Does The F40 Have a 'Flat Plane' Crankshaft? | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by 512Tea Are, Feb 20, 2008.
  1. 512Tea Are
    512Tea Are F1 Rookie
    Apr 22, 2004
    2,742
    Dear Comrade,
    Is anyone able to confirm whether the Efforty has a 'Flat Plane' crankshaft and if so, how does such a device differ from other crankshafts that are not of a 'Flat Plane?'
    With kind regards,
    512 Tea Are
  2. Birel
    Birel Formula 3
    Sep 12, 2005
    1,941
    Brisbane
    Andrew Turner
    Yes it is a flat plane crank. Basically that means it runs as a pair of synchronized 4 cylinders (firing 2 cylinders at a time) rather than eight firing one at a time. Thats why it doesn't sound like a Chevy, or a Maserati.
    Someone with a better engineering background will hopefully expand on this and explain about 180 degree firing angles and all that. I'd be interested to learn more too.
  3. 512Tea Are
    Apr 22, 2004
    2,742
    Dear Comrade Birel (MHT),
    Would there not then be an imbalance requiring the fitment of a contrarotating crankshaft balancing device?
    With kind regards,
    512 Tea Are
  4. Tifosi66
    Tifosi66 Formula 3
    Nov 30, 2004
    1,786
    Jiang Jia Jie
    Li-Ge
    Dear Comrade 512 TR,
    By your above quote I can surmise that you actually know what's a Cross Plane Crankshaft and a Flat Plane Crankshaft..:)
  5. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,327
    Canada
    Newman
    The engine cant fire 2 cylinders at a time or it would go BOOM! It has alternate bank firing unlike a domestic V8 or Thema's with ferraris V8's which is the reason for the different sound. 90 Degree cranks all start off as flat 180 degree cranks (if they are forged) then they are twisted to arrive at the 90 degree throws.
  6. Fritz Ficke
    Fritz Ficke Formula 3
    2,259
    Tucson, AZ.
    Fritz Ficke
    The point of a flat crank in a v configured engine I belive is to not have harmful harmonics, that is why there is no harmonic balencer on these engines while a engine v configured that fires not perfectly in line with other cylinder might feel smother but has a harmonic balencer on the crank shaft. I have seen harmonic balencer go bad and the driver never feels it intill the crank breaks.
  7. of2worlds
    of2worlds F1 World Champ
    17,525
    ON
    CH
    I would be more interested in the bore, stroke ratio and whether the engine is 'over-square' or not...
    CH
  8. Newman
    Dec 26, 2001
    14,327
    Canada
    Newman
    The engine is over-square. a 308 for example is 81mm bore by 71mm stroke giving 2.9L so an F40 is going to be similar if not the same.
    As for the balancer, my 308 has one wouldnt an f40?
  9. of2worlds
    17,525
    ON
    CH
    The F40 bore stroke is 82 X 69.5mm or 3.22 X 2.73 inches. This yields a 179 cubic inch engine. The little engine that could on a 7.8:1 compression ratio...
    CH
  10. 246tasman
    246tasman Formula 3
    Jun 21, 2007
    1,446
    Will Tomkins
    From www.autozine.org/technical_school
    Engine Smoothness
    V8 engines
    May I say all V8s are 90° ? apart from Ford Taurus SHO's 60-degree 3.4-litre V8 (which was derived from Ford's 2.5-litre 60-degree V6), I haven’t heard any non-90° V8. 90° is the only configuration achieving good balance for V8. However, there are two types of crankshaft arrangements, which delivers very different characters. They are cross-plane crankshaft and flat-plane crankshaft. Most of the world’s V8s are cross-plane V8, including all American V8s and all sedans’ V8s. However, the most exotic European sports cars, including Ferrari, Lotus and TVRs, employ flat-plane V8s.
    Flat-plane V8 (left) and Cross-plane V8 (right)
    Share the same crank pin
    No matter which kind of V8s, they have 5 main bearings. A cylinder in bank A shares the same crank pin with the corresponding cylinder in bank B, therefore the crankshaft of V8 is actually simpler than V6. Both V8s generate no vibration in vertical, transverse directions or between bank and bank.
    Cross-plane V8
    However, for cross-plane V8s, there is vibration from end to end of the engine, this is because the first piston of bank A is not in the same position as the last piston of bank A (the same goes for bank B), unlike an inline-4 engine. No problem, the 90° V8 solves this problem by introducing an extra-heavy counter weight to every cylinder. The counter weight is heavy enough to balance the weight of crank throw, con-rod and piston of that cylinder, thus resulting in lack of vibration.
    Now you must be wondering why such counter weight is not used in other kinds of engines. It is because this counter weight must be used in 90° V-type engines which have shared crank pins. It our previous study, you’ll find only V8 fulfills all these requirements. Why are there such requirements? good question. As you know, all engines have counter weights just enough to balance the weight of crank throws and part of the connecting rods, leaving the remaining weight of connecting rods and the whole, all-important pistons unbalanced. This is because the rotating counter weight can only balance rotating mass. Unluckily, the whole piston moves vertically rather than rotates about the crankshaft, while the CG of con-rod is somewhat rotating but also somewhat going up and down. If we insist to use heavy counter weight, it will cause side shake.
