Engine Bay Heat and Muffler Heat Shield | FerrariChat
Discussion in '360/430' started by Brambleworth, May 8, 2011.
  1. Brambleworth
    Brambleworth Formula Junior
    388
    NY
    Ted
    Recently somewhere in this forum I saw a 430 owner that built a CF heat shield/wall between the muffler and air box assembly. I bought my spider about 2 months ago and have been really surprised at the huge amount of heat in the engine bay when I park it, sometimes I leave the hatch open for a while. So I have a few questions for the experts.
    1. We all know that heat absorbed by the air box will lower charge density and HP. Is it reasonable to assume that CF air boxes hold less heat? I heard they lack a horn inside which I guess accelerates charge air flow speed. Has anyone had a problem with the CF boxes cracking easily under the screw? Can you use stock paper filters with CF boxes? The oiled filters are a pain to clean and oil in my experience with other vehicles and boats.
    2. In trying to reduce air box temps, it would seem logical to put a heat shield between the muffler and the air box. There are some great products out there that could be used, remember how great the gold foil looked in the McLaren engine bay? Has anyone experimented with a heat shield in this location?
    3. Would a heat shield between the muffler and air box screw up airflow in the engine bay as designed by Ferrari? Since the coupe came first, one would assume that the aero and cooling guys got it right, flowing air properly, it would seem that the spider had to be a compromise. The engine bay has less area above the engine and fewer vents in the hatch at a lower, flatter plane. Does the air flow in through the hatch and out the back or from the bottom and then out the top and rear? I have only been under 430's at the dealer that had the bottom tray removed so I couldn't see if there are any vents, scoops or NACA ducts under there, does anyone know? I assumed the bottom is flat the help the rear diffuser do it's job properly. So how does the air flow?
    4. Being an aircooled Porsche guy, I find it odd that there isn't a fan of any type in the engine bay or the rear grill. I know water does the job here and there are fans up front. Has anyone added electric fans to the rear grill?
    5. Does anyone with a coupe have a problem with fogging the rear glass when the cabin is cool and the engine bay is hot?
    I would really like everyone's opinion on the idea of building a heat shield forward of the muffler.
  2. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    I wouldn't worry about it unless you have exhaust mod. My Capristo muffler is position a lot higher and closer to the air boxes. It melted the K&N filters, so I had to go back to factory paper filters. the heat also warped the center brake light. My sports cats are also very hot, I like watching it glow in the dark, wondering which rubber component will melt next.
  3. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Interesting topic!
    Regarding the paper air filter in a CF airbox, no problem at all. Although, I don't know if CF airboxes build up less or more heat than the stock airboxes. The main reason I keep the stock airboxes are the horns.
    The only way to find out how much the muffler heat affects the air temperature in the intake would be to mesure it. It's something I'm going to do soon by building up a graph comparing outside temp, temperature at the air intake, speed at the wheels, water cooling temp and oil temp + average load/revs. This would show the impact of the temperature of the air flow in the intake when the engine is at full load. Full load with little speed would bring a higher temperature in the engine bay as the air flow there would be reduced. A drive test uphill on a mountain road would be a good candidate for such test as the speed is quite reduced but with an engine running at max load.
    It's difficult to predict the impact of a heat shield between the muffler and airboxes. It may help direct heat on the airboxes but it may reduce the engine bay air flow. It may build up also more heat around the muffler. That's why I installed the Capristo remote control so that I can control the exhaust valves myself. With the valves open, exhaust gases take a direct route and the difference of temp in the engine bay is greatly reduced.
    I've been thinking already to install air fans at the rear. I would be useful when you're stuck in trafic jams with high outside temperatures. But there are not easy to install as you'll have to build up a frame to support the fans. And all this is pretty close to the muffler so I'm not sure the fans would support such heat. But the Italia has now fans there, so maybe I need to give a deeper look how they made it.
  4. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    #4 Ingpr, May 8, 2011
  5. lilleprins
    lilleprins Formula Junior
    Apr 19, 2010
    446
    Torslanda , Sweden
    Anders T.
    Been thinking in the same direction. Maybee large computer cooler fans. Would be great to be able to cool the F1 pump also.
    //A
  6. Russell996
    Russell996 Formula 3
    Sep 24, 2010
    2,263
    New Forest UK
    Russell
    Ferrari's own CF air box upgrade keeps the horns, no idea on temperature issues.
  7. ttdang123
    ttdang123 Formula Junior
    Nov 28, 2009
    706
    North San Diego CA
    Tung
  8. lilleprins
    Apr 19, 2010
    446
    Torslanda , Sweden
    Anders T.
    I think we need a Pusher fan and the smalles were 11 inch. To large. Will have a look tomorrow.
    //A
  9. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Interesting website, need to be studied. It's just a pity that their catalog download doesn't work :(
  10. lilleprins
    Apr 19, 2010
    446
    Torslanda , Sweden
    Anders T.
    Quick note : They have the old noisy fans. Newer ones must hace "swept" blades to be quiet.
    Take a look in your computer.
    // godnight
    A.
