Ediff failure light | FerrariChat
Ediff failure light
Discussion in '360/430' started by [email protected], Jan 23, 2013.
  1. szink@2020companies.com
    Jul 15, 2010
    9
    Fort Worth, Texas
    Steve Zink
    I have a 2005 430 with an ediff failure light that comes on constantly. The first time it happened I took it to the dealer and they replace the control valve under a "courtesy warranty". It failed again on the way home and I returned the car to the dealer. They claimed the replacement valve was faulty and put yet another valve - no charge. About 6 months later the the light would come on occasionally. I could stop the car, recycle the ignition key and the light would go away. After a couple of months this processed stopped working and the light came on at start up. I returned the car to the dealer for a third try. They replaced the valve, again, replaced the pressure sensor and the ediff ECU. This took place over a 2 month period working with Ferrari NA. None of this has worked and the ediff failure light comes on still. The dealer claims they have completed all of the "phase 1" procedures and they will need to move on to "phase 2" but first I need to pay their invoice for $7,400. Phase 2 repairs will be replacement of the differental costing approx $30,000 or replace the F1 pump costing approx $15,000 or both. And they do not guarantee results. I know others have had this problem and I have mentioned this to the dealer but they seem to disregard. Anyone out there have suggestions?
  2. djastral69
    djastral69 Formula 3
    1,895
    Fl
    David
    Did you say $15k for an F1 pump?
  3. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    LOL!!
    I cant believe this prices man!! How can people come with this numbers????
    I think that when these guys see Ferrari owners enter to their shops they just pull down their pants zipper and let the party begins!! LOL
  4. djastral69
    1,895
    Fl
    David
    That's what I was thinking! Steve, I would have your car looked at by another dealer as they obviously don't know their ass from a hole in the ground.
    Just FYI, the F1 pump, latest version is $800 for the part and it takes an hour to put it in and bleed it via SD2-3.
    I have a friend who had our local Ferrari Stealership tell him that he needs '3' tires? Since when do they make cars with three tires....Lol. It really is sad and not good business practice. It's been put very well by others on this forum, be honest and have customers for life!
  5. TheMayor
    104,751
    Vegas baby
    Why don't we try to help this guy instead of dancing on his misfortune... That's why he came here.
    So, let's get back to the subject and see if we can give him some advice.
    For one thing, you can try an independent shop. The pump might be gotten for less in the aftermarket. You might want to contact Daniel at Ricambi and see what he has. I would at least talk to an independent shop before doing much else.
    I think the dealer did try to help you here as best they could. They tried it seems pretty hard to get the car working at no cost to you. That isn't working and now it's time to take it to the next level. If changing the the obvious things don't work, it's got to be deeper. Deeper means more expensive.
    These Ediffs are actually pretty reliable (there's not many threads like this one) so it's more likely something like the sensors, the pump, or the actuators that's causing the problem. There's a problem here and there with the warning light but it's usually a pretty simple fix as the dealer tried.
    If in the worse case the E-diff needs to be replaced, it's going to be bloody expensive. There is no other way around it.
    Let's hope it doesn't come to that.
    The only thing I don't understand is why the dealer cannot diagnose the problem better for you. It would seem they would be able to single out either the pump or the edif in whatever data they have about the systems.
  6. TheMayor
    104,751
    Vegas baby
    Is it the same pump for the F1 that feeds the Edif though?
    Remember he's talking about the Ediff light, not the gearbox. The gearbox appears to be working perfectly.
    I do agree with the second opinion though.
  7. djastral69
    1,895
    Fl
    David
    +1 Mayor. You were the one I was thinking of when I was writing my last post.
    Per the Edif, from what I have come to understand its the same pump that feeds the tranny and Edif. Either way, it won't be $15k for the pump, I can assure you.
  8. TheMayor
    104,751
    Vegas baby
    Yah I agree on the cost of the pump. I would shop around.
    I'm really surprised it's taken this long to get this far though and by the lack of information/speculation on what the problem may be.
    If it were me, I would be upset about that aspect here, aside from already being upset about the problem in the first place.
    I also would not pay the previous bill of $7500. The problem wasn't fixed so why should I pay for that? I think it's their responsibility to diagnose and fix the problem. It depends a lot on the documentation that was signed and agreed upon when the car came in. The six month gap though between their fixing it and it returning though may indicate that there were more than one problem. It's iffy who has the best case here. I can see it both ways.
    But, that's a separate issue altogether. What's more important is to get the car fixed at the least amount of effort and cost.
  9. vrsurgeon
    vrsurgeon F1 World Champ
    16,436
    Charleston, SC
    Curt
    Glad I wasn't the only one thinking this.. $7500 for what? Seems unreasonably large..
  10. BRADAN
    BRADAN Two Time F1 World Champ
    22,661
    West Babylon, NY
    BRADAN
    You can bench test the soleniod with a 12v battery. Dip it into a container of diff fluid and you should see air bubbles when it starts to pulse. That is the first thing to look into.
