360 - Drive Cycle Procedure - Advice? | FerrariChat
360 Drive Cycle Procedure - Advice?
Discussion in '360/430' started by SRLC716, Apr 29, 2020.
  1. SRLC716
    SRLC716 Formula Junior
    Sep 15, 2019
    292
    Buffalo
    Sam
    I’m looking to do Ferrari’s recommended 360 drive cycle procedure to reset my emissions monitors. Of course, and unsurprisingly, it is not very clearly written. See below.
    If I’m cruising at 2500rpm in 4th gear, how do I then magically decelerate from 4500rpm to 2000rpm? I’m assuming I will have to accelerate gradually from 2500 -> 4500 and then decelerate as instructed?
    Any help or advice is appreciated.
  2. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Yes, Ferraris procedure is confusing.
    I have a post here that explains it in plain English and I offer some tips. Kindly do a search.
    Dan
  3. SRLC716
    Sep 15, 2019
    292
    Buffalo
    Sam
    I did do a search and didn’t/don’t see the post you’re referencing... is it a separate thread? Any clues on how to find it? Or a link?
  4. jdlegg
    jdlegg Formula Junior
    Dec 22, 2009
    251
    Bryan / San Rafael
    James D
    Tried this several times on my previous 360 before handing car over to dealer to get it done.
  5. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    You let off the accelerator and coast until you’re down to 2000 rpm. The instructions don’t say to go to 2000 and also maintain your speed. Just don’t get in the way of faster traffic (easier said than done).
    The cycle works, but it’s not easy to find a road or time when you can do the cycle according to instructions. It may be easier these days with shelter-in-place regulations and less traffic. Best is a highway with at least two lanes in the direction of travel and enough off-ramps to pull off the road safely.
    You also need to start with a cold engine after the car sits overnight. I did mine early in the morning, no doubt annoying my neighbors.
    SAFE4NOW and jdlegg like this.
  6. SRLC716
    Sep 15, 2019
    292
    Buffalo
    Sam
    I’m not concerned about maintaining speed - I’ve got a good stretch of road where I can do this safely. Step 2 is what has me baffled.
    If I’m cruising in 4th gear between 2000 and 2500rpm, how do I then decelerate from 4500rpm to 2000; wouldn’t I need to first accelerate to 4500rpm? What am I missing?
  7. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    899
    S La
    That pretty much matches the instructions for setting belt tension with removing and replacing the little tensioner lock.
    Need4Spd likes this.
  8. tazandjan
    39,007
    Drive cycle explanation (may be Dan's, forget) and also a simplified drive cycle that works most times.
    The purpose of the OBDII drive cycle is to run all of the onboard diagnostics. The drive
    cycle should be performed after you have erased any trouble codes from the PCM memory,
    or after the battery has been disconnected.
    Running through the drive cycle sets all the system monitors so that subsequent faults can
    be detected. This is vital for the purposes of our PPI.
    The OBDII drive cycle MUST begin with a cold start:
    - coolant temperature below 122 degrees F
    - coolant and air temperature sensors within 11 degrees of one another
    NOTE:
    The ignition key must not be on prior to the cold start otherwise the heated oxygen sensor
    diagnostic may not run.
    F-Car Step 1:
    Start the cold engine directly from the key ‘off’ position.
    With no driver input, let the engine idle with the ECU in full control of the
    idle speed for four (4) minutes.
    ~ OBDII checks oxygen sensor heater circuits, air pump and EVAP purge.
    F-Car Step 2a
    Accelerate with moderate throttle and shifting into 3rd or 4th gear &
    2,000- 2,500 RPM
    ~ OBDII checks for ignition misfire, fuel trim and canister purge.
    F-Car Step 2b
    Hold this steady state engine speed in the same gear at 2,000-2,500 RPM
    for 3.5 miles.
    ~ OBDII monitors EGR, air pump, O2 sensors and canister purge.
