458 - Engine Oil | FerrariChat
458 Engine Oil
Discussion in '458 Italia/488/F8' started by BlackF271181, Aug 24, 2023.
  1. BlackF271181
    BlackF271181 Karting
    Nov 17, 2022
    52
    H.K
    Which is the best engine oil?
    Now using Shell helix ultra 5w-40. Endorse by ferrari. Is it a must to use shell engine oil? Possible for other brands to destroy oil seal etc?
  2. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,429
    redline
    flash32 likes this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,662
    Central NJ
    Dominick
    You will get as many answers as there are oil companies
    Some like Redline, some like Mobil 1 , some like moto .. your pick
    I chose Mobil 1 for all my cars .. wrong / right don't know but easy to get, inexpensive, and seems to be around for ages
    Snapshift and blkdiablo33 like this.
  4. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,951
    St. Louis, MO
    Eric
  5. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,378
    Santa Clarita, CA
    Other brands will not damage oil seals. There are many good oils available. Just use the correct weight for your areas temperature and use a synthetic oil. 0W-40 or 5W-40 are good all locations oil, except for maybe Alaska in the winter.
    Also, look at the API oil rating on the bottle.
    Shell oil is endorsed by Ferrari because of some kind of kickbacks, not because it is any better than any other quality oil.
    anishka, mdrums and blkdiablo33 like this.
  6. blkdiablo33
    Jul 12, 2004
    4,429
  7. blkdiablo33
    Jul 12, 2004
    4,429
    ferrari dealerships all use diffrent oils,my local uses totalbrand i bring redline for them to use 5/40.
    Buzzl likes this.
  8. Boiler Inspector
    Boiler Inspector Formula Junior
    Oct 14, 2017
    347
    Texas
    Brian
    I use Joe Gibbs Driven Racing oil DI40 and send off to Blackstone for analysis.
  9. BlackF271181
    Nov 17, 2022
    52
    H.K
    Locally shell 5w-40 sells for $6/litre. Therefore I'm wondering is it any good for this price.
  10. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,378
    Santa Clarita, CA
    Where is locally?
    I get Walmart.com to deliver 10 quarts ( two 5 quart jugs) of Mobil 1, 5w-40 to my door for $60.
    9650max likes this.
  11. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    I have more track miles in a regular 458 than probably anyone else on here and I EXCLUSIVELY run Royal Purple. There is no better engine oil on the market.
    mdrums and 05F430F1 like this.
  12. Snapshift
    Snapshift Formula Junior
    897
    Centralia IL
    Lyle D. Pahnke
    This topic will give you as many dogmatic answers as there are oil companies squared. AS has been said, there is no one best oil.They are all good, API of SN on rating, 5-40 synthetic, 10 quarts in two 5 quart jugs. Pennzoil ultra premium foamed a lot for me so i have been using Valvoline European formula 5-40 ($29.00/jug at Walmart) and it is fine. Normal temps, no metal ,good analyses, no foam. Your call. You can find as many oil analyses/opinions on You Tube ad nauseam as you want and perhaps get more information and research, but in the long run all major oils are fine IMHO.
    blkdiablo33 and flash32 like this.
  13. wthensler
    wthensler F1 Rookie
    3,473
    Gator Country, FL
    William
    Maybe, maybe not on the track miles (though I no longer track the Spider), and maybe-maybe not on the oil.
    Red Line synthetic oil has a moly content of 950 ppm. Moly is a great additive if you're running hard.
    I run it in the 458 Challenge now.
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,662
    Central NJ
    Dominick
  15. Dicecal
    Dicecal Formula 3
    1,844
    Phoenix, AZ
    Rob
    Penzoil Ultra Platinum consistently comes out on top in many oil comparisons, Amsoil is also very good. If you change the oil regularly, probably doesn’t matter much with any of the top brands.
  16. hgoodwiniii
    hgoodwiniii Formula Junior
    279
    I use Pennzoil Platinum Racing. It's way overkill for my application but now "Recommended by Ferrari" o_O
  17. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,907
    Isle of man- uk
    Where are you based ?
  18. Mrpseudonym
    Mrpseudonym Formula Junior
    585
    Sydney, Australia
    Somewhere where they use quarts
  19. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,907
    Isle of man- uk
    Usually for the beer through
  20. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    William Hensler is the KING of engine oil analytics. Listen to what he says!
  21. Bandit23
    Bandit23 Formula Junior
    250
    Miami
    when I had the 458, I used Liqui moly 10w60 (recommended by my Indy guy)
    kept the engine nice and cool, and also great performance, wasn't tracking it regularly but was very good for daily driving.
  22. SD455TA
    SD455TA Formula Junior
    Something like that sounds real cool, and that is, as long as you can get it, curious about the cost too only because there doesn't seem to be a limit as to what they can charge, you know....sort of like a craft beer too, ha ha. My Speciale calls for 10W60 and I am trying to figure out what to keep in it other than the Shell that is recommended, and to which I might use
    Bandit23 likes this.
  23. SD455TA
    Just looked it up for a moment, oh its very inexpensive so to speak. As long as you can get it year after year, sounds pretty good. To say, I haven't changed my oil yet, so far the dealer has with the Shell 10W-60 so I am thinking that it is probably the best choice because the enigne has been run with it. I don't like mixing oil changes from one to another so I guess I'll figure it out when it is time.
  24. Bandit23
    250
    Miami
    thats great the dealer is putting the 10W-60 Shell stick with that for sure -so they use different oils for Speciale that's super good to know
    i understand they use 5W-40, on the regular models ...
    Yes it's a good option to have when the time comes, my time had come with my 458 so this oil was really good
  25. SD455TA
    Yes my understanding too is the 5W-40. I am thinking in my case, that much like the Antifreeze from Shell that is no longer available is that one day the Shell oil too won't be available.....argh......I have always been a fan of Castrol and if I am going to change, as long as I can get that 10W -60 that is might be my chance to do it. I think that the Castrol will be around where I am not so sure about the Shell products. In your, case you've made the move and long live with that move. Engines and other things in my view are happy with using the same lubricants over and over.
