DIY Maintenance 458 thread. | Page 7 | FerrariChat
Discussion in '458 Italia/488/F8' started by Melvok, Feb 25, 2019.
  1. wthensler
    wthensler F1 Rookie
    3,153
    Gator Country, FL
    William
    Hmmmmm. I hadn’t envisioned that scenario. I hope you hold stock in Michelin.
  2. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    901
    Homosassa, FL USA
    Ian Joubert
    lol ... you'd think at this point I would have been bright enough to buy some, but sadly, no.
  3. Ianjoub
    Dec 22, 2019
    901
    Homosassa, FL USA
    Ian Joubert
    That being said, the Michelins are relatively cheap. I think I spend $1100 or so when I buy them (I still have wholesale tire accounts). The 18" all terrain tires for my wife's truck are more per set (though they last 40k - 50k miles instead of 8k).
  4. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,116
    Mel
    Dunno, just normal torque with my tool … felt O.K. (but is in the digital WSM that I use … )
    Need to do the BEDDING now but it's not dry in NL / EU now.
    Anyone has done that before ?
  5. Baitschev
    Baitschev Formula Junior
    Jan 8, 2017
    262
    Vienna
    Hi Mel How many mm Are the Rest of brake Pad
  6. Melvok
    Jul 25, 2008
    14,116
    Mel
    3 mms, but the thinner they are, the hotter they get ….
  7. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    Yes, these sensors automatically marry themselves to the car after driving a few hundred feet. Very easy!
  8. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    Thanks for the complete write up!
    There are two tools that I recommend for this job. They are not necessary, but they are helpful to try to avoid damage to the calipers:
    https://www.amazon.com/gp/product/B07QXMGT6X/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    https://www.amazon.com/Lisle-29100-Quick-Quad-Spreader/dp/B005GLQCKA/ref=sr_1_5?dchild=1&keywords=caliper+spreader&qid=1604266426&sr=8-5
    (however, I didn't try the caliper spreader on the Ferrari yet, but worked great on the mustang brakes with the Brembo option. So not 100% sure it would be good, but not sure why it wouldn't)
    Melvok likes this.
  9. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    Like girls, hahaha
    Mikael-F360 and Melvok like this.
  10. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    27 - 33 NM (20-24 Ft/Lbs ) according to the shop manual
    Need4Spd likes this.
  11. Melvok
    Jul 25, 2008
    14,116
    Mel
    He guys, no I have a little problem :)
    My battery is not trickled anymore, the connection seems not to work. Trickler Leds do not react as indication.
    So what now, deduction ... and first thing I see is that the connector from the trickler seems broken.
    Secondly, I can get no pwer (+) in the dashconnector ..., also not after had it taken out.
    Anyone has had this ?
    Is there a fuse for the trickler power socket ? At least not in the didgi WSM or Owners Handbook.
    Baitschev likes this.
  12. Melvok
    Jul 25, 2008
    14,116
    Mel
    There was a thread a long time ago, explaning wher to get these connectors, especially the SD1327.
    Can anyone help we with where and how we can find these connectors please ?
  13. Melvok
    Jul 25, 2008
    14,116
    Mel
    One lead I found was that in the fusebox behind the driversseat one fuse F 68 is mentinned as: F78 15 amps +30 Battery charger.
    At least one lead ....
    Will let you know my findings next week .....
    turbokraft likes this.
  14. Melvok
    Jul 25, 2008
    14,116
    Mel
    Baitschev, up4speed and turbokraft like this.
  15. Melvok
    Jul 25, 2008
    14,116
    Mel
    #166 Melvok, Nov 24, 2020
    Found the other fault …. the CTEK was NOT delivering enough trickler pulses.
    It shows only one bar (level of battery loading) … on a new trickler … EMPTY BATTERY !
    Added a simple and cheap $ 30 trickler from a local hardware store: all problems away !!
    GET RID OF THE OEM CTEK before you will also have problems ….
    Next morning: full ! :)
  16. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    I'm about to change the accessory belt. There is a cover on one of the pulleys that has to get removed.
    There is one screw that is in a really tight place, does anyone have a trick to get that one off, and on when done?
    I will be doing it tomorrow, I would love any hints that anyone can give me!
  17. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    I'll reply to my own post, since I changed it today, lol.
    There are 3 bolts holding the cover over the power steering pulley. One bolt is hidden behind pipes, so my hand had trouble fitting (you can see it). The technique I used was to use a 1/4 ratchet, with the proper length extension to position it where it can turn, the tricky part is to get the screw once it's loose. I used one of those grabber tools with a flexible shaft, I was able to grab he screw and guide it out when taking it off, and guide it back in when installing.
    There is also an arrow on the belt, make sure it rotates in the proper direction (clockwise when looking at the belt, and facing the rear of the car).
    This first time took me about 20 minutes (with a lift), I think I can do the next one comfortably in 10.
    nothingbutair, MalibuGuy and Melvok like this.
  18. Melvok
    Jul 25, 2008
    14,116
    Mel
    Photos Chris ?
  19. up4speed
    up4speed F1 Rookie
    3,544
    Long Island, NY
    Chris
    Unfortunately I didn't get any photos or video. By the time that I realized that it would be a problem, I was already elbow deep into it, and wasn't planning on even posting anything at the time, I just was focused on getting the thing done.
    I only decided to post afterwards, once I realized that I may be able to help others from getting frustrated and cursing and screaming, lol.
    To be honest, it's not that complicated, and if one were to read my post, and look at the situation, it would be fairly obvious.
    Now that I think about it, I feel like I missed a great opportunity to make a belt replacement tutorial, or even video. Darn it, sorry
    Melvok likes this.
  20. Melvok
    Jul 25, 2008
    14,116
    Mel
    No problem Chris !
  21. Melvok
    Jul 25, 2008
    14,116
    Mel
  22. Melvok
    Jul 25, 2008
    14,116
    Mel
  23. Melvok
    Jul 25, 2008
    14,116
    Mel
