Engine cylinder temperature question - Left vs right bank | FerrariChat
Discussion in 'Technical Q&A' started by BlueBiturbo, Jan 30, 2015.
  1. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,968
    Jakarta
    TS
    I have an LM002 with a bad ECU and change it to Haltech PS2000 with 12 Exhaust gas temperature sensor for the V12 motor.
    Is it normal that (at 900rpm idle) my left bank shows 200C while the right bank shows 400C ?
    Both banks shows same temperature once it is past above ca 2,500 rpm.
    Anyone care to share their opinion.
  2. JL350
    JL350 Karting
    Jan 20, 2013
    211
    May I suggest you add a bit more detail so the answers are more relevant to your problem and not just what other people had happen.
    Is this only a problem on startup and warming up, ie goes away when at normal operating temperatures, or returns once cooled down at idle.
    I think I recall that you had fuel fuel consumption issues that would worry a Saudi prince, is this the same with the new ecu?
    Is the one ecu controlling both banks?
    Is there one fuel pump or one for each bank? Are they operating at the correct pressure and flow, ie not just the dead head pressure, as a restriction would give the right pressure at dead head pressure with no flow, but at flow would give low pressure if the blockage is before the pressure measurement point...
    Timing, has it been checked that the spark is firing at the right time for both banks. This can be an issue if cam timing is out between the banks and the timing is inferred for one bank. Ie timing set on number one cylinder but a resulting error on the other bank of six degrees could cause issues.
    Injectors ok? Sounds like they are as you said only the banks have the temperature differential, one cylinder could cause a problem, unlikely but need to eliminate.
    Are there any afr sensors before the catalytic converters or just the temperature sensors?
    Coolant temperature sensors ok, I assume there is only one, thermostat checked and ok?
    Knock sensor connected and ok?
    EFI fuel map, need one of these, and presumable configured for the v12.
    No air or vacuum leaks in the inlet side to the motor, or exhaust manifolds?
    At the stoichiometric ratio of air and fuel the exhaust temperature is the hottest, either side will cool the gases. Typically run a bit on the rich side to keep temps down and help avoid detonation.
    Timing has a similar effect, fire too soon and more heat is absorbed by the cylinder head, fire later and more heat escapes to the exhaust. Again want to get timing in the right area so that combustion does not happen in the exhaust manifold, but also where detonation is not going to occur.
    EFI will start up in open circuit from a cold start, ie while the coolant temperature is below optimum levels. A fuel map with no correction is used, so basically the air flow meter reads the air flow and fuel is added in a ratio. For this case there is no correction to the fuel ratio based on the measured oxygen in the exhaust gases. A potential fuel supply issue or timing issue will cause the banks to run at different exhaust temperatures.
    Once the coolant temperature gets to the normal operating zone the the EFI goes into closed circuit using the oxygen sensor. This tweaks the fuel addition based on oxygen levels in the exhaust gases. If the temperature differences are occurring in this mode, then it may be an oxygen sensor on one bank which is slightly contaminated causing a slower reading response time, or slightly incorrect reading.
    The temperatures should be reasonably close together if both banks are doing the same thing, and there is no extra cooling of the exhaust on the cooler bank prior to the temp measurement.
    I think something is not quite right and a process of elimination will sort it out. The fundamentals of air, fuel and spark need to be right, but it can be a pain in the arse to find the little problem that screws it all up.
    Good luck with it.
  3. rmarchjr
    rmarchjr Formula Junior
    May 21, 2012
    586
    North east, USA
    +1 JL350 nice detailed post, not ur 1st rodeo.
    I agree completely, lots of variables to sort. But in general no- all exhaust temps should be very close to each other 25-50 deg F (on my F cars it is less then 25 after warm up-8 cyl cars) when an EFI system is working properly.
    Something is not right.
    Good luck.
  4. Rifledriver
    36,754
    General rule on that design is if a problem of that nature exists on one bank and not the other there is a very high probability of a cam timing issue.
    Most LM's have had upper chain and tensioner replacements and the incidence of being incorrectly timed is very high.
  5. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Thanks for the suggestions,
    Our number 1 suspect was also the timing issue.
    Currently the LM is grounded due to leaky radiator and we just finished building a new radiator today.
