ECU supplies an earth to the solenoid valve via the blue/yellow wire when the valve is commanded open.
    There will be a complete circuit via the battery of course. The ECU earth wires will provide a path through the chassis.
    I'm not sure why you're getting 6 volts on the blue/yellow wire. ECU fault or some power wire shorting to the blue/yellow wire? Check the 14 pin plug near the ECU for bent pins. And the main ECU plug, too.
    cavlino likes this.
  3. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    #3 Copperhed51, May 6, 2023
    Great info. This is exactly what I was looking for. As far as the 6V to the blue/yellow wire, I don’t know. I’m not sure which wire at the connector was reading 6V and which was reading 12V, though it would stand to reason that the yellow/blue was the one reading 6V. YelCab suggested a short somewhere, which it very well may be. Now that you’ve given me a better understanding of how the system works, I can chase down the problem more effectively. Just curious, how do you know the startup sequence so well? Is this spelled out in the WSM somewhere? Thanks.
    cavlino and Qavion like this.
  4. Qavion
    14,236
    Ian Riddell
    A combination of manuals, reading the diagrams, experimentation and the combined wisdom of the forum.
    cavlino and Copperhed51 like this.
  5. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    cavlino likes this.
  6. Qavion
    14,236
    Ian Riddell
    Also have a look at the 14 pin plug near the ECU. I can’t remember if it’s clear or white.
    Are you getting a Check Engine Light?
  7. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    No check engine light. I did get a P1448 when I wired the valve open temporarily, but that was expected and I’ve since cleared it and unwired the valve. I’m kind of surprised because I would have thought the thermocouple would read that the valve is not opening when it is supposed to and throw a light, but I guess it isn’t programmed that way. I’ll check the 14-pin connector when I’m back home. Another thing I noticed while chasing a coolant leak at the thermostat housing is there is some slack in the throttle cable. I need to rectify that, but I can’t imagine it’s enough slack that I’m not meeting the conditions required to command the valve open. Plus that 6V thing doesn’t add up anyway.
    Qavion likes this.
  8. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    If ECU is supplying ground to open the valve the 6v reading you got could be the "float" voltage of that pin when not in a open valve grounded state. Was the solenoid connected when you measured?
    Qavion likes this.
  9. Qavion
    14,236
    Ian Riddell
    #9 Qavion, May 6, 2023
    Now I'm confused. I measured the voltage with the plug off and there was, indeed, around 6 volts on the blue/yellow wire. When I back-probed the pins with the plug in-situ, I got around 12 volts on both pins.
    Still trying to figure this out.
  10. Qavion
    14,236
    Ian Riddell
    I was earlier thinking that the circuit looked something like this:
    But would this cause floating voltages and the test results I saw?
  11. m.stojanovic
    m.stojanovic F1 Rookie
    3,210
    Serbia - Niš
    Miroljub Stojanovic
    As "Zamboniman308" mentioned, the 6V when the solenoid is disconnected is most probably just a "float" voltage of the electronic circuit inside the ECU which switches the blue/yellow wire to ground in order to activate the bypass. When the solenoid is connected, and the ignition turned "on", there will be 12V supplied to one side of the solenoid (by the relay M). While the ECU has not grounded the other side of the solenoid (the blue/yellow wire), this wire will also read 12V which comes to it through the solenoid coil and overrides the 6V "float" (or some "bias") voltage. The blue/yellow wire will be at 12V until it is grounded by the ECU to activate the solenoid valve.
  12. Qavion
    14,236
    Ian Riddell
    Thanks, Miro and Zamboniman
    So if Copperhed's values are normal for the non-open valve command (including the floating voltage), then perhaps this would suggest the wiring from the ECU is ok.
    I can't think of anything else causing an issue other than the ECU. I think if there were earth issues, there would be other symptoms.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,521
    San Carlos, CA
    Mitchell Le
    Let me suggest to you a way to figure out where the problem is:
    Open the back of the 88 pin connector, somehow splice a connector to the yellow / blue wire and attach DVM to that line. Plug the ECU back in.
    Drive around while observing the value on the DVM.
    When you floor the gas in first or second gear, the value on the DMV display should be close to zero volt.
    Case 1: you do see zero volt on the DMV but you cannot hear a difference in the exhaust sound. That means the problem is outside the ECU
    Case 2: you do not see any change in voltage coming out of the ECU when you floor the gas. The ECU is not giving the open-valve command.
    In case 1, and given the trouble shooting you have already done, the remaining issues are:
    a) broken wire from ECU to the solenoid
    b) Not enough vacuum while the engine is running to properly operate the bypass valve circuit
    c) Bypass valve is open, but the bypass channel in your muffler is not a loud type or clogged. There are mufflers that do not sound different even when bypassed
    In case 2, the issues can be:
    a) The ECU is not seeing the wide open throttle signal from the throttle position sensor and never issues the command to open the bypass valve.
    b) The ECU does know what gear the car is in so it does not open the bypass valve. The ECU needs a speedo signal and an RPM signal to figure out what gear the car is in. One of those 2 signals is missing
    I hope that helps.
    cavlino likes this.
  14. Qavion
    14,236
    Ian Riddell
    You can probably narrow this down further.
    If your speedo wasn't working or you have a suspension light on, then it's likely that the ECU is not getting a speed signal.
    The 5.2 only has one crank sensor. This sends an rpm signal to the ECU, the ECU processes it and uses it for timing. It also sends rpm data to the tachometer. If your engine and tacho are working, then the ECU should have an rpm signal.
    A good scanner should tell you the TPS or perhaps if the engine management system is in closed or open loop. The ECU switches to open loop mode with the throttle wide open.
