Dropped 1-6 Bank After Washing Or Sitting In Heavy Rain | Page 3 | FerrariChat
Discussion in 'Boxers/TR/M' started by Shamile, Jun 10, 2018.
  1. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,553
    So. Cal
    Armen
    I recently have been having the same issues with the check engine and slow down lights.
    All this info will help.
    Thank you
  2. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    Shamile, Awesome! These cars arent a a frickin Rubicks cube. Whith that said, they arent exactly easy to figure out.....so take that to the food truck outside the workshop.
    Thats why I had to tear mine apart to re do the plastic parts. Talking about the cube not the car.
    When I had a wet-no-work scenario on my 911, I just went with a simple solution of covering grids until I could pin point the offending party. (It was the first coil pack). Replaced them all and all is good after a good douching rain fall. Its so easy even a caveman can do it. Start with a spray bottle of water, some Lynard Skynard, and a bottle of Petron.
    Shamile...we will toast the the F Gods next time I roll in to the Lords waiting room. Carpe FPimp or somethimthing.
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    and when finished a bottle of beer or wine :)
  4. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    We speak the same language my friend!
  5. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Great work!!
    Ps:there is one for sale on eBay with 82k miles; u are catching up!
  6. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Here is a potential solution to the connector working itself loose. The cables constantly tug at the connection and its weight tries to work the connector loose. Some safety wire routed from under the tank to the two wire looms will take the load off the cables and help it to stay secure.
    Streetsurfer, Shamile and xplodee like this.
  7. V4NG0
    V4NG0 Formula Junior
    696
    Charles Edward Cheese
    My car is now running rough after washes and in high humidity. Is this the part to which you are referring that needs cleaning and greasing?
  8. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    No. Thats the connect to the ignition module.
    The connector this thread refers to is under the coolant reservoir
    turbo-joe, V4NG0 and Shamile like this.
  9. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Yep, you will find two connections under the coolant reservoir. One is a multi pin and not at all a waterproof connector. The second is a round plug connector. Both are right next to each other.
    Shamile
    Freeze....Miami Vice!
    Sent from my SM-G950U using Tapatalk
    turbo-joe and V4NG0 like this.
  10. V4NG0
    696
    Ok, thanks for clarifying. I’ll take a second look when I’m back to the car.
    Shamile likes this.
  11. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
  12. V4NG0
    696
    Thanks so much for the visual—will get to it and report back as soon as I can. I’ve already bought the dielectric grease, cleaner, and brush. Fingers crossed.
  13. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    I can already see that your multi pin connector is exposed. Even the ineffective rubber boot cover is missing. Definitely clean both ends to death and apply dielectric grease on the pin sides. Push in, pull out, add a tiny bit more grease and seat.
    Shamile
    turbo-joe likes this.
  14. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Shamille- good eye!! Thats my car. There’s only a boot on the rectangular connector, correct? I’m going to look to find one from a parts supplier.
    Shamile likes this.
  15. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Yes, there's a form fitting rubber boot that covers the multi pin connector. Unfortunately, with the heat of the engine bay, it gets distorted. Try to find some sort of covering for it.....even if you have to wrap it in black electrical tape.
    Shamile
  16. V4NG0
    696
    I cleaned and greased the connections as per above but it didn’t work this time. The car was then sent off to the shop and came back home today with two ‘new’ coils installed. The problem is fixed, and the car has never run so well or sounded so good since I’ve had it.
  17. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    #67 xplodee, Aug 15, 2019
    Coils are such a frustrating problem because its intermittent until it fails for real. My coil going bad dragged out a year and across a major having been done!
    Oh, and one thing: generic coils/modules can be had to the tune of $200 for 2x coils AND 2x modules. While I hate to recommend blindly replacing parts, if you ever have problems with running and know your coils/modules are old then it may be worth just doing the replacement.
    ago car nut and Shamile like this.
  18. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
    Yesterday I had 1st problem in almost 10 years of my TR ,not running on 1-6 bank. Cleaned all connections and now running fine again.
  19. DonB
    DonB Formula Junior
    616
    Florida
    Don Bartz
    When I wash my BBi I put a large plastic garbage bag over the engine. It keeps water out of all the little spaces and electricals on top of the engine..has always seemed to work OK.
  20. V4NG0
    696
    That’s good information about affordable generic coils being an option. Mine came rebuilt from a specialist in the UK for probably double the price you cited above.
  21. ago car nut
    5,267
    Madison Ohio
    David A.
    Where can these generic coils be obtained?
  22. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    I bought all from Amazon. There are two different style coil connections that exist on the TR, one is a single connector with four pins and one is two connectors with two pins each. Make sure you match the coil to your car.
    There is also an earlier coil that looks very different. This requires an earlier style heat sink to mount it. If you have the earlier type I think its easiest to buy a used heat sink off a breaker. They run about $50.
