Emergency fuel door release? | FerrariChat
Discussion in 'California/Portofino/Roma' started by SciFrog, Jul 30, 2013.
  1. SciFrog
    SciFrog Formula Junior
    Apr 9, 2008
    566
    I don't have access to the manuals, how do I open the fuel door if the button is not working?
    Tks
  2. RickLederman
    RickLederman F1 Rookie
    2,836
    Swanton Ohio
    Rick Lederman
    From the manual:
    Emergency Opening
    In the event of a failure of the fuel tank cap flap button, the flap can
    be opened manually.
    Open the luggage compartment lid, turn the lock E and open the
    flap F.
    Pull the emergency string G.
    Lock E is in the right rear corner of the trunk. It is the same thing you open to plug in a charger. The string that you pull seems to be directly below the charge plug, toward the bottom center of the opening, just to the right of the metal piece that the charge plug mounts to. It is a red string with a loop at the end, VERY easy to spot.
    Rick
  3. SciFrog
    Apr 9, 2008
    566
    #3 SciFrog, Jul 30, 2013
    Tks
    I had looked there before and could not see it...
    I checked. I think I found the flap F where the charger plus is. There is no red string to pull...
  4. mtarvydas
    mtarvydas Formula Junior
    Oct 26, 2011
    701
    On the Mountain
    Martin Tarvydas
    Try this it actually resets the computer. Hold the unlock/trunk button on the FOB for 30 seconds. This trick always works when my trunk won't open
  5. RickLederman
    2,836
    Swanton Ohio
    Rick Lederman
    #5 RickLederman, Jul 30, 2013
  6. SciFrog
    Apr 9, 2008
    566
    You mean that black loop with the little red thing? My car doesn't have that. I found a lot of electrical wires and a loose piece of metal. But not the release cable...
    I tried the two key button reset and maybe that helped as the door finally opened. I could alwys hear the noise trying to open even before so not sure what really happened...
  7. tazandjan
    39,019
    Download a copy of the California OM for your smart phone from ferraridatabase.com.
  8. SciFrog
    Apr 9, 2008
    566
    Finally looked in the manual. They show a cable marked in red. I don't see it in my car...
  9. YAMVS6
    YAMVS6 Karting
    Jan 26, 2011
    138
    ohio
    resetting the FOB is just locking and un locking with FOB,with all doors closed,that will reset system,can you hear the fuel door release motor when pushing button? if so you may need a new fuel door hinge,emergency release cord may be tucked away too far behind panel
  10. SciFrog
    Apr 9, 2008
    566
    I could always hear the motor.
  11. Verno
    Verno Rookie
    Aug 7, 2010
    9
    After a year my fuel door stopped opening but I could hear a relay activating--the dealer just had to adjust the mechanism and then it worked fine. Until yesterday. Tried to put the roof up and got a red "failure" message on the screen, the trunk wouldn't respond to the fob or floor button, and the fuel door wouldn't open. All at the same time. Glad it didn't rain and I didn't run out of gas. Today all worked as normal. Anyone see this combination before?
  12. mtarvydas
    Oct 26, 2011
    701
    On the Mountain
    Martin Tarvydas
    This happens to me all the time. I reset it with the FOB, another poster stated just off then on, but the only thing that works for is holding unlock +trunk for 30 seconds.
  13. oldman1982
    oldman1982 Rookie
    Jun 15, 2022
    31
    Harris M
    sorry for replying long dead thread. but im currently experience this problem to my cali too. i can hear the motor works when i press the gas cap button. but nothing happens. how does one actually open the cap ?
  14. Jbutler
    Jbutler Rookie
    Mar 21, 2022
    3
    James Butler
    ok i found the red cord got the door open but what is the likely fail in the system, fuse? button the the floor?
  15. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,049
    DFW, Texas
    Tom C
    Based on what I can recall seeing here, the button on the floor seems the more common culprit. Can you open the trunk with the button next to the fuel door release?
    T
  16. Jbutler
    Jbutler Rookie
    Mar 21, 2022
    3
    James Butler
    door does not open when pressing the button on the floor. I pulled the red string in truto open it, lubricated the entire thing but the cellenois does electrial switch does not seem to make and noiuce or movement when I press the floor button to open it. I heard there was some sort of reset via the key fob that may work? true ?
  17. SVCalifornia
    SVCalifornia F1 Rookie
    2,551
    Silicon Valley
    Keith
    Look at the fuse.
    SV
  18. bb2thdr
    bb2thdr Formula Junior
    Dec 23, 2021
    318
    Scott Bialik
    My fuel door only opens when the engine is off and the key is out. Are you removing the key and then trying to press the button?
