Does height matter for motorcycles? | FerrariChat
Discussion in 'Motorcycles & Boats' started by agup48, Nov 19, 2008.
  1. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    Sorry if this has been discussed, but I couldn't find anything, and doubt it has been discussed before.
    Alright, I want to get my motorcycle license, and I want to get a sport bike (yeah, I know, I have alot of goals, and things I wan to do, aka road trip, HfH, photography, w/e) but does it matter how tall you are when you ride a bike? I researched this online, and some were saying it depends on the bike, and that it is an "easy" fix. I'm around 5' 3" (yes, I'm asian ;)) so I'm sure none that ride motorcycles really know unless you are short, but I want to know before I try, and end up liking it. :D
    Thanks in Advance. :)
  2. Axecent
    Axecent Formula 3
    Oct 15, 2008
    1,112
    Central Texas
    The issue isn't so much overall height but leg length...I.E. inseam. I am 5'9" but a 28.5" inseam, and many sport bikes have a seat height that is uncomfortably high for my short legs and makes holding the bike up at corners on grades a bit tricky. Taller Ducati's that are also heavy, like the Multistrada and Hypermotard are flat out intimidating for me to ride, and even a 1098 is tall...I have one and ordered the race seat to pick up an extra 1/2" lower seat ht, but I tiptoe at corners on it and that can be nervewracking on occasion.
    You need to go sit on a few and see what you think. Some shorter legged riders just slide their rear to the side at corners and truly stand up on one leg to hold the bike up, and when you look at most GP riders, they are also pretty short....like jockeys. So, if you want to ride bad enough, you can learn to overcome this issue. Also, some sport bikes can be lowered fairly easy (some easier than others, but they can all be lowered with varying degrees of modification) if that is required, and of course, cruisers already typically have lower seat heights. There are also some sport bikes with lower seats, like my Bimota YB8 and others.
  3. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    Well, for a beginner bike, I was looking at a Ninja 250cc, or 600 as I read that 250cc's will get boring fast. I'm just a beginner so I don't wan't a Ducati or anything that might be dropped. :eek:
  4. Kravchak
    Kravchak Formula Junior
    Oct 17, 2005
    850
    Northeast
    Ken
    I think you need to sit on the bikes and see what you are comfortable on. Especially if this is your first bike you'll want to be able to at least touch both your tip toes down on each side as to avert a fall to either one. Believe me if you have a tall bike and are hanging over the one side to hold it up and you high side (meaning for some reason you start going the other way over) there is no way to stop but fall. and the girls think your a dork because it doesn't look pretty. I only did it on my racing bike once and then never again. But now I have no issues at all as I am 6'4" and have a 36" inseam it's hard to find a bike that is too tall.
    The other part about a tall bike is the higher center of gravity at slow speeds is a little hairy, feels like the bike want to lean the turns on its own instead of you leaning the turns with a lower center of gravity bike...
    Oh and last thing, they do "settle" a little after riding a few hundred miles and breaking in the suspension on these street bikes...
  5. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,554
    NY/SC
    David
    Saddle ht may well be an issue. I would go to dealers and private sellers and try your interests for size. Or you can determine what saddle height works for you (after finding one that works) and then call around or google/go to boards for bikes that match your specs. I would think sportbikes.net would have noob stickies or something that would help with this.
    As for the 250 vs 600, plenty of discussion and opinions on this. If you can think of starting with a 250 not as a quickly-outgrown waste of money, but instead of whatever that depreciation (when you sell and move up to a 6) as the cost of your safe progression, it's worth every penny. Start with good full gear and then buy w.what you have left. $3k is plenty to spend for a 1st bike.
  6. ExoticSpotter
    ExoticSpotter Formula Junior
    Jun 1, 2008
    685
    Honeslty, getting a 250 is never a bad idea. You can pretty much always sell them for what you paid for them! Especially the new 08 250 Ninja (if you can even get your hands on one).
    Regardless of what bike you get, take the MSF course FIRST and get good habits before you learn bad ones.
  7. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    Yeah, I was planning on doing the MSF course.
    and thanks David, noob stickies, I like it. :D
  8. tundraphile
    tundraphile F1 Veteran
    May 16, 2007
    5,083
    Missouri
    #8 tundraphile, Nov 19, 2008
    A new 600 will be too much for you even if you could fit on it, which you probably cannot.
    A 250 or older small bike would be a much better choice. An older EX500 Kawasaki or GS500 Suzuki would also serve you well for a season or two. Even a small Ducati Monster (they made a 600 and 620) would probably be short enough and not be that intimidating.
    Buell makes a bike with a lower seat height just for shorter riders, but it would be too much for a beginner.
  9. mchas
    mchas F1 Veteran
    6,084
    Los Angeles
    Mark
    My coworker is about 5'4" and bought a Suzuki SV650 with a shaved seat. He can sit on it with his feet flat on the ground. It's often recommended as a good first bike. Just another option.
  10. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,320
    SFPD
    Dirty Harry
    250 Ninja - Out-The-Door price should hopefully come down when 2009 models hit states in Feb/March, as they were spectacularly redesigned in 2008 and gouging was in full effect. You can wring the most of this bike.
