Does the Harbor Freight Fuel Pressure Tester work for our cars | FerrariChat
Discussion in '308/328' started by BillyD, Dec 15, 2018.
  1. BillyD
    BillyD Formula 3
    1,805
    Pacific Northwest
    Bill
    Does anyone know if the Harbor Freight Fuel Pressure tester has all the fittings required to test our CIS systems?
    thanks
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Don't have that particular testing unit, and no idea if it works.
    You might consider borrowing one from a parts store. Places like O'Reilly's, AutoZone, and PepBoys will loan you one free of charge. It's not the sort of tool you need to purchase, unless you're a professional tech doing it on regular basis.
  3. BillyD
    BillyD Formula 3
    1,805
    Pacific Northwest
    Bill
    The answer is YES, the Harbor Freight tester has all the fittings to test our K-Jetronic injection systems.
  4. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    please someone make a video of how to use it. Where is the test port or where does it splice in?
  5. warrenz
    warrenz Karting
    Aug 11, 2014
    95
    Sweet S Ranch
    Regis Bragg Stevenson
    Don't Test,
    ,Replace the feul pump and accumulator which are $00 bmw parts,as is filter
    its not really expensive and that little corner down there is VIP,best when new and pristine
    Peace
  6. warrenz
    warrenz Karting
    Aug 11, 2014
    95
    Sweet S Ranch
    Whats the problem?
  7. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,673
    Pittsburgh, PA
    Matt F
    Whatever it is, it's going to get worse after Harbor Freight tools are used!
    Matt
    308 milano and thorn like this.
  8. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    climb likes this.
  9. todd6363
    todd6363 Formula Junior
    Jan 20, 2007
    270
    Ohio
    Todd
  10. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
  11. built2grind
    built2grind Formula Junior
    Oct 16, 2016
    419
    The Peninsula
    ANDREW
    Ferrari owner / Harbor freight tools. Something just doesn't sound right.............
  12. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,252
    Black Forest Germany
    Martin N.
    Why not for rarely used tools?
    An expensive high quality tool doesn't auto automatically make a highly skilled mechanic.
    As well as a owning Steinway Grand piano doesn't make a great piano player.
    For the cambelt drive bearings job, for instance, I can choose between a $300.00 and a $25.00 puller set. Both work for a job, which probably has to be performed once, maximum twice during ownership.
    Best from Germany
    Martin
  13. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,825
    Mike 996
    I have the HF fuel pressure kit and did all the readings with it on my 328 a few years ago.
    Re tool quality - I was always a big Snap-On user back in my engine building days but now I have a mix of various brands of tools and, TBH, I don't see any practical difference in most cases, In fact, I prefer other brand ratchets to the Snaps because of the socket release button which none of my SO ratchets have. HF stuff seems perfectly OK to me for general use. OTOH, I wouldn't buy a torque wrench from HF (or any place else that doesn't provide a certificate of accuracy for THAT particular torque wrench by serial number).
    And I can confirm what Martin stated: I have a Steinway Grand Piano but I suck as a piano player! :) I also have a Martin D28 guitar with the same problem... (both left to me when my father passed away)
  14. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    For occasional use, Harbor Fright tool is barely acceptable. For constant use, even the middle of the road Craftsman tools are no good anymore. I do have a number of supplier tools in my cabinet and I have learned what not to buy from whom. Don't buy... aluminum jacks from HF, they don't last more than a few months of use.
    As for the HF pressure tester, if it has a screw on fitting, then it works.
    Here is a list of tools NOT to buy:
    Aluminum jacks from HF, they squeak, they bend, and they will kill you if they go. This is life saving equipment, go high end.
    Standard ratchets from Sears (they are going out of business, and they only give you a used ratchet to replace the one you broke). The very top of the line Sears stuff, polished ratchets are OK.
    Any electronic torque wrenches from anybody. They last exactly 1 day beyond the warranty, and then they die and it's a constant hassle looking for batteries when they do work
    What can you buy from HF?
    any percussion instrument, ah implements, like hammer, brass drifts, mallets,
  15. yelcab
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    Mike, I already have a piano, but you can sell me your Dad's Martin.
  16. kiwiokie
    kiwiokie Formula 3
    1,539
    Tulsa, OK
    John McDermott
    I bought my CIS pressure gauge set from Pelican Parts. Decent quality and had all the fittings for the job.
