Ecu failure visit dealer | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by freddie royal, Nov 8, 2019.
Tags:
  1. freddie royal
    freddie royal Rookie
    Aug 19, 2019
    22
    Chesterfield, Virginia
    freddie royal
    ok thanks i'm new so I should have posted my vehicle but thanks for the help. I'll keep everyone posted
  2. freddie royal
    Aug 19, 2019
    22
    freddie royal
    Ok newest update. The exhaust manifold came in and when the mechanic went to install them he saw a valve cover gasket leak also on the same side. So waiting on gasket them I will update.
  3. freddie royal
    Aug 19, 2019
    22
    freddie royal
    Ok new update. Installed the exhaust manifolds on both sides. Still same problem. Any ideas on what to try next. Any suggestions would help.
  4. gsholz
    gsholz Formula Junior
    347
    Oregon
    Jerry
    #29 gsholz, Jan 7, 2020
    Since the failure is repeatable, it is just a matter of looking at all the data when it happens. I'd have them hook up a scan tool or scope and log all pertinent information (fuel pressure, fuel trims, air/fuel ratios, O2 sensor values, injector pulse, coil pulse, etc). Compare it to known good values from another cylinder. The ECM is seeing something it does not expect. You/your tech can look at all the same inputs in real-time.
    It is an interesting clue that is always happens at the very same RPM (5998). Given that it is unlikely fuel or air related. It is more likely something electrical/digital/firmware related. I'd investigate ECU, crank and cam sensors etc.
  5. RBL
    RBL Rookie
    Mar 22, 2019
    3
    You have to replace injector 8. Best thing is to replace all of them to have a smoth runing engine as it was new.
    Sent from my SM-A510F using FerrariChat.com mobile app
  6. Tarek307
    Tarek307 Formula 3
    1,348
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    are you sure its' not your manifold flaps?
  7. freddie royal
    Aug 19, 2019
    22
    freddie royal
    Ok new update. Installed new exhaust manifold, and fixed valve cover gasket still same problem. Cylinder 8 misfire. Installing new injectors on tomorrow.
  8. f355spider
    f355spider F1 World Champ
    18,043
    Diagnosis by parts replacement
  9. freddie royal
    Aug 19, 2019
    22
    freddie royal
    I have new plugs, new coil packs, new exhaust manifolds, new valve cover gaskets. Still ecu failure visit dealer misfire cylinder 8
  10. Continental AutoSports
    Sponsor
    Aug 22, 2006
    4,409
    Hinsdale, IL
    Bobby Williams / Parts Manager
    What dealer did you take it to? Ferrari of Washington?
  11. freddie royal
    Aug 19, 2019
    22
    freddie royal
    Yes correct Ferrari of Washington. Also the dealer swap ECU's but the code stays at cylinder 8
  12. freddie royal
    Aug 19, 2019
    22
    freddie royal
    Ok new update. Just replace the injector rail. Yeyyyyyyyyyyyy its fixed. Thank everyone for all your help. The car drives amazing, smoother idle and a lot more power also. Thank everyone.
  13. albkid
    albkid Formula Junior
    Jul 1, 2016
    318
    Jim
    I am curious, what was the cost of parts and service before the diagnosis of the faulty fuel rail.
    I know this is a stupid question, but did Ferrari of Washington write down the cost of the fuel rail repair for all the other things that did not address the issue?
  14. freddie royal
    Aug 19, 2019
    22
    freddie royal
    Ferrari of Washington didn't find the faulty fuel rail. The cost was around 5000 for repairs
  15. albkid
    Jul 1, 2016
    318
    Jim
    Did the dealer replace plugs, coil packs, exhaust manifolds, and valve cover gaskets? It would appear you did well for $5,000.
  16. freddie royal
    Aug 19, 2019
    22
    freddie royal
    No 5000.00 before the fuel injector rails. 8500 total. Also ferrari of Washington diagnosed the problems and my local mechanic did all repairs .
  17. asgor
    asgor Formula Junior
    Sep 8, 2016
    715
    Virginia, USA
    Freddie, I live near Richmond and I have trouble finding a good indy with appropriate Ferrari knowledge. I'd like to ask who's your "local mechanic", if you don't mind.
  18. freddie royal
    Aug 19, 2019
    22
    freddie royal
    Sure no problem. Its two brothers that own the shop and they work on my buddies Ferrari 430 also. HIs name is Issa and his phone number is 804-231-7097.
    Just let him know that Freddie referred you.
    D-Gunz likes this.
