Do you have to remove valve covers to replace oil sending unit? | FerrariChat
Discussion in 'Technical Q&A' started by 3POINT8, Oct 1, 2020.
  1. 3POINT8
    3POINT8 F1 Rookie
    4,397
    Random question on 458 -
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,344
    The Cold North
    Tom
    Oil sender is near the oil filter housing in the mid rear top section of the engine. Removal of the valves covers would be a no. Removal of the intake manifold would be a yes..
    Never have I ever felt the need to replace the sender.. what reason do you need to replace it? Leaking..
  3. 3POINT8
    3POINT8 F1 Rookie
    4,397
    thank you so much. i did not replace it. my mechanic did. the car was reading low oil pressure but when they tested it manually it was fine so they believed it was the oil sending unit so they replaced that.
    you can replace the oil pressure regulator valves without removing the valve cover correct? i believe they just slide out. i believe i was confusing the oil pressure regulator valves and the oil sending unit.
  4. 3POINT8
    3POINT8 F1 Rookie
    4,397
    also random, do you know if the oil pressure regulator valves were a common failure in these cars (2012 458) or were a recall?
  5. tbakowsky
    Sep 18, 2002
    19,344
    The Cold North
    Tom
    No I do not. I haven't encountered a 458 with oil pressure issues as of yet..
  6. 3POINT8
    3POINT8 F1 Rookie
    4,397
