Dreaded CEL | FerrariChat
Dreaded CEL
Discussion in '360/430' started by My 1st, Nov 1, 2019.
  1. My 1st
    My 1st Karting
    174
    Gladwyne, PA
    Scott
    Just an FYI. My 2004 gated spider with 8500 miles (5200 covered in the last two years since purchased) displayed a CEL. Took it to Algar and they found a faulty rollover valve. They replaced all four, and the CEL was gone. However, the next time I filled up, gasoline almost immediately spewed out of the filler. I thought there was a problem with my casually setting the nozzle on low rather than high flow. Tried again with the same result, took it back to Algar and they diagnosed a bad carbon canister. Problems solved.
  2. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    That all makes sense. Fixed the leaking rollover valves so the nozzle detected back pressure and kicked off. The canister was faulty all along you just couldn't tell. Glad it is fixed.
  3. RedNeck
    RedNeck F1 World Champ
    10,016
    The CSA
    Me
    Thanks for the info, those are common issues with these cars. Did you by any chance get a copy of what the codes behind the CEL were?
  4. My 1st
    My 1st Karting
    174
    Gladwyne, PA
    Scott
    No, but I can ask Rachel on Monday.
  5. Walt Gamble
    Walt Gamble Formula Junior
    May 22, 2014
    425
    Can the canister be replaced by a DIY? My 360 is really slow to fill...back pressure makes sense. Thx
    Sent from my moto g(6) using Tapatalk
  6. RedNeck
    10,016
    The CSA
    Me
    Yes, easily. It's behind the passenger's side engine panel.
  7. My 1st
    My 1st Karting
    174
    Gladwyne, PA
    Scott
    Matt, the code was P0442.
  8. RedNeck
    10,016
    The CSA
    Me
    EVAP leak, makes sense. Thanks.
