360 - Engine mounts replacement at 5 years? | FerrariChat
360 Engine mounts replacement at 5 years?
Discussion in '360/430' started by 550nitis, Feb 25, 2021.
  1. 550nitis
    550nitis Formula Junior
    Feb 3, 2016
    715
    Houston
    Prior to me buying my 360 the engine mounts has been changed about two years prior. I've had the car 3 years now. Took the car in due to some odd vibration at idle and a horrible low frequency noise. Shop says the mounts are done and are on the secure metal tab. thought they lasted more than 5 years. Anyone had to exchange them around this time?
  2. BDubbs
    BDubbs Karting
    143
    WA State
    B Dubbs
    I am by no means an authority on the subject, but since no one else chimed in- I believe they are a common wear item. I dont know the typical replacement interval, but I bought my 360 a little over 2 years ago and the PPI said it needed replacing. This was a car that was maintained with an open checkbook and zero deferred maintenence. It was a 1 owner car(til i bought it...) its getting an annual service now at FOS.... if they mention it, I'll let you know!
    Sent from my SM-N975U1 using FerrariChat.com mobile app
  3. Vegas CS
    Vegas CS Formula Junior
    967
    Vegas
    James
    I don’t have my CS’s maint records readily available so I don’t know when/if they’ve been changed. Las Vegas Ferrari service showed me my mounts in person and I’ll be replacing them and the cracked trans mount during my next major this summer. May try the Challange mounts. The CS was built on the race car assy line so I don’t mind the extra noise and vibration.
  4. BrettC
    BrettC Formula 3
    Aug 13, 2012
    1,970
    Calif
    Brett
    my 04 360 spider has the original mounts at 45K miles....hmmm. Guess I will take a look next service but no vibration/issues I can detect.
  5. one4torque
    one4torque F1 Veteran
    5,090
    Houston
    One4torque
    Can be a function of how car is driven.
  6. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,280
    San Jose
    dc
    The stiffer mount is like ~$60 each. Just go replace them. Replacing the mounts should increase the rattles at idle. Often the exhaust valves (see spring fix thread) or engine panels (tighten bolts or add larger washers)
  7. imahorse
    imahorse F1 Rookie
    2,648
    WI
    Dustin
    If your upper trans mount is shot I could see that causing the engine mounts to fail that much faster.
  8. 550nitis
    Feb 3, 2016
    715
    Houston
    The ja guys for the feedback. It's going in on Friday. Will keep posted.
  9. vmule
    vmule Karting
    51
    Vito M
    where do you find the stiffer mounts? Thanks
