Driver seat electric failed | FerrariChat
Discussion in '360/430' started by maghriha, Oct 27, 2016.
  1. maghriha
    maghriha Rookie
    Aug 18, 2006
    26
    Saudi Arabia
    Hosam maghribi
    Hi
    The driver electric seat went all the way forward.And then tried to return back it did not.We found electric wire on the bottom of seat is disengaged. decided to remove the seat .The rear bolts holding the seat was exposed and easy to remove.But the front ones was covered by the seat and i can not reach them.
    Can the electric seat return back by any means?Any idea how to reach the front holding bolts?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    You will have to try to connect a temporary supply to the motor to see if you can power it back. Or you get the car on a ramp and see if you can remove the seat bolts from the underside.