  11. DMOORE
    DMOORE Formula 3
    Aug 23, 2005
    1,720
    San Diego
    Darrell
    Agup48, Here is the ticket. Buy a used Ninja 250, ride it a year or so, and then sell it. When My wife wanted to start street riding, I first had her attend a MSF course. Then we purchased said Ninja. She had no problem touching (4'11"). The bike is lite, handles well ( I loved passing guys on bikes 3 times the size, on Palomar Mtn.) and holds a great resale. We kept the Ninja for 2 years and sold it for MORE than I paid for it. Don't waste your money on a new one. After you are used to riding a street bike, the seat height, and weight will not be such a factor.
    BTW. I am selling my wife's NSR250 that she no longer rides due to a bad neck. I'll let it go for cheap, (and I can promise, there is NO street bike that will out handle a 250 Racerep). She now sticks to her Harley 1200 Sportster, due to it's upright riding position.
    Darrell.
  12. James in Denver
    James in Denver Formula 3
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    I know you mentioned a "sport bike", but the Honda Rebel 250 or 450 is a good "shorter" starter bike.
    I'm 5'6 with a short inseam (29 i think) and I ride a BMW R1100R with the seat on the lowest setting (BMW R bikes have 3 seat height adjustments). I rode but did not fit a BMW K100RS, nice bike, but I could not flat foot it at all, rather dangerous.
    I suggest the Rebel for another reason, its not too powerful. I know 2 people who bought thier first bikes with substantial loans, the wrecked the bikes within 2 weeks of ownership. The Harley owner said "the throttle stuck", the yamaha owner said "I didnt think the back brakes would lock up". Both wrecks were solely based on inexperience.
    I know the sport bike guys ride hard and crazy, looks cool when it works. Watch YouTube for a while and you'll see how fun a faceplant is when you're stoppie doesnt stop correctly.
    Good luck,
    James
  13. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    Again, thanks again to all.
    James, I don't that's the reason I want a sport bike to ride hard and crazy, I've always like those types of bikes, just personal preference, not trying to impress anyone either since lots of people get that.
    And, I know "everyone" says they won't get in wrecks and all that, but you stated above, based on inexperience. How do you classify someone as experienced, the number of years they've ridden, the way they ride, so many different ways to classify that. Also learned that even if you're a good rider, it all depends on the other drivers, so thats the main concern.
    Mostly, I'm looking for a bike that will be a commuter, and fun to ride, I'll always wear my gear regardless of temperatures (PHX weather sucks, but so does hot asphalt) Thanks again to all, I'll probably give MSF a try during the summer time back in Austin and then go from there. I'm sure they will help me out as well. :)
  14. AustinMartin
    AustinMartin F1 Veteran
    Mar 1, 2008
    5,445
    Los Angeles/Idaho
    Why??? Already to popular... :D:D:D
  15. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    No, because I know I'll make an ass out of myself if I do. :D I.E: Stall, fall of the bike, crash, etc. :D :D
  16. AustinMartin
    Mar 1, 2008
    5,445
    Los Angeles/Idaho
    Now I just need video! :D:D:D:D
  17. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    I can haz stardom?! :D
  18. GuyIncognito
    98,978
    I'm 5'6", 31 inch inseam (long legs for my height I suppose). I ride a CBR600RR and the fit is no problem, can get both feet down at stoplights, etc. However, I couldn't do the same on an R6 because of the width of the saddle. Do your research, sit on a lot of bikes, find one that is comfortable.
    Also, if this is your first bike...a sportbike might not be ideal. (there are other threads on this topic)
  19. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    Yup, still reading mostly. I have probably till the end up summer so I have a while to do this. I just want to do so many things. :eek:
  20. smoney
    smoney Karting
    Jul 24, 2004
    215
    Try sitting on different models and see what "feels right for you"-the last thing you want is to drop your bike because you can't touch the ground.If you REALLY want a sport bike,then why not check out a Ninja 250cc-take a motorcycle safety course(maybe offered at a local community college-check with your DMV or local motorcycle dealership may have that info. for you)-I'm 5'8 and had to cut 1 inch out of my foam seat n re-cover it and I still wear boots with a big heel.-Good luck n ride safe always!!!
  21. agup48
    Apr 15, 2006
    28,633
    Phoenix
    AG
    Thanks, I found out information already about MSF, It's either here in Phoenix at the Harley Davidson dealership or in Austin at some middle school. I actually know a guy who's about my height maybe an inch or two taller in one of my classes, I'll probably talk to him about it, and see if he has any trouble, he says he has an R1.
  22. AustinMartin
    Mar 1, 2008
    5,445
    Los Angeles/Idaho
    You can be FAMOUZ!!!!
  23. Kingair33
    Kingair33 Formula Junior
    Aug 28, 2006
    941
    San Francisco, CA
    Alex
    Darrell, You have a PM.
    Agup48, I have a 30in inseam and can sit with my feet flat on the ground on both the EX 250 ninja and EX 500 ninja perfectly fine.
  24. DMOORE
    DMOORE Formula 3
    Aug 23, 2005
    1,720
    San Diego
    Darrell
    Check.
    Darrell.