    If the pump failed they should be able to get a pressure reading off the SD3 computer. If it failed it's not a big deal to replace or expensive.
    If both check out I would check the CAN network for faults. If the soleniod was shorted out or damaged it can short out the CAN HI or Low network including any computer that is connected. Normally it would damage the E-diff computer first but can travel further down the line.
  11. DanS*
    DanS* Karting
    May 29, 2012
    218
    Manhattan Beach, CA
    Dan
    The OP is in Fort Worth TX. Anyone have a recommendation for a shop familiar with the 430 E-diff?
  12. szink@2020companies.com
    Jul 15, 2010
    9
    Fort Worth, Texas
    Steve Zink
    I have an update. The service advisor has called back and adjusted the bill to $6,000. He confirmed the Ferrari North America advises the next step is to replace the entire F1 system and that will cost $25,000. I declined to spend the $25k and plan to pick the car next week. Even though I will need to pay $6k for a broken car I will feel better if it is in my garage rather than the dealership as I consider next steps.
    BTW, before I took the car to the dealer for the third try at the repair I did take it to Norwood Ferrari. James at Norwood was great and he tried everything to figure out the problem. He worked on it for a month but could not pin it down. He believed it was going to be the e-diff ECU and recommended I take it to the dealer. After putting a month's worth of work into the car James did not charge anything because in his words "he didn't fix it". May kind of guy.
  13. MVDESQ
    MVDESQ Formula 3
    Nov 25, 2010
    1,581
    Greenwich, CT
    Matthew & Kristen V.
    Maybe he should ship car to LI to Bradan for the fix. Even with shipping costs it may be cheaper and done right. I really liked Bradan's above post.
  14. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    +1; It may sound crazy, but paying a few $k for round trip transport to Bradan is not as crazy as it may sound. They can also do a paint correction while its there.
    +1; on trying a second shop, make sure they have one of the service computers: SD3, Leonardo, etc
    Me personally, I would read the workshop manual, learn the system, and fix it myself. If I fail, I would send it to qualified mechanics with more experience and better test tools.
  15. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    I just read this thread and am shaking my head. At this point I would have no confidence in your Ferrari dealer service department. Furthermore I would not rely on the hearsay of what FNA reportedly "advised." The car should go to someone who you or someone you trust has reason to believe will zero in on a small number of possible causes based on what you know to date.
    I think the best thing this thread can do is suggest such skilled trustworthy service centers. Maybe Bradan can recommend one or two based on their knowledge and experience.
  16. vrsurgeon
    16,436
    Charleston, SC
    Curt
    +1. If you're going to have to "throw parts at it", you can at least try working used parts with this method.
    That's disappointing that the stealership handed you that line. That's unacceptable as is the $6000 for not solving the problem IMHO. I'm sure it's not indicative of ALL dealerships, but this fleecing is IMHO not acceptable.
    Actions like above is the mark of a reputable mechanic.
  17. Houston348
    Houston348 Formula 3
    Oct 18, 2006
    2,297
    I had repeated problems with the ediff on my F430 as well. Mine would fail after driving it pretty hard on the track. There would be no warning light, just a red ediff failure light after slowing down and exiting the track.
    I took it to FoH and they said it's very important that the ediff valve has to be tightened precisely.
    It hasnt failed again, but then again, Im too scared to take it out to the track lol
  18. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,794
    Dallas Texas
    If you know you know
    With the OP permission, I would like to share, as they say " The rest of the story " as what has been presented here is less than accurate. Or rather less than the complete story.
    S
  19. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,794
    Dallas Texas
    Thank you for your thought out and considerate reply.
    I will await a simple yes or no from the OP before adding more information from "the other side of the desk".
    S
  20. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    ...he certainly has earned his reputation, so have some dealers....
  21. szink@2020companies.com
    Jul 15, 2010
    9
    Fort Worth, Texas
    Steve Zink
    Please do present the other side of the story. I have never mentioned the dealers name. The purpose of this post is to is to solicit information from other Ferrari owners to help me with my problem and I have in fact received some good suggestions. In the process others have weighed in on their opinion. I tried to be factual. If I misrepreseted the facts please feel free to correct them.
  22. TheMayor
    104,751
    Vegas baby
    I think what's important here is not who did what or why. There are always two sides to any story. And, both could be right depending on your point of view.
    That's not what's important.
    What's important is what is the proper next step the OP should do to get out of the situation and his car back on the road where it belongs.
  23. vrsurgeon
    16,436
    Charleston, SC
    Curt
    Yes but if everyone (myself included) would adopt this view in life then there would be no drama on FChat. And then the world would be a boring, homogeneous, happy place... ;)
  24. TheMayor
    104,751
    Vegas baby
    Well, I have also been told many times that I should take my own medicine. :)
  25. DrStranglove
    DrStranglove FChat Assassin
    30,980
    Google Maps
    DrS
    I am looking forward to this!