    We will check again one by one for all the possible errors.
    When we had the car, the ECU fail within two weeks and we did not have a chance to measure the "before" fuel consumption.
    The old OEM ECU is TWO units, one for each back, now the ECU is Haltech PS2000, controlling all 12 cylinders.
    All 12 injectors are brand new Marelli OEM spec, the fuel pumps are Bosch 044 fuel pumps which we have the fuel pressure meter for each and they are OK.
    AFR of the right and left bank is the same.
    The car is OEM with no cats and we install 12 Exhaust Gas Temperature sensors on the top of the headers.
    Will restart the car again tomorrow and see the temps of the left and right bank.
    Thanks.
  6. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #6 BlueBiturbo, Mar 9, 2015
    Engine test last night.
    Turns out the problem of low left bank exhaust temp was the ignition wires are too old (for the whole left bank).
    We made new wires, and test the car last night.
    New problem emerges, the cyl 4,6 temp is a bit low, and surprisingly cyl 10 and 11 is dead. There is spark but I guess there is no fuel. Gotta check the injectors on 11 and 12 (all 12 Marelli injectors are new) again tomorrow.
    We were already tired at 10:30 pm so hopefully today we will find the fault once and for all.
  7. JL350
    JL350 Karting
    Jan 20, 2013
    211
    Good to see some progress, can be a long slow process of elimination. If it were me, I would replace all of the ignition leads and spark plugs if you are not 100% sure they are ok. Can be the really annoying source of an intermittent problem...
    Was it running this bad before the rebuild? The afr reading being the same for both banks maybe a little misleading at idle with two cylinders reading low temps... Maybe more indicative of issue over a range of engine speed and load.
    If you have an infra red temp gun it may pay to check the probes are reading ok, just so you can rely on the readings.
    Anyway you guys seem to be working through it, best of luck.
  8. Markphd
    Markphd Formula Junior
    Mar 10, 2012
    713
    I was going to say, that's not so surprising, as Rifledriver noted many times a difference between banks is timing related, but when the difference is that big (200 F) it's more likely a dead cylinder than anything else. Glad you are on the path to resolving it. If it were me, I would consider going to a COP setup to eliminate the spark plug wires which tend to be a wear item.
  9. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #9 BlueBiturbo, Mar 11, 2015
    Yesterday one of the Haltech coil went dead. This was the second dead coil in 6 months.
    This time we got a replacement for free.
    Here is my ignition setting :
    Spark mode : Twin Distributor
    Spark edge : Falling
    Trailing spark edge : Falling
    Dwell mode : Constant change
    Trailing Dwell mode : Constant change
    Dwell time : 5.000 ms
    Dwell duty : 70%
    Ignition lock : Disabled
    Lock timing : 0.0
    Lock split timing : 15.0
    The Haltech forum suggested the dwell time decreased to 2.5ms and up to 3.5ms max.
    Tonight we checked all the 12 brand new NGK iridum DPCR9-EIX9, replace 4 or them which were black due to rich fuel setting.
    Setup the throttle body in each bank and voila ! Now the engine is even between left and right bank.
    Finally !
    It sounded like a V12 Lambo should. Idles better and revs up very quick.
    Still has a rich fuel setting which we will tune tomorrow, but other than that everything is perfect.
    23 months of rolling restoration is finally done.
  10. JL350
    JL350 Karting
    Jan 20, 2013
    211
    Good stuff. Now you can enjoy it.
  11. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Thank You JL350.
  12. Rifledriver
    36,754
    I tend to leave the Italian cars mostly stock, at least visually, but I agree. When I do change something I hide it. If you are going to a custom set up there are many advantages to a COP and I would have probably gone that way.
    On the Lambo there is that great screw in tube that would be easy to convert to hold a coil.
  13. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    Coil on Plug will is my consideration for next mod.
    Anyone have a link on how to convert old LM002 /countach engine to COP ?
  14. Cribbj
    Cribbj Formula 3
    I build COP systems for the 550 Maranellos, but am not familiar with the Lambo engine layout or its plug wells. There's 2 important considerations for you when converting a 12 cylinder engine to COP using the PS2000:
    1. You'll need 6 channels of ignition output to run a 12 cylinder engine in waste spark. This is possible with the PS2000, but it has to sacrifice 6 channels of injection to do it, so you'll no longer have sequential injection (one channel for each injector) but will have batch fire injection, where you fire 2 injectors at the same time. Perhaps Haltech offer a multiplexor expander module (as MoTeC do) where you can expand the number of ignition channels?