    F-Car Step 2c
    Increase the engine speed at a modest rate to 4,500 RPM and hold for 10
    seconds or a bit more to ensure a steady state condition.
    Decelerate to 2,000 RPM without braking or depressing the clutch.
    ~ OBDII checks EGR and purge functions.
    F-Car Step 3a:
    Safely pull over to the side of the road with minimal or no gear changes and
    certainly without double clutch blipping of the throttle. Declutch to neutral
    when the slowing engine speed calls for it.
    Let the engine idle with the engine in neutral and with the clutch out at the
    side of the road. Allow the ECU to fully control idle speed with no driver
    input.
    For a full 5 minutes, allow the engine to idle in neutral with no driver input.
    During this 5 minutes of idling, do not change the engine loading by switching
    on any accessories (like the A/C).
    F-Car Step 3b:
    Switch the engine and key fully off after the 5 minute idle.
    Keep the key in the off position for 15 to 20 seconds.
    F-Car Step 4:
    Restart the car and drive it at a moderate acceleration back up to 3rd or
    4th in the 2,500 to 3,500 RPM range (i.e.: “normal driving”).
    ~ OBDII checks misfire, fuel trim and purge again.
    Continue to drive for at least 10 minutes with the car under this steady
    state condition (2,500 to 3,500 RPM).
    ~ OBDII monitors catalytic converter efficiency, misfire, EGR, fuel trim,
    oxygen sensors and purge functions.
    F-Car Step 5:
    certainly without any double clutch blipping of the throttle. As appropriate,
    keep the engine in gear as you de-accelerate.
    ~ OBDII makes a final check of EGR and canister purge.
    Check readiness codes w/ OBDII scanner
    Run Cycle
    Run cycle.
    Turn battery disconnect switch off and turn off all accessories (stereo, A/C, etc).
    Let engine get completely cold or wait at least 30 minutes.
    Reconnect disconnect switch.
    Disarm immobilizer with the fob.
    Insert key in ignition and leave for 30 seconds.
    Turn ignition to on and leave for 30 seconds.
    Turn ignition off and leave for 30 seconds.
    Turn ignition on, wait for Check OK, and start. May have to push fob again if 120 seconds have elapsed since last fob actuation.
    Let idle with no input whatsoever for 10 minutes.
    Turn accessories back on and drive gently for 10-15 minutes at least.
    You will have to insert stereo code, if required.
  9. SRLC716
    Sep 15, 2019
    292
    Buffalo
    Sam
    Thank you - very helpful!
  10. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,796
    Dallas Texas
    If you know you know
    Here is Ferrari's latest instructions for drive cycles, that I personally follow several times a week, with 100% success rate:
    S
    SRLC716 likes this.
  11. SRLC716
    Sep 15, 2019
    292
    Buffalo
    Sam
    Thank you!
  12. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Sorry Sam I was busy all day and just now finding time to chime in.
    What I have on my tip sheet is (which I still cannot find as my hard drive crashed months ago) pretty much what Taz posted on post number 8 so just follow that.
    The only thing I wanted to add which I included on my tip sheet was if for some reason you run out of road and not able to complete a step you do not have to start all over again. Just repeat that specific step.
    I did this procedure stated by Taz on my F430 after I replaced all my spark plugs, turned the master switch power off, did the recycle procedure to prepare my car for emissions testing. It passed with flying colors.
    We are lucky here in Washington State. Starting this year 2020, no more emissions testing! Yay!!!!!!!!!!
    Reason - they said they want the testing to run for 10 years and 10 years is completed and it has served its purpose.
    Thanks everyone for helping.
    Dan
    Need4Spd and SRLC716 like this.
  13. SRLC716
    Sep 15, 2019
    292
    Buffalo
    Sam
    Thanks Dan - hope all went well with your 430 today.
    Appreciate everyone’s help - all of the monitors have cycled properly, just need to do the cold start beginning process tomorrow and it should inspect clear (fingers crossed).
