Ethiopian 737-8 MAX down. No survivors. | Page 5 | FerrariChat
Discussion in 'Aviation Chat' started by RWatters, Mar 10, 2019.
  1. NW328GTS
    NW328GTS Formula 3
    Nov 16, 2009
    2,191
    Washington
    Hal
    Or turn off the trim system or use the trim switches to trim in the opposite direction and then turn the trim system off. I
    ts not like trim system can sneak up on the pilot. Its noisy and very visible when its moving. A significant amount of training is done on what to do if the trim system is acting up. Whether the "acting up" is coming from damaged trim switches or a broken stall warning or a bad AOA or the MCAS issue the pilot action is the same.
  2. George Vosburgh
    George Vosburgh F1 Rookie
    Trump has just grounded the plane in the U.S.
  3. KKSBA
    KKSBA F1 World Champ
    14,930
    SBarbara-La Jolla CA
    KKSBA
    Thing is it doesn’t act like sustained runaway trim, which is trained for on most aircraft, it just puts in trim in increments depending on flight characteristics. It’s obviously overloading marginally trained pilots right after takeoff just when they retract the flaps. it’s busy in the cockpit following ATC changing freqs flying a SID etc. if you have a newish Captain on type and a useless copilot you’ve got trouble if it acts up so close to the ground.
    furmano and jcurry like this.
  4. Gatorrari
    Gatorrari F1 World Champ
    15,939
    Georgia
    Jim Pernikoff
    Looking at the photo of the aircraft, I don't see much difference in the location of the engine thrust line compared to the 737 NG or even to the original -100/-200; the only difference is that the thrust is much further forward than on the original aircraft. So I don't see why MCAS is even necessary.
    Apparently there is a switch to turn MCAS off. Why not simply order everyone to turn it off and keep it off until a definitive solution is reached?
  5. jcurry
    21,545
    In the past
    Jim
    2 deg (hard to discern looking at photos) would be 3.5% change in pitching moment due to thrust, then add higher thrust engines and net change could be closer to 10%, all which needs to be trimmed. Distance forward of the wing MAC means greater moment arm for any vertical component of thrust. It all adds up. Since fuselage lengths are unchanged from MAX to NG the tail trim loads will be greater.
  6. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    7,913
    Shoreline,Washington
    Robert Parks
    I was trying to roughly figure the amount of incidence in the thrust by looking at the photo of the Ethiopian 737 Max in the previous post. You did for me and everybody else.
  7. TheMayor
    TheMayor Nine Time F1 World Champ
    98,734
    Vegas baby
    I think Boeing didn't do a good job in explaining the Lion Air case to the public. If they did they would have had the general public more at ease with a second plane.
    It's not Trump that did this. Its pressure from fliers and maybe even the airlines wanting someone to "do something" to take the heat off them.
    Now people will stop asking what kind of plane they are flying because they know it's not a Max.
    Rifledriver likes this.
  8. Ferrari 308 GTB
    Ferrari 308 GTB F1 Veteran
    Feb 21, 2015
    7,738
    Tropical
    The old saying 'if it ain't Boeing i ain't going' has been somewhat degraded .
    boxerman and polishhammer83 like this.
  9. Bob Parks
    Nov 29, 2003
    7,913
    Robert Parks
    The airplane that I was thinking about was the "Colonial Skimmer".
  10. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    11,990
    FRANCE
    Not London, but Paris (sorry, nothing to do with this week's votes in the House of Commons about a certain matter...) Ethiopan has asked for the french BEA to do it.
    Rgds
    Ferrari 308 GTB likes this.
  11. Ferrari 308 GTB
    Feb 21, 2015
    7,738
    Tropical
    Thanks. It makes sense the BEA also handled their last 737 crash.That final report makes scary reading.https://www.bea.aero/docspa/2010/et-b100125.en/pdf/et-b100125.en.pdf
  12. thecarreaper
    thecarreaper F1 World Champ
    17,579
    Savannah
    Mentioned this is the thread in Silver. The Ethiopian crash has ground eye witness statements about engine noise, smoke and "engine"debris as well as a burning trail of fuel vapor in the air. Could bird strike(s) have failed one engine, and the performance change and differential thrust caused the loss of control?
    They took off from a runway elevation of @7600 feet and only got to @8500 feet so not much time, altitude or airspeed to respond to a hypothetical single engine failure or maybe it was a flock of birds that affected both engines.
    May not be AOA / MCAS at all, unless the systems AOA sensor was affected in hypothetical bird strike (flock) and the system reacted erroneously?
    I think grounding all the planes world wide is premature.
    We dont have enough facts and it seems the MCAS override procedure is being communicated to flight crews since the Lion Air incident.
    Never worked on or with the bird birds, just biz jets (21 years).