  15. yelcab
    Nov 29, 2001
    13,521
    San Carlos, CA
    Mitchell Le
    Do I remember correctly that before the change over of the exhaust headers, you had none of these problems? That the bypass circuit worked, and you can readily tell when it works via the loudness level changes and the pitch changes at the pipes?
    Did you install the headers yourself?
  16. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    I had considered attaching a DVM to that wire, but couldn’t think of a good, non-destructive way to do so. I may have to go this route in the end, but maybe I can figure something out another way.
    For case 1:
    a) Can’t rule out a broken wire completely, but it now seems unlikely given that the voltages are the same as other folks have on their cars.
    b) I’ll also say it isn’t ruled out, however, I did test the valve using the 9V battery while the car was idling and it worked fine a number of times in a row. The vacuum was sufficient at idle and I also tested just the vacuum reservoir using a handheld vacuum pump and it held vacuum. So, given that vacuum is sufficient at idle and the reservoir is holding vacuum, this is unlikely to be the problem.
    c) The car has a Capristo exhaust and is definitely noticeable when the valve opens. This was the reason I temporarily wired the valve open and drove the car. I wanted to make sure I knew what it was supposed to sound like with the valve open. I can definitively rule this out.
    I’d call case 1 very unlikely, but I’ll never say never.
    For case 2:
    a) I had considered this, but have no solid way to test it at the moment. Going by memory, I think the ECU needs to see at least 85% throttle to command the bypass valve open? There is a fair bit of slack in my throttle cable that I will correct next week, but I doubt it’s enough to cause this. It would be great if it was this simple, so we’ll see.
    b) The speedo and tachometer are working correctly. Is it safe to assume that if those gauges are working correctly, then the ECU is getting that signal?
    It seems like I am headed down the road of needing some sort of more advanced diagnostic tool that can read TPS values, so I’ll start researching my best options. I’m open to suggestions here.
    Thanks for the suggestions here. With this community, I think this problem will get solved one way or another.
  17. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    The problem existed prior to the header install, but I just didn’t realize it. I had never wired the bypass valve open to check the sound levels until after the headers went in. After I installed the headers, I had this feeling that the car still just wasn’t as loud as it should be. During one random drive after the header install, I heard the valve open when flooring the car in 2nd gear. I looked at my wife in the passenger seat and said “that’s what it’s supposed to sound like!” It was after that I wired the bypass valve open to confirm what I’d heard. So maybe this adds to the mystery that the valve has opened a single random time since I’ve owned the car, but the issue existed before and after the header installation. I did do the headers myself.
  18. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    The speedo is working and I did get a suspension light the other day from starting the car a few times on the lift and not moving it. As soon as I pulled the car off the lift, the suspension light went out. Seems like good confirmation that the speedo signal is being received. The engine and tach are working, so I think we’re good on the crank sensor. As I said in another reply, I think I’ll need to invest in a good scanner very soon. Suggestions on a scanner? My OBDII port seems to be functional since I can view and clear codes using a simple scanner. Not sure if the more advanced scanner would be hooked up there or if it hooks up to the 3-pin connector by the ECU, but I should be in good shape with either connection point.
    Qavion likes this.
  19. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    A simple cheap yet well featured OBD scanner will tell you a lot about the health of the car. It won't necessarily tell you explicitly but the raw data such as open closed loop TPS values fuel trim and O2 data.. so you'll need to get acquainted with the data and how to interpret. I use a few year old bluetooth obdlink mx+ i think. I couldn't live without it.
    Copperhed51 likes this.
  20. yelcab
    Nov 29, 2001
    13,521
    San Carlos, CA
    Mitchell Le
    Don't rule out weak vacuum at high rpm.
    You need a scanner that can tell you what the throttle position sensor is reading.
  21. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    Ok, this is going to be a stupid question, but what else is vacuum used for on these cars? I won’t rule out vacuum, but assumed (probably wrongly) that if I had sufficient vacuum to open the valve at idle and a reservoir/accumulator that holds vacuum, then I should still have enough vacuum remaining in the reservoir to open the valve during hard acceleration after a stop where the car is idling for a bit.
    I’m currently over analyzing and hunting for the “perfect” scanner so I can read TPS values.
  22. yelcab
    Nov 29, 2001
    13,521
    San Carlos, CA
    Mitchell Le
    Vacuum is used for the fuel pressure regulators. If that leaks at the regulator or at the intake manifold, there is less vacuum to operate the bypass valve. And you get don't get maximum vacuum at high rpm with the throttle opened all the way.
  23. Qavion
    14,236
    Ian Riddell
    The vacuum also operates the Secondary Air system, but with the car warmed up, that system should be off. I assume you're not revving the heck out of the engine with the car cold. The coolant temperature sensor determines when the system is switched off (but there may be other inputs). Is your engine otherwise behaving normally after warm-up?
    cavlino likes this.
  24. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    Secondary air system sounds like it is working properly. I can clearly hear when it shuts off. I always let the car warm up prior to any revving, and generally the coolant is to operating temp prior to even leaving the garage. Best I can tell, the engine behaves very well when warmed up.
    Qavion likes this.
  25. Copperhed51
    Copperhed51 Karting
    Feb 4, 2023
    148
    Ok, so I hooked up the OBDLink MX+ and got some interesting readings for TPS. I pushed it to the floor and was getting less than 70%. I pushed harder, to the point it almost felt like I was going to push a hole in the floor and only got to ~75%, but that means the limiting factor was the floor and there was probably more throttle travel available without the floor in the way.
    So, the question is, is this reading accurate for TPS absolute throttle position? If so, either the slack in the throttle cable is worse than I thought, or the TPS itself is bad, or a combo of both.
    Does this look normal?
