Engine compression ratio vs. Fuel octane | FerrariChat
Discussion in 'Technical Q&A' started by Tifoso1, May 6, 2005.
  1. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,600
    Pacific NW
    Anthony C.
    Just noticed that the Testarossa's engine is set at a compression ratio of 8.8:1, not trying to be cheap or anything like that but I have read somewhere that the type of fuel a engine should run on (87, 89, 92, 93 etc) depends on what the compression ratio is. Meaning, if it's ratio is low, you will get no benefits by running a higher octane fuel and it can also cause it to run not as smooth. Is this correct?
  2. Steve Magnusson
    26,506
    Don't know about the "smooth" part, but using a fuel with a much higher octane rating that spec'd by the vehicle manufacturer is unnecessary and of no operational benefit IMO.
  3. TimN88
    TimN88 F1 Veteran
    Jun 12, 2001
    5,054
    Northeast
    Tim
    What does the manual call for?
  4. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    What ever you can get by with while avoiding the (ping), all aluminum motors can safely utilize one full compression ratio than iron blocks with alum. heads. It all has to do with heat removal from the combustion area, also keeping the motor reved to avoid lugging protects against pinging.
    Gary
  5. Steve Magnusson
    26,506
    The US TR OM fuel spec is 91 RON minimum (which is about 86 AKI minimum as marked on US gas pumps) -- the 87 AKI minimum grade is plenty good.
  6. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    I agree with Tim. Check the manual. It will tell you what octane you need. Running higher octane does not produce more power, despite what the TV ads from the oil companies seem to suggest. If you are running 93 octane now, try going to 89 for a tank or two. If the engine pings, go back to the 93. Chance are, it will run just fine.
  7. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    The additives to increase octane are designed to prevent pre-ignition. The higher the compression ratio, the more chance of pre-ignition. This means that the heat generated by compressing the mixture in the cylinder gets the mixture hot enough to ignite before the spark plug ignites the mixture. The problem is that the mixture may start to burn before the piston has reached the top of its stroke, and so the explosion is fighting the engine, trying to push the piston down while its still coming up. VERY bad for the engine. You hear it as pinging or knocking. Bad enough and it will wreck your engine.
    Using a high octane fuel with additives to decrease knocking in a low compression engine that doesn't need it will not harm anything, it's just a waste of money. Many people are under the false notion that high octane fuel is somehow more "powerful" or contains more ability to make power than low octane fuel. No. In fact, you could argue the opposite. High octane fuel has additives that make it harder to ignite so it won't pre-ignite on its own. Lower octane fuels actually burn easier. Therefore, you get the most bang for your buck (pun intended) by using the lowest octane that makes your engine happy. I use regular unleaded in my 308. The 8.8:1 compression ratio is considered pretty low compression by today's standards.
    The gasoline companies actually add detergents to the more expensive fuels as well in an attempt to get people to buy them. You have heard the ad campaigns ("Drive your engine clean..."). The solution to that is to buy the cheap gas and run a bottle of techron injector cleaner through the car once a year.
    Birdman
  8. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    This is both right and wrong. High octane fuel IS harder to ignite; Fuel for the Blackbird spy plane is so high octane you can throw a lighted match in it at sea level and it will extinguish the flame. So why use it?
    High octane fuel has more energy per gallon than low octane fuel; more oxygen. So with a higher compression ratio and correctly set engine you will get more HP. Put regular in a 10.5 Compression engine and even if it doesn't knock, it won't go as fast. If you retune your car that uses regular to be able to utilize the higher octane you will get more power, but of course putting premium in a car built for regular IS just a waste of money without modifications.
    Ken
  9. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,600
    Pacific NW
    Anthony C.
    I also did a little research on my own on the net, and came across this site:
    http://www.theserviceadvisor.com/octane.htm#1
    I guess a potential harm by using a higher octane fuel than the engine is set for is on the Catalytic converters. Thank you all for answering, I know what I will be using the next time I am at the pump. I am trying not to think about how much money I had wasted since 1991.....