  11. ttdang123
    Nov 28, 2009
    706
    North San Diego CA
    Tung
    I downloaded it OK from here: http://www.fluidyne.com/technical-center.html (8M file).
    If you can not download then I can try to send it to you through yousendit.com BUT will need an email address from you.
  12. ttdang123
    Nov 28, 2009
    706
    North San Diego CA
    Tung
  13. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    Don't you think Anders that an extractor fan would be more efficient to extract the engine bay heat?
  14. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
  15. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,805
    If you have a challenge grill one could mount several cooling fans. Direct the air outwards?
    Would you be able to get sufficient airflow through the relatively small holes in the challenge style grill? The grilles for the challenge race cars and CS have a larger bore hole, I think?
  16. anxpert
    anxpert Formula Junior
    Mar 4, 2008
    970
    Oceanside, CA
    Enrique Mar
    3" Bilge Blower Fans for boats flow about 100CFM, are waterproof anf relatively inexpensive. It seems as though there is plenty of space in the void above the exhaust pipes, which already has a heat shield.
    They do draw about 3 amps, but used with a thermostat / timer the fan(s) would create quite a bit of air flow with .
    http://squirrelcageblowersale.co.cc/johnson-pumps-of-america-54124-bilge-blower-marine-flange-mount/
  17. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    #17 Trent, May 8, 2011
    I agree to look toward marine fans for this type of application. I used some similar to this to cool an intercooler once. They are VERY powerful and somewhat efficient at 230cfm from 4.4A in a small moisture tolerable package. Also inexpensive from $27 to $35 (water resistant). I have used the water resistant ones and you could spray them with a hose. These fans will blow your hair back from across the room!
    http://www.twinsrecreation.com/fs365082.html ( not the ones I have used, but similar, many brands / vendors out there)
    I did a bit of research on what the challenge racers use and it "appears" to be similar units. Here is an image. I love the carbon 6" intake hoses, too bad they feed a 1" restricter pipe.
    2x fans blowing toward the top vents.
    1x Fan Y Piping from the header area.
  18. MalibuGuy
    Sep 18, 2007
    5,805
    Might improve the aero by filling a low pressure region at the rear of the car?
  19. MalibuGuy
    Sep 18, 2007
    5,805
    #19 MalibuGuy, May 8, 2011
    Another approach would be to use the small computer fans in the slit grill next to the rear deck glass.
    Again could improve aero by disrupting boundary layer and reducing drag
  20. ttdang123
    Nov 28, 2009
    706
    North San Diego CA
    Tung
  21. MalibuGuy
    Sep 18, 2007
    5,805
    Those water proof fans look excellent for this application. Hopefully they can withstand the heat cycles.
  22. 4RE RaCer
    4RE RaCer Rookie
    Mar 6, 2004
    46
    California
    KT
    #22 4RE RaCer, May 8, 2011
    Just found this thread... I have thought about adding Heat Shields for my 360 speed for a long time. I also wanted to clean up the look of the rear engine bay area. My car is a six speed and I bought the c.s. rear engine bay tins. The rear engine bay tins did not fit my car exactly and the right side had a space for the F-1 pump. I decided that this was not an appropriate fit for my car. So off to the local fabricator for some custom work.
    I had four pieces designed and fabricated for my car. It has reduced the under hood engine temp by at least 100 degrees. It also happens to look alot cleaner in the engine bay area. I hope that you like the results. I might also add the fans after somebody has done some testing.
    AHudson likes this.
  23. anxpert
    Mar 4, 2008
    970
    Oceanside, CA
    Enrique Mar
    Very good possibility that you will experience a variety of failures in the future.
    Utilizing a heat shield between the exhaust and air box can possibly have the advantage of providing a cooler intake charge, thus in theory increasing horsepower.
    In completely covering the exhaust area, you will be concentrating an enormous amount of heat in a reduced space which is already void of cross ventilation.
    Do realize that besides the wiring looms, there are multiple parts that will be subjected to much higher temperatures, including your transmission mount and transmission oil lines.
    While it is true that the the engine compartment gets hot, it is well within the parameters calculated by many Ferrari engineers.
    Once you get stuck in one of our typical California bumper to bumper freeway commutes you will cook something.
    Looks over functionality is not a good formula .... !
  24. 4RE RaCer
    4RE RaCer Rookie
    Mar 6, 2004
    46
    California
    KT
    #24 4RE RaCer, May 9, 2011
    Well maybe I should have showed all the parts that went into making the shield. There are four sections which box out the exhaust area. Exhaust system is now in its own separate compartment. I believe that the wires that are around the rear lights and the engine compartment will be cooler as a result.The side pieces are just like the challenge stradle ones.I will enclose some more pictures to show that this is not just a cosmetic change. I was just putting my project out there for you to see.
    The first picture is the bottom of the shield, the second is the top and the third is the side. I can possibly see your point for added airflow of the exhaust , so I do have the option of removing the top portion if I want. I do have a challenge rear grill on my car, and a bi-valved capristo.
    Thanks for the comments.
