Engine Noise | FerrariChat
Engine Noise
Discussion in 'Mondial' started by DocBasilone, May 28, 2020.
  1. DocBasilone
    DocBasilone Karting
    Apr 15, 2020
    164
    NW PA
    Hey guys new to Mondial T ownership. I bought 1990 T Cab in March poi was good less ac small electronic issues. Major done 1yr ago. I notice very noisy engine at higher RPM. Reminds me of old VW engines. There is a tap as well that stops with idle. Any suggestions as to where I should start with the work up. Just don’t want to walk into repair shop blind and need to tear down engine. Thanks fir any input
  2. BillyD
    BillyD Formula 3
    1,776
    Pacific Northwest
    Bill
    DocBasilone likes this.
  3. DocBasilone
    DocBasilone Karting
    Apr 15, 2020
    164
    NW PA
    This vehicle had a major last apr but wasnt driven after Im wondering if they didnt set thevalve lash correctly since most of the noise is coming from above
    (I Think) Although the louder exaust sounds good too. :)
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Put a compression test on the engine before you start taking it to bits
  5. Wingnut
    Wingnut Karting
    Feb 11, 2005
    126
    Corolla, NC
    My 1990 Mondial t had a tapping sound after a major engine-out a year ago. The shop did a valve adjustment before I took it home and they silenced the tapping.
    I have as not had any unusual engine noises since.
  6. DocBasilone
    DocBasilone Karting
    Apr 15, 2020
    164
    NW PA
    Is that an engine out job? Can they get to the top? Thanks for the input
  7. Wingnut
    Wingnut Karting
    Feb 11, 2005
    126
    Corolla, NC
    The engine was back in (after the major engine-out) when the tapping was heard. The valves were adjusted with the engine in. Yes, from the top.
  8. Autohaus of Boston
    226
    20 Mill lane Braintree MA 02184
    Mr.Ferrari
    Seriously i cant resist to comment on this, where are you guys having this cars serviced ?? valve train noise after a major service unbelievable makes me wondering hows working on this cars.
    ronfrohock likes this.
  9. Subito Grigio
    Subito Grigio Formula Junior
    Jun 2, 2009
    329
    OK, ok. Just in case: My ‘83 QV Cab began a serious tapping noise a few years ago. Sounded metallic and drove me nuts! Found a thread here somewhere and talked to Dave Helms about it. Unbelievably, one of the very accessible belts was snapping due to temperature or prolonged sitting. It was easily fixed. If you didn’t know this - now you do! SG
    DocBasilone and ronfrohock like this.
  10. ronfrohock
    ronfrohock F1 Rookie
    3,939
    MA
    Ron Frohock
    Yes, it’s a terrifying sound. Like a clap of lightning over and over until the belt stops making the noise.
    To diagnose, you can spray a small amount of belt dressing on the Accessory belt and start the car. If the noise stops, you know the problem.
  11. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    409
    Eastern Tennessee
    Howard Scott
    I had the same dreaded belt noise. Sounded like gravel in a blender. Easy to fix.
  12. djs308
    djs308 Formula 3
    1,100
    Long Island, NY
    David S.
    Reviving this conversation as my car is now doing the same thing. Cold winter weather start after sitting for a couple of weeks. Getting the "ominous" metallic tapping sound. Definitely seems to be in the area of the belts, but no idea which one. After the car idles for 3-5 minutes, the sound goes away. The car drives fine with no other weird noises. My car had belts adjusted back in December and I've driven it sparingly since.
    What is the recommended type of adjustment or treatment for the belt(s)? I'm not mechanically inclined but sense this may be a DIY project I can handle.
  13. Steve Magnusson
    25,123
    #13 Steve Magnusson, Mar 6, 2021
    If nothing seems obviously wrong visually, I'd start with applying some spray V-belt dressing to the V-belts and see how long it keeps the cold-start-up noise away (you should be able to do this without needing to disassemble anything by spraying into a pulley-belt tangency location at idle). You can't use a V-belt dressing daily/weekly, but applying it every 3~6 months would be no sin IMO.
    djs308 likes this.
  14. ronfrohock
    3,939
    MA
    Ron Frohock
    Great advice Steve as always.
    I had the same problem. It turned out to be the AC belt. I had it replaced and it’s been fine since.
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Horrible stuff belt dressing, banned where i used to work.
  16. Steve Magnusson
    25,123
    #16 Steve Magnusson, Mar 6, 2021
    Good for you :rolleyes: -- I'm sure you worked on many engines that used plastic V-belts on a badly-designed, way-too-low-wrap-angle idler pulley, large V-angle pulley belt paths. Bless your heart...
  17. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Encourages bad engineering, some at work saw it as a way to avoid the job of changing the belts. Mind you these were a lot bigger on industrial units.
  18. Steve Magnusson
    25,123
    #18 Steve Magnusson, Mar 6, 2021
    And completely different in design -- using belt dressing to solve a problem on a rubber V-belt with a 6 deg pulley groove angle with a well-designed belt path is probably a bad idea just masking a real problem (as a 6 deg angle V-belt virtually self-locks into the pulley and never slips or moves vertically relative to the pulley). A plastic V-belt with a 60-deg pulley groove on the poorly-designed 308/Mondial AC belt path is a completely different animal (more like a flat belt). But feel free to keep applying your unrelated experience to every other different belt design.
  19. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Being retired i dont need to- its great letting others have the hassle these days
  20. djs308
    djs308 Formula 3
    1,100
    Long Island, NY
    David S.
    I've had my accessory belts all changed within the last 3 years. Is there a recommended changing interval based on time/mileage for those?
  21. moysiuan
    moysiuan F1 Rookie
    3,644
    Canada
    The belts should be checked for tension after the first year from change, they will have loosened up a bit. Most would change at the time of a timing belt service, usually every 5 years would be a typical interval for that. The ac belt does have that plastic spine inside, and can crackle and tick especially at cold start after only a year or two. Proper tensioning the belt would help solve for this.
    Sent from my BBF100-2 using FerrariChat.com mobile app
