Ethanol free or Premium? | FerrariChat
Discussion in 'Hawaii' started by Bob in Makiki, Aug 15, 2017.
  1. Bob in Makiki
    Bob in Makiki Formula Junior
    May 30, 2017
    443
    Honolulu
    I know we need premium gas. But I suspect I will not drive the car often or far enough to need to fill it regularly. Ethanol is a problem potentially (it is hygroscopic) if you don't change the gas with some frequency. So, it seems to me, the choice is ethanol free regular gas with an octane additive, or premium with ethanol and take my chances. Any recommendations? (If there is ethanol free premium in Honolulu, I haven't found it.)
  2. WPOZZZ
    WPOZZZ F1 Veteran
    Aug 22, 2012
    6,477
    Honolulu, HI
    Did you try the McCully Union 76?
    On a tangent, you know George Nitta? He came out to a C&C a few years ago with some fuel hose soaked in a gallon of ethanol. He said it was there for a couple years and there was no deterioration. He did a burn test of the ethanol and it burned clear, he burned something else and it left soot all over the Pyrex dish. Can't remember what it was. George has some "interesting" theories and ideas. He recommends pure ethanol as an octane booster. One of my pals with a 997.2 turbo bought into this and said his car runs smoother and better.
  3. Bob in Makiki
    May 30, 2017
    443
    Honolulu
    Yep, McCully Union 76 has ethanol free regular. So, one option would be to buy that and add an octane booster. As for Premium with ethanol in it, I assume it is fine in our cars, but I have also been told that over time it goes bad, whereas gas without ethanol will last longer.
    So another option, I guess, is just drive the car enough to fill the tank regularly!
  4. 483hp
    483hp Formula 3
    Aug 17, 2005
    1,428
    www.fca.alberta.com
    Shell should be ethanol free
  5. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    22,965
    Honolulu
    Kevin
    Windward side has a Shell on Kam hwy near the mall that has ethanol free but it is 89 octane. I buy it for my garden tools but have not put it in the car.
  6. stever
    stever F1 Rookie
    4,067
    West. Wisconsin
    Steve R
    pure-gas.org probably call before you go
  7. Glassman
    Glassman F1 World Champ
    Don't you guys have ethanol free premium at Costco
  8. WPOZZZ
    WPOZZZ F1 Veteran
    Aug 22, 2012
    6,477
    Honolulu, HI
    Nope.
  9. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    Some of the Hele (formerly Tesoro) and 76 branded stations have ethanol free fuel.
    The fuel to these stations is supplied by a local refinery, and should be fresh.
    http://parhawaii.com/
  10. Kevin Rev'n
    Nov 29, 2009
    22,965
    Honolulu
    Kevin
    I haven't been to a Hele to check yet but they did take over a couple of my 76 locations that I used to use. If they have ethanol free high test that would be great. I just filled up my little gas can for the power tools last week. The ethanol free 89 octane was 4.19 a gallon!
  11. yronZFF
    yronZFF Formula Junior
    Dec 21, 2009
    749
    FIVE-O
    Ron
    In my boat I've used 89 octane straight gas with Marine Stabil.
    For my 430 (and my former 355) I use premium ethanol and add Marine Stabil at storage dosage (double dosage).
    Kevin and Gil knows I drive my 430 only about 400 miles a year and I've never had a problem with premium ethanol for the past 8 years or so that I've owned these cars.
    Hope I didn't just jinx myself!
  12. BMW.SauberF1Team
    BMW.SauberF1Team F1 World Champ
    Dec 4, 2004
    14,244
    Fuel systems in modern cars are able to deal with ethanol...it's been that way for decades. The cars that can't are very very old now.
    http://www.bae.ksu.edu/precisionag/Biofuels/Converting Gasoline Engines to Ethanol.htm
  13. Bob in Makiki
    May 30, 2017
    443
    Honolulu
    My concern is not primarily with the fuel system (although the 360 came on the market in 1999, and that is pretty close to the time cars were shifting over to fuel systems able to deal with ethanol) but with the fact that ethanol is hygroscopic. If you don't change the gas in your car by driving it and refilling it, then I believe in Hawaii's humid climate there is a risk that the E10 will absorb moisture from the air.
    I guess the answer to that is just to drive the car more!
  14. spicedriver
    Feb 1, 2011
    3,859
    You would have to go back to the early 1970's to find a fuel tank that's vented to the atmosphere. Newer tanks are pressurized, so they are not exposed to the atmosphere directly. You can also mitigate the moisture problem by simply keeping the tank full. This is especially important for motorcycles, and other vehicles with steel tanks, or they can rust.
    Alcohol is great for increasing the octane rating, but it will eat through some types of rubber, and also can damage fiberglass fuel tanks. Some older motors and boats have been damaged with ethanol in the fuel.
  15. BMW.SauberF1Team
    Dec 4, 2004
    14,244
    +1 If you don't completely tighten down your gas cap, modern cars will have a sensor go off and make the check engine light go off (EVAP leak is the code). That's how good modern cars are with that. I have a car from 2003 and had that recently go off after I forgot to tighten it down...what a PITA to get that code cleared since I don't own an OBDII reader.
