Engine hoses ,clamps, vacuum lines | FerrariChat
Discussion in '308/328' started by Austin Newman, Oct 21, 2020.
  1. Austin Newman
    Austin Newman Karting
    Dec 18, 2019
    229
    Memphis
    Austin Newman
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    I buy them at Oreily's
    Your air filter housing needs to have the silkscreening done if you are picky about hoses and clamps.
  3. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    I buy the clamps at West Marine.
  4. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,396
    Toronto / SoCal
    Rob C.
    Be aware that new is one thing and historically or 'concours' correct is a whole other thing.
    If you want new then the European style gear clamps from companies like Norma, Gemi, or Zebra are all excellent options. Many of these are available from McMaster Carr
    If you are after concours points then your best bet is to remove what you have (assuming it is original and correct) and then have them carefully restored. If you are missing anything then you will have to source some old clamps and have those restored. Historically correct NOS clamps are near impossible to find so you will go down the restoration route. Expect this to cost many times more than new clamps
    Lastly, don't for a moment think that if you order clamps from Ferrari you will get what the car came with. They will send you a replacement that fits and works well but is no different than sourcing out your own clamps.
    As for hoses, original looking replacements are available but you will first have to research what is correct for your car before hunting down replacements.
    Brian Harper and Andy 308GTB like this.
  5. Austin Newman
    Dec 18, 2019
    229
    Memphis
    Austin Newman
    Where can we source the braided style hoses?
  6. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,463
    Tulsa, OK
    John McDermott
    Belmetric is another good source for hose clamps.
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    10,650
    CT
    John Kreskovsky
    And hoses.
  8. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,396
    Toronto / SoCal
    Rob C.
    Smaller diameter metric braided hoses are the same as used in some VW applications. I get them by the roll from Wurth.
    Larger diameter braided hoses are available from Aeroquip and can be bought from many industrial and hydraulic manufacturers by the foot.
    Alternatively T Rutlands should have most of these hoses available too.
  9. moysiuan
    moysiuan F1 Rookie
    3,638
    Canada
    Don't throw away old original clamps. They are quite valuable.
