430 - Excessive play in Engine Bay Lid & Lock ass'y? | FerrariChat
430 Excessive play in Engine Bay Lid & Lock ass'y?
Discussion in '360/430' started by PBT58, Mar 5, 2020.
  1. PBT58
    PBT58 Karting
    Jul 6, 2018
    69
    Peter T
    My '08 F430's Engine Bay Lid moves up and down approx. 3/8" when latched.
    I doubt this is normal operation and I occasionally hear rattles in the back at certain RPMs.
    I checked the lid on a F430 parked near mine and it's rear lid has no play at all.
    Has anyone ever had this issue?
    Is there any way to adjust the locking mechanism to take out this 3/8" of play?
    I googled and no luck on finding any info on adjustment.
    I appreciate any input from the community.
    Thanks!
    Pete
  2. cole328
    cole328 Formula Junior
    May 9, 2014
    882
    I can confirm for sure that is not normal. Mine closes and doesn’t move a centimeter. Do you have a good Indy mechanic that can check it out?
  3. RedNeck
    RedNeck F1 Veteran
    BANNED Silver Subscribed
    Jul 8, 2016
    9,875
    The CSA
    Me
    There is a slight side to side adjustment on the striker itself, also adjustment plates that you can remove and add.
  4. RedNeck
    RedNeck F1 Veteran
    Jul 8, 2016
    9,875
    The CSA
    Me
    I will also add, make sure that all the locking mechanisms are tight, might not be an adjustment issue.
  5. PBT58
    PBT58 Karting
    Jul 6, 2018
    69
    Peter T
    Thanks for the reply.
    I do have a good Indy Svc facility (Radcliffe Motors) and I'm planning to bring car in next month for it's annual service.
    I was hoping to take of this myself if it was an easy fix.
    If not, I will have Radcliffe take a look and address during the annual.
  6. PBT58
    PBT58 Karting
    Jul 6, 2018
    69
    Peter T
    Thank you.
    I found this diagram as well and used it to make sure all parts were present.
    (ie. Vibration Dampers...)
    Note: I confirmed my car does not have any adjustment plates installed between lid and striker plate.
    To my eye the adjustment plates would make the gap even bigger.
  7. PBT58
    PBT58 Karting
    Jul 6, 2018
    69
    Peter T
    Thanks.
    Everything does appear to be tight.
    Appreciate the feedback
  8. RedNeck
    RedNeck F1 Veteran
    Jul 8, 2016
    9,875
    The CSA
    Me
    Those rubber dampers (20 in the diagram) will also thread in and out.
  9. PBT58
    PBT58 Karting
    Jul 6, 2018
    69
    Peter T
    That may help!
    If I can extend those out 3/8" it might just solve my problem.
    Will give that a try tomorrow and report back.
    Thanks RedNeck!
    RedNeck likes this.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,561
    Central NJ
    Dominick
    How do the lines of the lid match to the fender ? Is there an offset ..
    Sent from my moto g(7) using Tapatalk
  11. PBT58
    PBT58 Karting
    Jul 6, 2018
    69
    Peter T
    Good question flash32.
    I will check on that tomorrow.
    Thanks!
