Does this oil line look correct? | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Ak Jim, Mar 18, 2021.
  1. Ak Jim
    Ak Jim F1 Veteran
    8,498
    North Pole AK
  2. Al Campbell
    Al Campbell Formula Junior
    Nov 22, 2013
    574
    Australia
    No.
    It should be like the bottom one in this picture.
    The top one is the one that was on my car and had a cracked crimp fitting that was leaking.
    Il Tifoso likes this.
  3. Steve Magnusson
    25,147
    Are you guys talking about the same line? The 365GT4 2+2 SPC shows item 10 as being:
    which looks like fitting -to- banjo bolt in the middle -to- fitting so see how that matches Ak Jim's photo (where one flexible leg with swagged fittings was replaced with hose clamps as a fix), but don't see the middle banjo stuff in Al's photo?
  4. Al Campbell
    Nov 22, 2013
    574
    Australia
    Sorry for any confusion.
    Mine is for a series 1 400i but the hose should be of this type as it is the engine oil feed to the engine and under pressure.
    If that hose lets go it will make a big mess of the engine.
  5. Ak Jim
    Ak Jim F1 Veteran
    8,498
    North Pole AK
    Al answered my question. At some point in time someone replaced the hose portion and just used hose clamps. While it has been ok so far I really need to get the proper hose and get rid of the clamps. There is a loot of pressure on that line and I think there is a chance it could fail the way it is now.
    Il Tifoso and Al Campbell like this.
  6. raemin
    raemin Formula 3
    Jan 16, 2007
    1,875
    Lyon (FR)
    R. Emin
    #6 raemin, Mar 19, 2021
    Ak Jim likes this.
  7. raemin
    raemin Formula 3
    Jan 16, 2007
    1,875
    Lyon (FR)
    R. Emin
    Here is what the collet looks like (with new Cohline hose)
    Normally you slide the collet over the loose hose, then you screw the fitting within the hose. Th fittingg is slightly threaded, and the shape is slightly conical, so the more you screw the fitting the more it compresses the hose against the collet. Really nice design.
    Jasonberkeley, Ak Jim and Il Tifoso like this.
  8. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,606
    Romulus, NY (Finger Lakes)
    Ken Battle
    If you have a new hose made, it must be "clocked" exactly right to face the source and destination fittings. There is no rotating these hoses. When I had my long hose made the shop added an extra compression fitting so I could clock the hose myself.
    Ken
    Jasonberkeley and Ak Jim like this.