    Need4Spd and whatheheck like this.
  14. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Your welcome Sam.
    Glad we can help out.
    Dan
  15. ItalGerBrit
    Mar 15, 2016
    899
    S La
    If you have test pipes and not subject to emission testing, you do not have to do the drive cycle dance?
  16. tazandjan
    39,007
    No, but it is designed to reset everything for optimum performance, so never hurts.
    whatheheck likes this.
  17. ItalGerBrit
    Mar 15, 2016
    899
    S La
    Wonder if that is why "sport mode" has not worked since I pulled my dash? Have never done a relearn ever.
  18. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    There are some posts here that some owners state the drive cycle reset is an overkill and not necessary as eventually the ECU will pull all the data its looking for and reset itself.
    I say it never hurts to try and follow the procedure as I think Ferrari knows what its talking about, usually............
    Dan
  19. ItalGerBrit
    Mar 15, 2016
    899
    S La
    Makes sense.
  20. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Yes, the drive cycle is to avoid driving a couple hundred miles in random situations hoping to get them all to reset.
  21. johnfe
    johnfe Karting
    Dec 22, 2016
    121
    SoCal Usa
    John F Edwards
    Hi everyone on this thread.
    I'm due for a 'Drive Cycle' myself since I have a smog test coming up for my 2009 F430 Manual Gated Transmission vehicle . When I first got it in 2017 I found this attached 'Drive Cycle' from a website entitled 'Ferrari Workshop Forum.' Please note this Bulletin number FNA - 20 shows it pertains to a 360 / 575M. Also an individual who owned a 2005 F430 commented it worked for him and it also worked for me. Thank you for the PDF referred to earlier in this thread as one can never have enough technical data on a Ferrari!
    Best Regards to all,
    johnfe
  22. Adomowitz360
    Adomowitz360 Rookie
    Dec 16, 2019
    34
    Adam Burke
    Thanks to all for the posts on this. I just used the instructions to pass emissions after failing the first time as the battery was recently disconnected for service. It took a couple tries as the roads near me aren’t conducive to the drive cycle requirements but after heading out to the country and finding the right route it came together.
    I bought the Autel OBD reader and that was a huge help as well to check after each attempt Wanted to share if others find themselves in the same spot.
    EastMemphis likes this.
  23. priericky128
    priericky128 Formula Junior
    611
    St. Louis MO
    Rick
    I recently bought a 2001 euro 360 spider. Due to the inclement weather we had in February, the battery died. I was unaware of the drive cycle process, and have driven it around 100 miles. I still have two monitors which are showing not ready. Perhaps this is a dumb question, but should I turn off the mater switch to reset the car again and then follow the drive cycle or should I just do the drive cycle without resetting? If I should reset, is there an amount of time to leave the switch off so that the electronics fully reset?
    Perhaps dumb question #2 - Taz when you say
    "NOTE:
    do you mean that I should not wait for the "Check OK" before starting? Typically when I start the car now, I turn the key to the first ignition point, wait for the Check OK to return, then turn the car over.
    I am in Missouri and our emissions here are fairly strict. I have found a way to possibly bypass the emissions inspection with a waiver, but doing a drive cycle and getting all the monitors ready is much simpler than wading through all the nuances of state forms etc.
  24. CarbonDan
    CarbonDan Karting
    190
    PNW
    #24 CarbonDan, Apr 30, 2021
    I tried this with my 360CS multiple times, to the letter, wouldn't work.
    Drove something+++ like 150 miles mostly highway and finally it worked. No special methods, just standard old highway driving.
  25. priericky128
    611
    St. Louis MO
    Rick
    Thanks for the info. I bought a scanner which should arrive next week sometime and will give it a try with more driving. Seems to vary whether people have luck with following the guidelines exactly or just do enough highway driving. Having the scanner in hand will help a lot also.