  10. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Regular Jet-A (or even gas) can extingish a match, that's an old parlor trick related to the fact that you have to have the vapor to ignite fuels. However, that fuel for the SR-71 WAS very special stuff, my Dad had some stories to tell about the requirements for it!
    But as for high octane fuels having more energy and the implication that more Oxygen is responsible for that, well, that is, at best, a game in semantics. When we're comparing differences in heating values of ~1.5%, when variability in fuels of the same grade is half of that, it's quite a stretch. Adding Oxygen actually decreases the energy content of fuel; you can increase the quantity introduced to get the power back, but adding oxygenates by itself displaces hydrocarbons with Oxygen, so the engine tuned to run on "pure gas" with a stoichiometric ratio of 14.6:1 will run lean with oxygenated fuel.
  11. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    There are a number of reasons to not run premium in a regular car, but worrying about it "collecting in the cat" shouldn't be one. #1 is simply economics. #2-41 are also economics. #42 would be driveability and it goes down from there. Because of the increased resistance to knocking that premium offers, as has been cited, premium is harder to ignite than regular. This has caused driveability problems in the past, but cars are tuned now to be sure they'll run well on "high DI" (you can do a google search on "driveability index" if you want to learn more) fuels.
    I looked at the site referenced and, despite the fact that fuel makers have been distinguishing their premium blends for a long time (maybe not in 97? Not like I remember!) by their increased detergency, he claims there's no need to buy premium for added detergency.
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    When high octane meant literally a higher percentage of octane molecules (long-chain molecules that had a higher ratio of carbon to hydrogen atoms than the lighter hexane or pentane), then high-octane did indeed have slightly more energy. Diesel & Jet-A contain a high % of much longer chain molecules, thus have even higher energy density than octane
    However, ever since the advent of cheaply boosting a gas's ping resistance (aka 'octane') by adding tetraethyl lead, and it's successors, including some alcolhols, the energy density of gasolene has had almost nothing to do with it's octane rating, and everything to do with it's resistance to prematurely detonating.
  13. ham308
    ham308 Formula Junior
    Nov 3, 2003
    358
    NE Switzerland
    Richard Ham
    It is definitely correct that an 8.8:1 compression engine will run OK on low octane fuel.
    However, being a) not confident of hearing pinging over all that er, music, b) having seen more than a few pistons burnt completely through and c) it's my baby, - I run my 308 on higher octane fuel which here is only a little more expensive.
    (I also put in lead substitute which may prevent exhaust valve seat and guide wear).
    Richard
  14. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,600
    Pacific NW
    Anthony C.
    Not trying to beat this topic to death, but just happen to be looking over the owner's manual and noticed on the inside of the front cover (US version) it states the following:
    This automobile is equipped with catalyst: Use unleaded fuel only (Recommended: Premium unleaded)
  15. sjb509
    sjb509 Guest
    Something else to think about is how they raise octane ratings by adding oxygenting agents like ethanol in quantities around 10% blended with gasoline. Ethanol only has about 50% of the available chemical energy per unit volume as does gasoline.
    Therefore for a gallon of blended fuel:
    .90 x 100% + .10 x 50% = 95% of the available energy compared to full 100% petroleum.
    Depending on the combustion chamber design 8.8:1 may require higher octane fuel to prevent detonation, while for a different design 10:1 may run fine on 87 octane. There are too many variables to make a hard and fast rule. FWIW, I found my old Ducati (11.6:1) actually ran cleaner on 89 octane than the 93 I had used for years.
  16. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,600
    Pacific NW
    Anthony C.
    Great point, I guess we shouldn't just go by what the compression ratio is on the engine, will stick to what the factory suggested. Thanks.
  17. Hubert
    Hubert F1 Rookie
    Jan 3, 2002
    2,642
    The Left Coast
    Run 87.
    You'll be fine.
    You don't need 91 until you're at a static compression ratio of AT LEAST 12:1.