    Sad to see the knee jerk reactions going on. Hopefully the data teaches lessons learned and provides root cause for corrective actions to be taken such as training and software updates.
  13. nerofer
    Mar 26, 2011
    11,990
    FRANCE
    The FDR has arrived this Thursday morning in Roissy-Charles de Gaulle by the regular flight from Addis-abeba, as well as two representatives of Ethiopian.
    These will be brought in the BEA premises in Le Bourget (very close to CDG) and then opened in the presence of "american Experts".
    Rgds
  14. Hawkeye
    Hawkeye F1 Veteran
    7,533
    Is this a software only fix?
  15. INRange
    INRange F1 World Champ
    10,186
    Virginia/Florida/Caymans
    JD
    I don't know the system. That said....it would certainly seem that whoever coded it ignored some basic principles of what sensors are prioritized and when the system should switch off attempting to control the plane. Imagine this is a self driving car that keeps trying to leave the road and the driver keeps fighting it. You would think that any automated system would not override the pilots or drivers physical actions. The purpose of the automated systems is to augment the pilots/drivers skills not replace them.
    The simple reality is that self driving cars and self flying planes today would kill people at an unacceptable rate as in evidence by the 737-800 MAX.
    polishhammer83 likes this.
  16. anthony47
    anthony47 Karting
    May 15, 2005
    90
    Has anybody heard of the results of the CVR from the Lion Air crash?When we have already heard of them from the Prime Air crash.This seems very odd and should tell us exactly what went on in the cockpit.
  17. Rifledriver
    34,031
    Austin TX
    And sadly they did it to themselves without help. Getting shot in the foot is typically a self inflicted wound.
    Boomhauer likes this.
  18. TheMayor
    98,734
    Vegas baby
    I'm not convinced it's software alone that caused it. Training may have some issues. The Lion Air case showed maintenance issues also but the report isn't finalized.
    Often with events like this its a combination of issues, not just one.
    furmano, Rifledriver and Bob Parks like this.
  19. Rifledriver
    34,031
    Austin TX
    Almost never a singular mistake. We usually get several chances at avoiding big screwups.
    furmano likes this.
  20. TheMayor
    98,734
    Vegas baby
    Which is my point about getting the facts first. Knee jerk reactions are often wrong and do unnessary damage.
    But as I said earlier Boeing did a lousy job of explaining the first one. People were shocked a practically new jet would crash that way. Now another. It’s human nature to try to put two and two together even if the answer may be five.
  21. Hawkeye
    Hawkeye F1 Veteran
    7,533
    Certainly there are a few guys at Boeing that are saying "this was our fear all along/we told you so, etc..." when changing the geometry of the engines and flight characteristics of an aircraft designed originally as short/medium range.
  22. TheMayor
    98,734
    Vegas baby
    I think if Boeing suspected something different (like terrorism, a bird strike, or pilot sabotage), they would be a lot more vocal now about not wanting a grounding. It seems to me they suspect something but believe its still very rare or hard to do or in fact, something that's not directly their fault but involves some systems of the plane.
    What may have to happen is the Max brand may be so damaged that they may have to repair them all and then call them another plane. Sort of like the Galaxy Note 9. People don't trust them.
    Right now there is confusion over the 737 Max 9 and the 737 900. People think its the same plane.
    boxerman likes this.
  23. Jeff Kennedy
    Jeff Kennedy F1 Veteran
    Oct 16, 2007
    6,575
    Edwardsville, IL
    Jeff Kennedy
    You left out another complication in Boeing's possible storyline. Would Boeing really want to say that they are selling aircraft to airlines that are too incompetent in their pilot standards, insufficiently rigorous training programs, sketchy maintenance commitments and la oversight by the national aviation authority? When they alluded to some of that with Lion Air the chairman hit back at Boeing and suspended his orders. In this specific case with MCAS it is also possible that giving instructions to disconnect the system could raise Type Certificate certification issues.
  24. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    A maybe naive question.....
    When a new aircraft is flight tested and certified over several years, etops etc. Is this generally done with company test pilots or is there a level of ‘beta’ testing with customer pilots later in the test programme?
    I work in an industry where we have to design-in safety for all user demographics and cannot assume a level of competence and specifically we cannot blame a lack of competence if there are issues in the field. Why should the aviation industry not work like that?
    It’s surprising to here comments on here pointing at training etc. Of course all pilots are not equal but the design of the aircraft systems surely should consider that spread.
  25. Gatorrari
    15,939
    Georgia
    Jim Pernikoff
    The worse thing for Boeing is if airlines with MAXs on order start cancelling them and ordering Airbuses instead. If one or two do it, it might invoke a tidal wave of cancellations.
    Boeing (like most of its counterparts) was a better company when it was being run by engineers and not bean counters.....
