Door detent? | FerrariChat
Door detent?
Discussion in '365 GT4 2+2/400/412' started by SouthJersey400i, May 15, 2011.
  1. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,591
    Romulus, NY (Finger Lakes)
    Ken Battle
    I am not sure I am calling the part by its correct name but I am looking for the piece that keeps the door from swinging shut when you want it to stay open. It is actually two pieces (or more inside door) with a pivot fixed to the door jam and then a piece held inside the door with two bolts. Is this pair of parts available anywhere (new)? It is likely fitted to other cars F or other. I think the weight of the 400 door is too much for the part over time.
    Is the left and right hand pieces identical, just upside down when installed? I am sure I can find a used part from my usual suppliers, but the passenger side is likely less worn than the driver's side.
  2. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    #2 It's Ross, May 15, 2011
    "Door check or stop" to most parts men.
    My parts book shows "Arresto"(door stop) # 255.30.978.01, also I suspect a related part is # 255.30.962.01 "Tirante"(tie rod). Hopefully from the Fiat parts bin.
  3. SouthJersey400i
    Mar 14, 2007
    1,591
    Ken Battle
    Ross
    I'll check with International Auto Parts; they carry many Fiat and Alfa parts. Thanks
    Ken
  4. SouthJersey400i
    Mar 14, 2007
    1,591
    Ken Battle
    I checked with International Auto Parts today. they have one Alfa door stop but it is a rubber strap and is 90 degrees off from the 400 piece. I think all of the Alfa, Fiat and Lancia's imported in the US were much lighter cars and would have light weight doors.
    Anyone in Europe know the source of the door stop for the 400?
    Ken
  5. Ben_CH
    Ben_CH Rookie
    Dec 11, 2010
    28
  6. SouthJersey400i
    Mar 14, 2007
    1,591
    Ken Battle
    Eurospares said NLA. I'm now checking my used car people.
  7. Panord
    Panord Rookie
    Nov 5, 2009
    10
    Did you have any luck in finding them? I need a couple as well.
  8. SouthJersey400i
    Mar 14, 2007
    1,591
    Ken Battle
    I obtained a used one from one of my regular used suppliers. I asked for the passenger side assuming it would be less used. It is better than what I had but still weak holding the door.
    Ken
  9. GT Jones
    GT Jones Formula Junior
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    Bump to see if anyone has found a source for the detents
  10. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,070
    Gold Coast, Aust.
    Patrick
    I took mine out and... basically buggered around with it a bit. It's still weak, but better than it was. IIRC there's a rubber piece that perishes in the receiver part - I think I turned mine upside-down.
  11. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    Thanks. I'll commence buggering
  12. theunissenguido
    theunissenguido Formula 3
    Jan 21, 2004
    2,371
    Argent/Brasil
    Guido
  13. Ferraridoc
    Jun 20, 2012
    16,070
    Gold Coast, Aust.
    Patrick
  14. theunissenguido
    Jan 21, 2004
    2,371
    Argent/Brasil
    Guido
    just the arm is a bit longer and has an other connection to the seat for door hinge. So for 400 the arm can be right or can be fabricated to the right dimension.
    Guido
  15. markcF355
    markcF355 F1 Rookie
    3,493
    Schmeckelstan
    Mark
    I was looking for these a couple of years back. I found the Ferrari ones but I think they were the same on Porsches of the same era.
  16. markcF355
    markcF355 F1 Rookie
    3,493
    Schmeckelstan
    Mark
    #16 markcF355, Feb 11, 2017
  17. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    The key is to measure the mounting bolts c-c. The length of the arm will only determine how far it opens; not a big deal. It would be great to get door stops for $40!
  18. SouthJersey400i
    Mar 14, 2007
    1,591
    Ken Battle
    I got email about this thread and I said to myself, 'I don't remember subscribing to this.' Low and behold I was the originator in 2011!! Whatever I did back them it must have worked as this is no longer on my 'to do' list or I just got used to it as it is?
    The Porsche part looks like the same concept but as Bruce said the dimensions are critical. If the length is longer one could always drill a new hole but getting the bolt center-line is key as Bruce states!
    Ken
  19. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    the door check 60921100 fits Mondial, 308/328, 512 but not our beloved 400's. I'll check the porsche part this weekend when I can get out to the garage.
  20. Arvid
    Arvid Formula Junior
    668
    Norway
    Arvid Andersson
    That would be great Christian :) I've searched for this part for a couple of years but without luck.
  21. Ferraridoc
    Jun 20, 2012
    16,070
    Gold Coast, Aust.
    Patrick
    You know, if the dimensions worked, I'd be happy to instal a Hyundai one :)
  22. Arvid
    668
    Norway
    Arvid Andersson
    Is that even possible without getting a rash ?
  23. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,094
    Canada
    Newman
    The door check on a boxer (injected only - carb has no check) is the same as a testaroassa. Its a much better design than the 308 style so if it fit I would use one of those in my 400. My 400 checks are crap too.
  24. Newman
    Dec 26, 2001
    14,094
    Canada
    Newman
    #24 Newman, Feb 16, 2017
    Because the latches are used in mercedes cars and lambos and I imagine millions of other cars im sure the door checks are an off-the-shelf part.
  25. GT Jones
    Oct 15, 2011
    669
    Lincoln, MA
    Christian J
    Porsche part 91153195700 which fits every 911 does not fit the 400's. When I find my calipers I'll measure the 400 door stop and we can continue to scour the world for a substitute. I'll be at the Hyundai dealer next week!
