Drivers ventilation error annoying | FerrariChat
Discussion in 'FF/Lusso' started by ttforcefed, Nov 12, 2019.
  1. ttforcefed
    ttforcefed F1 World Champ
    18,772
  2. LeoBRK
    LeoBRK Formula Junior
    Sep 26, 2010
    452
    NYC
    Leonardo
    yep every day!! super annoyning
  3. SVCalifornia
    SVCalifornia Formula 3
    2,447
    Silicon Valley
    Keith
    Yep but on FF. Seems to be less recently. May be due to new software
  4. Alcav5
    Alcav5 F1 Rookie
    3,970
    Scarsdale, NY
    Al
    In the 612 I get notice that the seat heater is on when it clearly isn't.
    Didn't think that problem could happen on newer cars...
  5. Bamsefar
    Bamsefar Formula Junior
    Nov 26, 2012
    523
    Yepp, it is on my 2016 FF also. I had the switch replaced on warranty 4 (four) times - no difference. It just got to be software error. And yes now when my FF is out of factory warrant (the original 3-years) I have it yet again - no I will NOT change the switch again, since that will not solve the problem. I had this from day 5 or so...
  6. ttforcefed
    18,772
    nah i have the latest software...just the way it is i guess
    maybe ill disconnect the battery tonight and see
  7. baguns
    baguns Karting
    Sep 19, 2012
    246
    Yorba Linda, CA
    Was just going to post something on this. ‘13 FF and intermittently getting this error (maybe every third start up). Mine shows passenger side is on level one but when I check it’s turned all the way to zero.
    Does this mean anything? Harbinger for any issue?
  8. Solid State
    Solid State F1 Veteran
    9,586
    Maximus Decimus Meridius
    No need to worry. When they go full electric there wont be any issues whatsoever. We'll all just sit back comfortably while the vehicle takes us flawlessly to our destination. Much simpler than detecting if the seat warmers are on don't you know.
    JTSE30 likes this.
  9. Bamsefar
    Nov 26, 2012
    523
    Question: When I get this on my '16 FF, on the driver side seat, I can never feel any air pushing through the seat. It is more like it says "level 1" but is "off" - anyone concur or am I wrong?
  10. otakki
    otakki Formula 3
    Mar 24, 2016
    1,623
    I'm fine with it as long as those systems don't stay on and drained the battery when the car is off.
  11. msgm1
    msgm1 Formula Junior
    Nov 4, 2003
    454
    NYC
    I think it means that the seat heating unit needs replaced, which was prohibitively expensive if I remember?
  12. ttforcefed
    18,772
    idk. hasnt happened again since the OP. its random and odd. lol
  13. JohnDxb
    JohnDxb Rookie
    Apr 10, 2019
    8
    Jonathon Lewis
    I have exactly the same problem - I had an issue with the seat cooler working in reverse. Level 0 = Level 3 fan and vice versa as well as the annoying pop up displays.
    I had the switch replaced on the seat so now 0 = 0 but still have the annoying pop ups.
    What I think is happening is that the seat is flexing the PCB that controls the heating and cooling controls. The reason for thinking this is that I have the same problem with the passenger seat but only when someone of larger proportions sits in the seat. When my wife sits there there is no problem.
    The heating and cooling work perfectly it's just the annoying intermittent display - I can live with it I guess.
  14. Elasto
    Elasto Karting
    Aug 27, 2014
    129
    Vienna, AUSTRIA
    Andreas
    Same here.
    From time to time the annoying info shows up. I then switch from 0 to 3 and back again.
    As long as the V12 is working fine I can live with that.
  15. ttforcefed
    18,772
    im thinking it might be battery related - ive gone back to using my tender all the time and will monitor if it happens.
    Caeruleus11 likes this.
  16. Caeruleus11
    Caeruleus11 F1 World Champ
    10,860
    You should definitely use the tender as much as possible. These cars have a lot of computers. I was surprised to read in an owners manual (I forget the model now) they say any thing more than something like 68 hours, you should have it on the tender....
  17. ttforcefed
    18,772
    Totally agree with that conclusion
  18. Caeruleus11
    10,860
    Are you still using the factory supplied tender or something better? If not better I will bring you a present the next time I see you!
  19. Elasto
    Elasto Karting
    Aug 27, 2014
    129
    Vienna, AUSTRIA
    Andreas
    My F dealer told me to connect the FF to the tender if the car isn't used for more than a week.
    A weak battery is known to cause many electric "issues".
    When I picked up the car (at a non-Ferrari dealer) and turned the key the dash lit up like a xmas tree, "Manettino defect", "4WD system defect" etc...
    Ignition off - on ..... everything ok.
  20. ttforcefed
    18,772
    I use oem ferrari one and a creek - depending on which bay I pull into. My oem ones have always worked fine for me for normal use. For charging a very depleted battery I always use the big boy ctek.
  21. Caeruleus11
    10,860
    I recommend you use the big boy all the time- it will condition the battery much better than the OEM and it also is much more resistant to brownouts/ power surges.
  22. ttforcefed
    18,772
    4.3 or 7002?
  23. Elasto
    Elasto Karting
    Aug 27, 2014
    129
    Vienna, AUSTRIA
    Andreas
    The same here with my '12 FF, but it's not the ventilation. It's the seat heating.
    It shows that it is on when it is not.
    I have gotten used to it popping up now and then, so now it actually makes me laugh. :D
    TriumphantTaco likes this.
  24. Bamsefar
    Nov 26, 2012
    523
    Howdy,
    So now I have this on "heated seat" also - however it does also activate the heat in the seat to level 1. Only way to turn it off, is to first turn the heat forward to 1 and then back to zero. And if the display still says 1 (it happens!) then I turn on the ventilation control to 1 and then to zero - problem fixed.
    I am starting to think about getting me one extra switch (about 125 euro on eurospares - it is the same switch for heating and ventilation control) and simply disassembly the thing to see why on earth they behave likt this. Even though I might think it is software in combo with battery kind-of-thing (my battery is 3.5 years, and I plan to change it in March when I service my FF), I still would like to actually see how it can start to behave like this. It is not normal anyway.
  25. ttforcefed
    18,772
    do you keep the car on the tender all the time? if not you shld try that.