    Considering the illustration. Assume the counter weight in vertical position is heavy enough to balance the crank throw, con-rod and pistons. When the crankshaft rotate 90°, the counter weight is repositioned to the right, but the piston doesn’t go to the left, and the con-rod just partially moves to the left. Only the crank pin moves completely to the left. Now you can see the system is not balanced. The counter weight will generate a net force towards the right.
    However, for 90° V8, when such a heavy counter weight moves to the right, the piston from another bank will cancel it completely, because their movement are exactly opposed at this moment. (see illustrations below) The same result can be found for the counter weight moving to the left. Therefore 90° cross-plane V8 employs full-weight counter weights can achieve near perfect smoothness.
    Flat-plane V8 for high performance cars
    However, the disadvantage of cross-plane V8s is also about the counter weights - not only increase the weight of engine, they also contribute to rotational inertia, thus making the engine less responsive and less revvy, dropping upper rev limit and top-end power. Moreover, the larger counter weights usually requires a larger crankcase to house them, thus raising the height (and more important, center of gravity) of the enigne. Therefore Ferrari all V8 models, TVR Cerbera AJP V8 and Lotus Esprit V8 employ flat-plane V8s instead.
    Flat-plane V8 is named according to the shape of the crankshaft, which is in a flat plane. It is very much like two inline-4 engines mated together. In particular, it achieves end-to-end balance because the first piston and last piston of a bank is exactly in the same position, so are the center two pistons. This is just the same as straight-four engines, therefore the sound of flat-plane V8 is usually somewhat like a pair of four-pot engines screaming simultaneously, unlike the rumble-bumble of cross-plane V8s.
    As both banks run like an inline-4 engine, there is second-order vibration. For a 90° flat-plane V8, the sum of second-order force generated in the 2 banks is - by simple vector analysis - 1.41 times (root-2) of the force generated by each of the inline-4 it consists of. And the direction of vibration is left-right instead of top-down. In other words, while displacement increases 100% compare with the inline-4, the second-order vibration increases just 41%. That makes the flat-plane V8 more refined than an inline-4 although it is not as smooth and quiet as cross-plane V8.
    To exotic sports cars, less refinement is not a big problem. Especially they usually employ short stroke and light weight pistons / con-rods, the second-order vibration is greatly reduced.
  11. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Flat plane crankshaft for sure....
  12. 512Tea Are
    Apr 22, 2004
    2,742
    Dear Comrade 246tasman,
    A superb post and one that I suspect may well take some beating.
    With kind regards,
    512 Tea Are
  13. Fritz Ficke
    2,259
    Tucson, AZ.
    Fritz Ficke
  14. Birel
    Birel Formula 3
    Sep 12, 2005
    1,941
    Brisbane
    Andrew Turner
    I knew we would extract some learning !! Thanks to all.
    The F1 Cosworth DFV engines were "flat" cranks and notorious for shaking delicate electric components to pieces, so you were right to ask the question about inherent vibrations. Some Chev V8 engines were converted to flat crank in the old days of F5000, and boy did they sound good.
  15. 512Tea Are
    Apr 22, 2004
    2,742
    Dear Comrade Birel,
    What is your view of the fitment of a Tubi exhaust to a completely standard and wholly unmolested Efforty replete, as it is, with Classiche Certification? I ask this question, not to draw you out, but as a genuine enquiry from an expert who will provide an unequivocal comment upon which I may rely. Naturally I do not wish Joe Sackey, RufMD or any other members of the American contingent of the United States of America's Efforty Heavyweight to become aware that this may be within my contemplation. However, as you can no doubt assess, I have become rather depressed over Comrade Joe Sackey's decision to refit the Tubi to his Efforty immediatley after gaining the Classiche Cerification honours, and I do feel rather left out of things, being the only contributor to this Forum who holds within his tutelage a complete, and wholly unmolested Efforty, be it the Euro Efforty, the USA F-40 or, as in my case, the Illustrious English F-40 Lightweight.
    Dearest comrade, please advise poste haste, thus that I may feel assurred, or otherwise, that this may be something that I should perhaps consider.
    With kind regards,
    512 Tea Are
  16. Birel
    Birel Formula 3
    Sep 12, 2005
    1,941
    Brisbane
    Andrew Turner
    It is my very humble opinion that all Ferrari cars, not just the illustrious F40, best serve posterity in ORIGINAL apecification. Apart from that, I just happen to think the Tubi is simply too damned noisy and anti-social.
  17. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    Your crazy! A Tubi sounds AWESOME! Loud is GOOD!
  18. carsinxs
    carsinxs Formula Junior
    Feb 26, 2007
    699
    On The Fence
    H
    7+
    you have TUBI's on all your Ferrari's right?
  19. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    I have heard quite a few. What does owning one have to do with knowing how a Tubi sounds? It doesn't. Grow up child.
  20. carsinxs
    Feb 26, 2007
    699
    On The Fence
    H
    Right again. Man you are just down to it with all things Ferrari. 8+
