Dying battery or starter? | FerrariChat
Discussion in 'FF/Lusso' started by ferrari169, Feb 24, 2020.
  1. ferrari169
    ferrari169 Karting
    Jan 14, 2014
    147
    Northeast USA
    Can someone tell me if this startup sounds like a dying battery or a dying starter? It doesn't sound right to me.
  2. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,109
    Denmark
    Max
    Dying battery to me
    Caeruleus11 likes this.
  3. j09333
    j09333 Formula 3
    May 7, 2004
    1,154
    More like drive me for a while and see how it goes than change battery asap.
    Tender is not enough for v12 for a long period of time. Eventualy one has to drive for an hour or so. For me, tender is only for holding and not loosing battery power.
  4. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,373
    Weston, MA
    Paul
    Definitely not the starter. Starters are either alive or dead, there's no inbetween.
  5. ferrari169
    ferrari169 Karting
    Jan 14, 2014
    147
    Northeast USA
    Thanks for the replies
  6. Nospinzone
    Jul 1, 2013
    7,373
    Weston, MA
    Paul
    Actually I correct myself. Sometimes there are starter issues in between robust and dead, such as missing teeth. However, this clearly isn't your problem.
  7. Caeruleus11
    Caeruleus11 F1 World Champ
    10,894
    I recommend changing the tender to the Ctek 7002. If your car has an AGM battery then use the snowflake mode ("*") - this will really maintain the battery. The included tender can barely keep up and is more prone to damage from brownouts and surges. The 7002 is much more powerful and resilient.
    j09333 likes this.
  8. Nospinzone
    Jul 1, 2013
    7,373
    Weston, MA
    Paul
    BINGO! That's the one I use.
    The one that came with my 612 simply couldn't keep up. And I didn't set the alarm just so as not to add an additional drain.