    2. The Haltech uses external ignitors (high current switches for charging the coils), so you can use "smart" coils, which have the ignitors within the coils themselves, however they're a bit taller than "dumb" coils without the ignitors. How much space above the valve covers do you have for the "head" of a coil to stick out? This is a limitation on our 550's as too high a coil will foul the throttle linkage on both heads.
  15. Rifledriver
    36,754
    Well you can see one today and I'll show you what I mean about mounting the coils.
  16. Cribbj
    Cribbj Formula 3
    #16 Cribbj, Mar 21, 2015
    The pics below show what Brian was referring to. The Lambo engine has these sparkplug tubes that serve double duty as valve cover hold downs. Very cool way of doing it, which leaves more surface area on the valve covers for sealing to the head. Wonder if Lambos have better valve cover sealing than Ferraris?
    Anyway, it looks like there'd be plenty of room to fit a smart type COP in there, but a little R&D would need to be done on coming up with a suitable weather proof boot for it.
    I noticed that the plugs looked very close together, and learned that the bore spacing is only 95mm (vs 98mm for our 550's)
    Brian was kind enough to loan me his Diablo WSM, so after some bedtime reading last night, I learned the Lambo's firing order is:
    1-7-4-10-2-8-6-12-3-9-5-11
    And the cylinder numbering begins at the left rear (when facing flywheel), and goes sequentially down the left bank toward the front, crosses over and continues down the right bank. So 1 & 12 are at the rear, and 6 & 7 are at the front. Also interesting that the Lambo has reverse rotation when compared to the Ferrari. It's CCW when looking at the front of the engine.
    Last pic is (L-R) Ferraridriver, yours truly, & Rifledriver, having some BBQ over in Austin yesterday (pic is a little overexposed - likely because of all the flash bounce from the heads without hair :))
  17. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #17 BlueBiturbo, Mar 21, 2015
    Hi John,
    Is this the Carburettor LM engine?
    On my FI LM002 the no 1 cyl engine is front right (where no 7 is in Your picture).
    No 6 and 7 is near the firewall, no 12 is left cyl bank nearest to the radiator.
    My firing order is :
    1 - 7 - 5 - 11 - 3 - 9 - 6 - 12 - 2 - 8 - 4 - 10
  18. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #18 BlueBiturbo, Mar 21, 2015
  19. Cribbj
    Cribbj Formula 3
    Interesting; your cylinder number seems to follow the Ferrari convention.
    The engine I was looking at in Brian's show was a Diablo injected version, and it's called the L522. Perhaps it's only similar to yours, but it's odd that Lamborghini would number one of their V12's one way, and a different model a different way?
  20. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    I think mine is L510 since my engine no is L5101084
  21. Cribbj
    Cribbj Formula 3
    Just a correction/clarification on what I said earlier. I'm looking at a Diablo WSM, but can't confirm it's actually a Diablo engine in the LM002. After a bit of research on this, there's evidently a lot of opinions out there by people a lot smarter than me on whether the engine is based on the Diablo, Countach or is perhaps even a 3rd variety. The Diablo is a CCW rotation, as confirmed by its odd firing order which is a 132 phase sequence. Yours is CW, as confirmed by your 123 phase sequence.
    This is not to say Lamborghini couldn't have thrown a special set of cams in a Diablo motor and ran it backwards (for them) in a normal front facing, rear mounted flywheel configuration for this truck. :)
    At any rate, a COP setup could be done in that engine with your current ECU, if you're willing to sacrifice some of the injection capability that you have now.
  22. BlueBiturbo
    May 19, 2004
    3,968
    Jakarta
    TS
    #22 BlueBiturbo, Mar 22, 2015
    Hi John,
    According to the Lambo gurus, the LM002 EFI engine is different than the carb version. This is a combo of special LM block, Countach QV internals and early Diablo LIE EFI system, and rotates clockwise.
    I will talk to the Haltech distirbutor down here to discuss the possibility of COP.
    Cheers,
    Taffy
